Results 1 to 8 of 8
Thread: Help: Bogging idle on Digi II 1.8 8v
  1. n00b
    May 17th, 2012
    Calgary
    1991 Jetta coupe TD, 1992 GTI 8v
    05-17-2012 04:48 AM #1
    Hey all, looking for some help with my stock 92 GTI 8v. Car runs great and pulls strong and cold starts very well. The only problem is after it warms up a bit and you let it idle, just coming off the throttle it finds a perfect spot to idle at for a second or two (850-890RPM) then it bogs down to a somewhat rough idle around 800RPM and develops a slight hesitation or missing that seems to be in all cylinders when it bogs down but it runs very smooth in all other areas of the rev band. Its not too bad and Ive never had it stall out but its bugging me. Ive gone through and checked the timing and set the idle by the Bentley manual, replaced the idle screw O-ring, replaced the exhaust which was leaking. I cant find a vacuum leak anywhere. Also tried cleaning the ISV and put some injector cleaner through it with no luck. Anyone else have this problem?
  2. n00b
    May 17th, 2012
    Calgary
    05-29-2012 06:17 AM #2
    Replaced the coolant temp sensor with no change...
  3. Junior Member
    Oct 16th, 2007
    North Carolina
    1960 VW Single cab
    06-04-2012 05:43 PM #3
    Check the intake manifold, Is it cold to the touch when this happens? If so then the fuel pressure regulator is leaking fuel into the vacuum port. Pull the vacuum hose off and look for any fuel in the line.
    Jim
    Wagenhaus
  4. n00b
    May 17th, 2012
    Calgary
    06-06-2012 06:33 AM #4
    Thanks! That sounds like a good idea, I'll check it out tomorrow. I have a new 02 sensor on the way..."shotgun troubleshooting"
  5. n00b
    May 17th, 2012
    Calgary
    06-06-2012 06:36 AM #5
    New fuel filter and cleaned the grounds too. No improvment.
  6. n00b
    May 17th, 2012
    Calgary
    06-12-2012 02:03 AM #6
    Fuel pressure regulator was good and changed the o2 sensor and still no change. Starting to think its the isv. It's buzzing as it should but if you unplug and plug it back in the idle doesn't change at all. I've already tried cleaning it.
  7. n00b
    May 17th, 2012
    Calgary
    08-19-2012 11:39 PM #7
    Changed the ISV with no change to the idle
    Nov 17th, 2001
    Northern Wisconsin
    08-20-2012 11:06 PM #8
    I know that you have checked for vacuum leaks but the issue still sounds like a minor vacuum leak that sucks enough air at idle to make a difference in the idle. There are a bunch of places to check. The dipstick funnel, the ISV elbow into the intake manifold, the gasket for the round PCV Valve on the cylinder head cover, the vacuum system check valves to include the vacuum switch for climate control, the injector sealing "O" rings, intake manifold gaskets, etc.
    Having said that I also think that I would check the intake air meter, ring out the wiring to the ECU and finally the ECU itself by replacing it. The air meter is easy to check with a multimeter. There is also a temp sensor in the air meter. A decent manual will tell you how to check the wiring and the air flow meter.
    One other quick check that you have not mentioned is the idle switch on the throttle body. Move the throttle and listen for a faint click. You can also check the switch with a multimeter.
    One time it took me a year to find a warm idle issue on a car I owned. Turned out to be a corroded wire for the O2 sensor -- there was a tiny hole in the insulation on the O2 sensor wire which allowed water into the wire and the wire had corroded internal to the insulation. The corosion gave a less than pristine connection. FR
