Results 1 to 5 of 5
Thread: MK4 2.0 it takes two secs or so to engage the D gear
  1. Junior Member Vitamin T's Avatar
    Feb 2nd, 2004
    Costa Rica
    2002 Jetta 1.8T
    05-17-2012 11:36 PM #1
    Hello Guys,
    I have a Jetta 2006 MK4 2.0 with only 32,000 KMS (Automatic Transmission)
    Only on the first engine start of the day in the morning when I am in my parking and I shift from P to D it takes like 2 seconds o so to engage.
    For the rest of the day, when I going to lunch or what ever when I shift from P to D it engage inmediately without any delay.
    The car drive normally without any issue, I can fill the transmission change gears very smooth, down shift normally, no strange sounds........... Its just that issue every day in the morning.
    I took the car to a mechanic in order that he check the Trans Oil Level and it was OK.
    Do I need to worry??? Any Advise?
    THX
  2. Member CoolAirVw's Avatar
    Mar 8th, 2007
    Kansas City Missouri
    85 Jetta TD sold 2001 Jetta Tdi, 2000 Jetta Tdi
    05-18-2012 03:49 PM #2
    This is common and not necessarily a problem. Just live with it. (pressure loss to a clutch pack probably)
    If it gets so bad that you have to "give it a little gas" to get it to "bump" into gear then you'll need to start budgeting for a trans.
    Auto trans fluid change or flush will not make a trans fail. Stop spreading the wives tale/urban myth.
    ASE Master Certified Technician with L1 Advanced Diagnostic Rating Recently passed ASE certification for Light Diesel repair.
    www.KansasCityTdi.com
    Jan 4th, 2007
    MA
    2004 Jetta GLS 1.8T
    05-25-2012 10:18 AM #3
    Really? can you just change some part to fix it? I'm having this kind of problem only on cold mornings too.
    Quote Originally Posted by CoolAirVw View Post
  4. Member CoolAirVw's Avatar
    Mar 8th, 2007
    05-25-2012 05:42 PM #4
    Quote Originally Posted by radlynx View Post
    there are dozens of parts that seal the pressure. Which one you gonna change?
    If you were able to Id the part, lets say.. "k1 piston" then you would have to pull the trans, disassemble it, reassemble it correctly, then hope it worked. Point being... live with it as long as you can then budget for a rebuild or replacement.
    Jan 4th, 2007
    MA
    2004 Jetta GLS 1.8T
    05-29-2012 09:31 AM #5
    ok. thanks.
