Page 1 of 2 1 2 LastLast
Results 1 to 35 of 51
Thread: 5,200+ miles over 10 days in a Mazda2 (long read)
  1. Member Assle's Avatar
    Oct 16th, 2003
    Blackacre
    '98 L36 Regal
    05-16-2012 01:55 AM #1
    Spent the better part of 10 days on the road in a Mazda2 traveling from Chicago to San Diego and back again. Thought I'd share my impressions on the car.
    For the tl;dr crowd:
    Surprisingly-good performance
    Averaged 30.4 mpg
    Typical Mazda interior
    Unabridged riveting tale chap:
    The Friday before last (May 4th), my buddy and I took some basic travel supplies + clothes and headed off on a roadtrip in a True Red Mazda2 Touring with ~6,200 miles on the odometer that looked like this:
    Prior to the trip, I had been interested in a Mazda2 so having one for such a trip made for perfect coincidence. For those not familiar, here are the basic stats on the car:
    100hp/98tq 1.5L 16V 4-cylinder
    Auto
    ~2,350lb curb weight
    0-60 in 9.2 seconds
    Top speed of 109mph
    The trip itinerary went like this: Chicago -> St Louis -> Oklahoma City -> Albuquerque -> San Diego -> Las Vegas -> Denver -> Chicago
    First and most-noticeable was how well the car drove. It weighs as much as my '89 Integra did but feels much better planted to the road than that car ever felt. Steering response is sharp and brakes catch very quickly. Surprisingly little body roll/lean considering how cheap the car is. As far as power is concerned, the 100hp/98tq may be at least 54lb-ft short of sufficient for safe passing, but it felt like plenty in this car even with the additional ~500lbs with us in it. It didn't stand a chance in any aspect against the Z8 we ran across on Mulholland and the engine had a tough time climbing I-70 by Denver up to the ~11,600-foot elevation, but it never gave off that impression that we could have dead.
    I was also quite impressed with the interior. Much like in my sister-in-law's Mazda3, the interior in this car is surprisingly cavernous and well-arranged. The dash and door cards, though, (much like they are in the Mazda3), are easy to mar/scratch. The trunk is roomy enough for two medium duffel bags and tools without a problem. There are several cup holders and change trays of various widths and depths in the center console. Map pockets in the front door cards flared in width toward the front of the car meaning you could stash items of wider width in there (such as a CD case). The rear doors, however, do not have pockets. Also, the part of the elbow rest on the front doors where you put your fingers in to pull the door closed was padded with soft material. This is great as I hate having something rattling in there as it does in most other cars. Lastly, the car does have a good seating position relative to window shape for cruising with your arm resting on the door.
    Other things of note:
    The Yokohama Avid S34F tires performed very well from the canyons of California to the snow/ice of Denver. Always good grip except for minor hydroplaning in New Mexico.
    Very little highway noise.
    There is no engine temp gauge, only one blue dummy light to let you know the engine has not warmed up to optimal temperature, and one red dummy light to let you know if the engine is too hot.
    Wider-than-expected turning radius. I tried to turn around 180 degrees at a gas station around the pump island and could not do it in one smooth move.
    Small 11.3 gallon gas tank made for stopping 2-3 times a day to get gas but at least it was cheap and quick to fill up.
    Overall trip fuel consumption was at 30.4 mpg. Trip consisted of almost all highway driving, never more than 5-7mph over the limit.
    No satellite radio. Not sure if it was just this car that didn't come with it or if the Mazda2 doesn't have it as an option at all.
    No sunroof. Again, not sure if at all available from Mazda.
    The cruise control would occasionally go into thermostat mode where it let the actual speed fall nearly 5mph under the set limit and then overcompensate by bringing the actual speed over the setting by 2-3mph. A few times, the cruise control would just randomly shut off or gun the engine to 5,000 rpm on level roads without much elevation change up or down.
    The distance to empty display would sometimes add mileage to the range instead of subtracting as we're driving along. This might be because of the gasoline moving about in the gas tank.
    The headrest makes for a vision obstruction if you look over your shoulder on the door side.
    Placement of the shifter being in the dash makes it pretty easy to tap into neutral when bringing your hand up from the center console area.
    The backs of the front seats do not have storage areas.
    The seats were quite comfortable and did not wear us out sitting in them day after day for a week and a half. The side bolsters were quite supportive on both parts of the seat even if the did feel flimsy in hand.
    The front passenger seat can slide forward of the B-pillar if you need to fit a large item into the back seat area.
    It is possible to turn the trunk light on/off with a switch but the light doesn't illuminate the trunk area very well.
    You do have a button to turn the DSC off, which was nice, but there is no indicator to inform you if wheel slip was detected.
    Only one 12V port.
    The glove box does open without crashing into your shins, which is more than I can say for most other cars I've been in.
    There is no dummy pedal to rest your left foot on, but there is a flat vertical carpeted space where a dummy pedal would have gone.
    All in all, I liked the car and I would consider owning one if I were in the market for a new small car. Only things I'd have to have that this car did not come with is a sunroof and manual trans.
    "Sometimes wrong is worth the funny." - Billy Gardell
  2. Member Aguilar's Avatar
    Jan 28th, 2006
    El Paso, TX
    02 Z06, 93 MX-5 LE, 2013 GTI
    05-16-2012 04:38 AM #2
    Nice review, you definitely get to know cars on long trips. I will be doing a 2000 mile trip in the Corvette soon, I'll definitely post something about it.
  3. Member mike02467's Avatar
    Mar 17th, 2010
    Massachusetts
    2011 Civic SI
    05-16-2012 06:24 AM #3
    My sister has a 2010 Mazda 3 and I think the interior is terribly laid out. The back seats are extremely cramped and the dash is just a plain mess. The seats are too firm and the ride is somewhat harsh. That's pretty bad gas mileage... my '93 2.sl0w golf would get 34mpg highway with me flooring it out of every toll booth and off ramp.
  4. Member GolfTango's Avatar
    Feb 15th, 2001
    Not Fancy CT
    09 Mazda5 GT, 09 Saturn Aura XE
    05-16-2012 11:11 AM #4
    Quote Originally Posted by mike02467 View Post
    A mess?
    My flickr
    Me
    The best way to give advice to your children is to find out what they want and then advise them to do it. - Harry S. Truman
  5. Member One_Love's Avatar
    Aug 2nd, 2006
    erie pa
    05-16-2012 11:23 AM #5
    he is talking about the 3 interior...but regardless i disagree with it. i think the dash is awesome. Unlike the truck dashboard in the civics
  6. Member GolfTango's Avatar
    Feb 15th, 2001
    Not Fancy CT
    05-16-2012 11:27 AM #6
    Quote Originally Posted by One_Love View Post
    So he's comparing a 3 to a 2 And the 3 looks great as well:
    My flickr
    Me
  7. Member Mike!'s Avatar
    Jun 17th, 2002
    Ontario & Ohio
    2010 Mazda6 GT-I4
    05-16-2012 12:31 PM #7
    The 4-speed auto sure kills the mileage. The manual does well, but it sounds like the auto could use the JDM SkyActiv 1.3l/ CVT combo... 84hp be damned.
    Oct 4th, 2000
    San Francisco, CA
    05-16-2012 12:53 PM #8
    It's unfortunate the mileage is so low for mostly freeway driving. My Subaru (with huge AWD drag) from 1999 will beat that in all highway driving.
  9. Member VadGTI's Avatar
    Feb 24th, 2000
    Hollywooooooood, CA
    05-16-2012 01:18 PM #9
    I hate it when TCLers come to LA (especially all the way from Blackacre) and don't say hello. It makes me angry .
    Fizzy - Team My Little Pony
  10. Member NightTrain EX's Avatar
    Feb 24th, 2004
    Outside ATL
    05-16-2012 01:19 PM #10
    I think sirius is a dealer installed option. Did your car have a "SAT" button that didn't operate anything?
    Quote Originally Posted by pops View Post
    I'm naming my next child NightTrain EX.
    Quote Originally Posted by WhistlerYOW View Post
    You're a pretty cool dude.
  11. Member Assle's Avatar
    Oct 16th, 2003
    Blackacre
    '98 L36 Regal
    05-16-2012 01:22 PM #11
    Damn!, totally spaced on that! I fear SuperHipsters and did not come bearing any flannel so would have been a lost cause. I'll be back in the fall or winter on a food truck feeding frenzy
  12. Member cryption's Avatar
    Mar 27th, 2006
    Houston
    99 Miata, 2011 Fusion, Texas Edition Silverado
    05-16-2012 01:24 PM #12
    Quote Originally Posted by Mike VR6 View Post
    This is my thought.
    My 2011 Fusion can get 35 on the highway cruising - and it's a much bigger car. I would expect close to 40 highway out of a 2.
    Aside from the poor mileage, seems like they are still neat little cars.
    Team 30k Jetta - Frat Boys
  13. Senior Member Aonarch's Avatar
    Dec 4th, 2006
    B6 Variant 3.6L VR6 4Motion | E30 325e | MKVI Golf 2.5L | Versys 650
    05-16-2012 01:25 PM #13
    I've been looking at a 2, but I would have to have the manual.
  14. Member Assle's Avatar
    Oct 16th, 2003
    Blackacre
    '98 L36 Regal
    05-16-2012 01:25 PM #14
    Quote Originally Posted by NightTrain EX View Post
    No "SAT" button but there were 3 faux button covers on the panel to the left of the steering wheel where the "DSC" button was. IIRC, Car & Driver griped about the lack of satellite radio on the long term test car. Theirs was a 2011 so maybe that changed for 2012.
  15. Member NightTrain EX's Avatar
    Feb 24th, 2004
    Outside ATL
    05-16-2012 01:25 PM #15
    I think the combination of the car being loaded + climbing mountains contributed to this effect. That engine was probably working pretty darn hard.
  16. Member NightTrain EX's Avatar
    Feb 24th, 2004
    Outside ATL
    05-16-2012 01:26 PM #16
    Quote Originally Posted by Assle View Post
    My 2011 3 had the button but the receiver needed to be installed at dealership. I have those 3 button covers as well near the DSC off button...don't know what they were for
  17. Member Assle's Avatar
    Oct 16th, 2003
    Blackacre
    '98 L36 Regal
    05-16-2012 01:28 PM #17
    Quote Originally Posted by cryption View Post
    This is my thought.
    I'm gonna blame the gearing and the strange behavior by the cruise control coupled with the tiny displacement. Almost every uphill was a SCREAM AT 5,000RPM (!!!) situation. Bigger displacement comes in handy for hill ascent.
  18. Member cryption's Avatar
    Mar 27th, 2006
    Houston
    05-16-2012 01:29 PM #18
    I reckon you're right on.
    Do you have any idea what it would get 70mph flat terrain? The biggest hill I have here is a freeway overpass anyway.
  19. Member Egz's Avatar
    May 30th, 2002
    Virginia
    2003 Ford Focus 2.3, 2006 Ford Fusion 2.3 Turbo, 2009 Civic EX Coupe
    05-16-2012 01:30 PM #19
    Sounds about right. I would personally like to see a 1.8 or 2.0 in this with a little more power.
  20. Member NightTrain EX's Avatar
    Feb 24th, 2004
    Outside ATL
    05-16-2012 01:32 PM #20
    Quote Originally Posted by Egz View Post
    With the SkyActive 2.0 this thing would be a rocket in comparison...and get great mileage to boot
  21. Member Assle's Avatar
    Oct 16th, 2003
    Blackacre
    '98 L36 Regal
    05-16-2012 01:35 PM #21
    From watching the instant consumption meter on level ground at 70mph, the reading was in the 35mpg range.
  22. Member cryption's Avatar
    Mar 27th, 2006
    Houston
    05-16-2012 01:39 PM #22
    I could live with that. I would truthfully use a car like this for putting around town more often then not, and use the Fusion for the highway.
  23. 05-16-2012 01:41 PM #23
    I have a 2011 manual transmission Mazda 3 and have averaged on at least two occasions 6.0L/100km (39 mpg) with 3 people and a loaded trunk plus A/C @ just under 120km/h. Fantastic little car.
  24. Member
    Feb 15th, 2010
    Chesterfield, Indiana
    2009 Caliber SRT4, 1989 Mazda B2200, 2010 RAV4
    05-16-2012 01:45 PM #24
    I like these as cars for around town but that mileage isn't what it should be and it's not all the transmission's fault. My wife's RAV4 with a 4-speed auto gets 30 on the highway and it weighs a lot more.
  25. Geriatric Member BRealistic's Avatar
    Dec 16th, 2005
    Tennessee
    88 F150, 04 RX8
    05-16-2012 03:56 PM #25
    Loaded down with passengers and cargo through the mountains?
    And small cars are about getting great real world daily driving mpg.
    Who buys a small inexpensive car for long highway trips?
    Larger cars with bigger engines that allow better highway gearing tend to do much better on the highway than around town.
    Some larger cars double their real world urban mpg on the highway.
  26. 05-16-2012 08:54 PM #26
    I have a manual 2 and am averaging 37 mpg over 10000 miles of mostly highway driving.
  27. Member adrew's Avatar
    Aug 14th, 2003
    Texas
    Yaris x2
    05-16-2012 09:01 PM #27
    Quote Originally Posted by proximal View Post
    The automatics really kill the mileage on these little engines. My 5-speed Yaris gets 36-38 MPG in mixed driving (just have to coast up to lights and accelerate gently) and upper 30s/low 40s on the highway depending on speed. 85 MPH = 35 MPG
    Improving the signal-to-noise ratio
  28. Geriatric Member BRealistic's Avatar
    Dec 16th, 2005
    Tennessee
    88 F150, 04 RX8
    05-16-2012 10:12 PM #28
    Quote Originally Posted by adrew View Post
    The 4 speed automatic can get low/mid 30s in mixed driving.
    http://www.fueleconomy.gov/mpg/MPG.d...rue&details=on
    The OP's situation was a small car loaded with passengers and cargo.
    That is not the same as a car being driven by a single driver in an unloaded car in 30-60 mph traffic.
  29. Geriatric Member BRealistic's Avatar
    Dec 16th, 2005
    Tennessee
    88 F150, 04 RX8
    05-16-2012 10:13 PM #29
    Your post does not count.
    We must keep bashing the Mazda2's fuel economy!
    Most Mazda2 user numbers easily beat the EPA estimates.
    Obviously the Mazda2 was not optimized for the EPA mpg tests.
  30. Member adrew's Avatar
    Aug 14th, 2003
    Texas
    Yaris x2
    05-16-2012 10:21 PM #30
    The 4 speed automatic can get mid 30s in mixed driving.
    I took our '11 on a camping trip last weekend with two other people, a tent, three sleeping bags, three sleeping pads, a crate of food, a big cooler and some other stuff (basically it was full to the brim) and still averaged 40 MPG on the trip (2 hours each way, 55-60 MPH country roads).
    On road trips (loaded down) I get 35-40 MPG depending on speed. 55-60 MPH = 40 MPG, 85 MPH = 35 MPG.
  31. Member jddaigle's Avatar
    May 30th, 2003
    Denver, CO
    2008 Passat Wagon VR6 4motion, 2001 VW Jetta 1.8T
    05-16-2012 10:27 PM #31
    My 11 year old Jetta 1.8T gets a good consistent 32mpg on highway road trips through the Rockies, with 4 people and their luggage. However it does benefit from having a manual transmission, and I skip the cruise control. It is a little disappointing that the smaller Mazda 2 doesn't seem to have a significant mileage advantage over the larger and more comfortable 3.
    - Jeff
  32. Member windycityvdub's Avatar
    Jan 21st, 2008
    Nashville, TN
    2012 MINI Cooper S, 1986 BMW 528e BABE Rally Beater
    05-16-2012 10:31 PM #32
    I took a 7000 mile trip last summer (Chicago to SF and back, the long way) in a Jetta 2.0T DSG. Car had two people and was packed with cargo...averaged about 31 mpg. I couldn't imagine doing it in a smaller/less refined car. You are brave.
  33. Geriatric Member BRealistic's Avatar
    Dec 16th, 2005
    Tennessee
    88 F150, 04 RX8
    05-16-2012 10:36 PM #33
    That is great.
    And don't get me wrong- the 4 speed auto obviously hurts the Mazda2's fuel economy.
    But it still returns great fuel economy in normal driving (combined).
    The manual is better.
    A couple of 40 mpg users here.
    And the automatic hurts the Yarises mpg too.
    It's just nice to see that some gas vehicles with nice epa numbers seem to easily surpass their epa estimates (Yaris, Mazda2).
    But I guess when you only have 100 hp and even less torque, you can't really play with the highway gearing that much to maximize the test results.
  34. 06-18-2012 11:53 AM #34
    With my 5-speed Mazda2 I'm averaging 34.4 MPG over 26,000 miles in mostly suburban driving. I've gotten up to 38 MPG on highway trips, and never less than 31 MPG in mostly city driving.
    __________
    GCF - The Alternative Automotive Community
    it's = it is
    its = possessive of "it"
  35. Senior Member Aonarch's Avatar
    Dec 4th, 2006
    06-18-2012 11:57 AM #35
