Results 1 to 10 of 10
Thread: Clear fluid leaking inside car
  1. 05-16-2012 11:43 PM #1
    I have a clear oily fluid leaking inside my Jetta. It's dripping down from right above the gas pedal. It's clear, has no odor. Anyone know what this is?
  2. Member I haz cheezeburgerz's Avatar
    Aug 8th, 2008
    Syracuse, New York
    96 GTI + 99 CR-V
    05-16-2012 11:52 PM #2
    probly brake fluid. in small quantities it looks clear.
  3. Member Sky-Fi's Avatar
    Jan 19th, 2008
    Charleston, SC
    97 LG5R Jetta GLS
    05-17-2012 12:31 AM #3
    What about coolant? I know if the heater core leaks, then it leaks inside the cabin, but I don't know from where it leaks out of. Inside the dash makes sense since that's where the air box is.
    Just my theory.
    We need a series like this state-side. I'm in if there is one, or will be one. VW Cup 2013, anyone?
    Mar 23rd, 2008
    N/A
    N/A
    05-17-2012 01:04 AM #4
    When the heatercores in my Jetta and Golf blew open, the leak was right at my gas pedal, so I would guess that it's the heatercore.
    Check the coolant bubble and see if the coolant level is down.
    You can also check the brake reservoir to see if the master cylinder is leaking, but a leaking master cylinder usually drips into the vacuum booster and fills it first (and you notice a problem with the brakes).
  5. Member kennybo's Avatar
    May 31st, 2004
    Huntersville, NC
    2000 GTI VR6, 1997 GTI VR6, 1995 Jetta 2.0
    05-17-2012 02:41 PM #5
    I'm thinking coolant too since the location along the firewall where the send & return coolant hoses feed the heater core is pretty much in alignment with the gas pedal.
  6. Member Sallad's Avatar
    Aug 29th, 2004
    Kelowna, BC
    '94 Jetta 2.0 16v
    05-17-2012 05:07 PM #6
    Taste it...
    ...if it's sweet, it's coolant, if you die, it's brake fluid.
    Pro Patria
    Making power, 4 valves at a time.
    MkIII 16v Club.
    Mar 23rd, 2008
    N/A
    N/A
    05-17-2012 05:16 PM #7
    Quote Originally Posted by Sallad View Post
    Taste it...
    Drinking coolant or brake fluid will kill you.
    NOT SO FUNNY, SOME PEOPLE DON'T KNOW.
  8. Member The Hamburglar.'s Avatar
    Jul 20th, 2008
    IN
    98 L132 Bench racer w/ a once pipe
    05-17-2012 06:58 PM #8
    Taste it...
    Hard Parked since 07
    BHC
    Quote Originally Posted by nemo1ner View Post
    Rimz is a ghetto term that should have raised a red flag.
  9. Member adam4490's Avatar
    Oct 19th, 2011
    Good ole PA
    2009 VW GTI 2.0T
    05-17-2012 07:01 PM #9
    Condensation
    my phone
    girls,cars and beer
    ride,love and drink it
  10. Member builtvw's Avatar
    Sep 19th, 2009
    coopersburg
    windsor 2.0, ginster 1.8t
    05-17-2012 08:39 PM #10
    Quote Originally Posted by germancarnut51 View Post
    agreed, but i dont think anyone is dumb enough to drink chemicals.
    Quote Originally Posted by ZACHER3tuning View Post
    only on vortex, could this turn into a argument.
    http://forums.vwvortex.com/showthrea...Project-molest
