Results 1 to 3 of 3
Thread: Engine Mount
  1. 05-17-2012 11:33 AM #1
    Has anyone come Across a good video or such explaining the replacement of Engine Mounts. I have a 2004 Passat TDI. Any help would be greatly appreciated!!
    Aug 2nd, 2010
    Athens, Ohio
    99 Jetta TDI, 00 Golf 2.0, 81 Rabbit pickup vr6, 02 TDI jetta
    05-18-2012 09:37 AM #2
    look for a diy for the 1.8t, its the same, but you wont notice any improvement from new engine mounts. they feel the same with new/old mounts. probably because they are all slush boxes.
    Athens Euroworks, http://www.athenseuroworks.com/
    Owner, mechanic, diagnostician, parts specialist, receptionist, custodian, you get the point
  3. Member bengone1's Avatar
    Jun 17th, 2003
    Newport News VA
    2001 allroad 6sp, 98 GTi TDi, Caddy TDi to be
    05-20-2012 07:34 PM #3
    Are the mounts leaking fluid leaving red stains on the brackets? New mounts on diesels do make a difference if your old ones are bad and they usually are after 100k+ miles.
    Do not rule out driveshafts if you are getting a bad shake at idle.
    You just need to use a block of wood to jack engine carefully enough to slide the mounts out. Straight forward job easily done on jack stands. Loosen bolts before raising engine. Change one mount at a time.
    Malone tuning services available- Contact Ben at MaloneTuningVA@gmail.com
    http://malonetuning.com
    MK4, B5, B5.5 remote window control recoding available and VCDS MK5/6. SKC retrieval, Cluster matching, IMMO programming/delete.
