as long as the WUR is off a 5000 TURBO, then its the right one..
the fuel dizzy however, no, its not the same as a 240 turbo setup..
you can use a stock VW cis-lambda setup, with the 5000 turbo WUR, and make it boost capable..
its apparent that you need to read more tho.. there are DETAILED instruction guides on how to make your CIS boost friendly..
