Results 1 to 17 of 17
Thread: Need help fast air ride problem ob2 compressor
  1. Member juldupp's Avatar
    Feb 12th, 2011
    Quebec (canada)
    bagged mk6 2.5
    05-17-2012 10:21 PM #1
    I have an air zenith ob2, i used the 12awg wire that came with the v2 kit but it looks like its not good enough. Keep burning fuses. (30amp)
    So should i simply just use a <30 amp fuse (was told its not recommended for a 12awg my wire could melt) OR change it for a 6awg/8awg wire as reccomended bu air zenith?
    I'd like a response as fast as possible, running on my 50 psi left on my tank atm loll
    Thanks!!
    Apr 12th, 2007
    Phoenixville PA
    07 baggedwagon, now 12 GLI
    05-17-2012 10:27 PM #2
    There is no way that should run on a 12 gauge wire. Go with a larger size wire, minimum 6 gauge. If I were you, I would run a 4gauge.
  3. Member juldupp's Avatar
    Feb 12th, 2011
    Quebec (canada)
    bagged mk6 2.5
    05-17-2012 10:46 PM #3
    Quote Originally Posted by fasttt600 View Post
    then why the v2 comes with a 12 awg wire? standard viair compressors are fine with this ?
  4. Member llllllll vr6 lllllll's Avatar
    Jul 10th, 2008
    Winchestertinfieldville
    2 MK6's. One with switches
    05-17-2012 11:35 PM #4
    Quote Originally Posted by juldupp View Post
    Viair usually runs with 8g, if you plan on keeping just the one compressor get the 8g or if you LAN on going 2 compressors eventually run a 4g.
    BAG RIDERS
  5. Member GREYTRACK's Avatar
    Mar 5th, 2007
    Rockland, Ny
    BAGGED 4DOOR (IG)-GREYTRACK
    05-17-2012 11:38 PM #5
    Quote Originally Posted by llllllll vr6 lllllll View Post
    This I run 4g with a dual set up
    BAG RIDERS / APRTUNED / Rat4Life / CCW
    Apr 12th, 2007
    Phoenixville PA
    05-18-2012 07:35 AM #6
    You might want to re-read your manual. I don't see anywhere that says use a 12gauge wire. They leave that section vague for a reason. People run all different set ups, which in turn draws more or less amps. It's your set up, you have to figure out what wire and fuse's to use. I don't mean to sound like a dick, just telling you do your homework before you burn your car up.
    Max amps on a 12 gauge wire = 20amps.
    Max draw on a OB2 = 35amps.(probably why your blowing 30amp fuses...)
    12 gauge wire + OB2 = car on fire!!!!
    This is deirect for the instructions:
    This compressor comes with pre-installed 80A relay with pre-wired relay socket. Connect
    your battery positive power wire to the Red wire on the relay socket. (Run minimum 6AWG
    wire for wire length runs more than 10 feet
    , and 8AWG wire for length shorter than 10 feet).
    Change that wire ASAP.
  7. Member juldupp's Avatar
    Feb 12th, 2011
    Quebec (canada)
    bagged mk6 2.5
    05-18-2012 08:01 AM #7
    Lol i didnt read that i needed a 12awg, its the wire that came with my v2 i said. Changing it for a 6g tonight, getting a thick one.
    My build thread here here
    Apr 12th, 2007
    Phoenixville PA
    05-18-2012 10:41 AM #8
    Good to here. you will most likely have to change that fuse as well
  9. Member juldupp's Avatar
    Feb 12th, 2011
    Quebec (canada)
    bagged mk6 2.5
    05-18-2012 03:42 PM #9
    That fuse in on the 12g wire
  10. Member juldupp's Avatar
    Feb 12th, 2011
    Quebec (canada)
    bagged mk6 2.5
    05-18-2012 03:44 PM #10
    Do i need a fuse on my new wire? I think theres one on the 80a power supply im not sure
  11. Member juldupp's Avatar
    Feb 12th, 2011
    Quebec (canada)
    bagged mk6 2.5
    05-19-2012 06:52 PM #11
    Done! One last queation, is it normal that my compressor is starting each time i air up? Its setted for 110-160 psi its not supposed
  12. Member llllllll vr6 lllllll's Avatar
    Jul 10th, 2008
    05-20-2012 10:31 AM #12
    All depends on your ride height, tank size and what your pressure switch is set to. You might have a leak somewhere.
    BAG RIDERS
  13. Member juldupp's Avatar
    Feb 12th, 2011
    Quebec (canada)
    bagged mk6 2.5
    05-20-2012 10:36 PM #13
    Yeah i have a leak on my back right bag, it might be because of this, its annoying it start everytime i air up even if its over what i setted it up to start
  14. Member llllllll vr6 lllllll's Avatar
    Jul 10th, 2008
    05-21-2012 10:40 PM #14
    Spray soapy water on your fittingsto find the leaks
    BAG RIDERS
  15. Member juldupp's Avatar
    Feb 12th, 2011
    Quebec (canada)
    bagged mk6 2.5
    05-23-2012 07:52 AM #15
    Oh thanks for the tip!
  16. Member juldupp's Avatar
    Feb 12th, 2011
    Quebec (canada)
    bagged mk6 2.5
    05-31-2012 07:49 AM #16
    Sometimes i get a comm error on my v2, how can i fix this?
