VWVortex.com - Race pedal cluster (Again)
    Results 1 to 7 of 7
    Thread: Race pedal cluster (Again)
    1. Member stewardc's Avatar
      Feb 2nd, 2005
      Nova Scotia, Canada
      '81 Rabbit Pickup
      05-16-2012 10:16 AM #1
      I know, "here it goes with the pedal clusters again"
      Surely someone, in all the years of Rabbit production and racing, has produced a more substantial pedal cluster for these old Rabbits??? I have a heavy clutch due to the torque of my AAZ diesel, and have reinforced the cable tube once, but the big ACT clutch is just too much for this thin metal structure. Someone else must have had this problem and come up with a creative solution ??? Help me please !
    2. Member stewardc's Avatar
      Feb 2nd, 2005
      Nova Scotia, Canada
      '81 Rabbit Pickup
      10-04-2012 07:08 AM #2
      Bump....anyone ???
    3. 10-04-2012 08:00 AM #3
      Tilton seems to be a common go-to.
      Because racecar: http://www.hrpworld.com/index.cfm?fo...ction=category
      Drift Car Build! - now with drift car content!
      Benny and the jets - Just your average air cooled 911 adventure
    4. Member Vegeta Gti's Avatar
      Feb 12th, 2003
      konoha village, hawaii
      1984 GLi 20v, '16 M3, '85 Golf, '03 BMP 20th AE
      10-04-2012 08:10 AM #4
      doesn't make sense to me, i have 370+ft.lbs and run a pretty serious clutch....zero issues in five years. then again, fuk act. get clutch master
      Sent from my SPH-D710 using Tapatalk 2
      :HOMEGROWN MOTORSPORTS:1:4.9 SuaSponte #13Dead Rabbits. Ungluck on IG. MKIforLife
      Quote Originally Posted by .Ant View Post
      What vegeta said.
    5. Member 2021cc8V's Avatar
      Apr 21st, 1999
      California...
      10-04-2012 03:47 PM #5
      if you're getting flex from the thin body structure where the pedal cluster mounts to, then reinforce it with a metal backing plate to stiffen things up.
      you also might want to check your clutch cable. maybe it's worn-out/rubbing/binding? maybe it's time for a new one...lube it up and go.
      i have an ACT six puck solid-centered clutch disc to one of their double-strapped pressure plates. I haven't had issues with it. Clutch engagement is a little bit heavier but otherwise pretty reasonable.
      i did have chattering issues early on, but now that everything has broken in, it's been pretty easy to drive.
    6. Member Vegeta Gti's Avatar
      Feb 12th, 2003
      10-04-2012 03:56 PM #6
      see that's weird, i run a clutch masters fx400 with the triple strapped PP and 6 puck clutch. pedal is maybe 15% heavier than stock 020 lol
      and i'm running a manual clutch setup on an 02J
      What vegeta said.
    7. Member 2021cc8V's Avatar
      Apr 21st, 1999
      California...
      10-04-2012 04:23 PM #7
      That's why if it's an 020, I'd think maybe a new clutch cable is in order...when those things bind, the action is horribly heavy.
