VWVortex.com - Turtledub's Armageddon Build
    Page 1 of 8 12345 ... LastLast
    Results 1 to 25 of 190
    Thread: Turtledub's Armageddon Build
    1. Member turtledub's Avatar
      May 10th, 2006
      1990 20v Corrado(soon), 2001 Outback 250k strong!
      05-18-2012 01:25 PM #1
      So the end of 2012 is approaching. I figure I will need something with style to welcome our alien overlords in. This thread will chronicle my journey to build a "not bad", somewhat fast, somewhat reliable Corrado before Doomsday. I need a getaway car when the looting begins.
      I have said however that when I finially get this car finished it would mark the end of the world.
      Will this be the build thread of the year? Eh, maybe.
      Will it be filled with crappy cell phone pics? You know it.
      Will this car be the harbringer of death? Yes. Why? Because 1.8t.
      Women are gentle and soft, but they hit things...
      20v AEB Corrado Build thread.
      Parting a B4 ABA Passat?
    2. Member Tk2g60's Avatar
      Aug 26th, 2010
      Eastern PA
      1993 vr6 Corrado, 2000 vr6 Jetta(sold) 1991 g60(sold) 93 BMW 318ti(sold)
      05-18-2012 07:15 PM #2
      If you are preparing for doomsday, I would imagine you will need to make this thing bulletproof. Covered with steel plates, machine guns, and rocket launchers in every angle. like a Mad Max Corrado I'm in! I too was thinking what I would do with my Corrado come the day the world ends
      Wtb: fmic and piping vr6 Corrado specific please PM me
      WTB: Estyles Headers
      My build thread-->The Gift and The Curse
      If you live in PA and own a Corrado click here-> Pennsylvania's Corrado's
      Shop Spoonfed Tuning for your Corrado essentials
    3. Member ewillard's Avatar
      Apr 21st, 2007
      Lewisberry PA
      1990 16vt corrado
      05-18-2012 11:04 PM #3
      Quote Originally Posted by VR6W8 View Post
      Is it a sickness? Yeah, I think so. Why I still tinker with it, and still own it, I have no idea really.
      my build thread pic heavy http://forums.vwvortex.com/showthrea...k-build-therad click for corrado bently PDFhttp://www.4shared.com/zip/eVgLVViZ/corrado.html
    4. Member 6BangSneezer's Avatar
      Mar 3rd, 2011
      Coral Springs SFL
      1992 Corrado VRT, HEMI
      05-19-2012 12:04 AM #4
      Yeeeeeea if the world is ending ill be using something SLIGHTLY more reliable... Like perhaps something Korean with 300k+ on the odo
    5. Member turtledub's Avatar
      May 10th, 2006
      05-19-2012 01:14 PM #5
      Nice. This means more build time.
      So far the plans are as follows.
      20v AEB from a 99 Passat. 90k on the clock according to the PO. When the engine was taken out of the car it was unbolted and the harness was hacked off with a pair of bolt cutters. All the hosed were also cut. Luckily all most of the connectors and sensors are in place.
      Uncut AEB harness.
      T3 from a previous build.
      38mm Turbonetics wastegate.
      2.0t coil conversion.
      Large FMIC.
      Snow Performance water meth.
      AGU manifold(straight out of Europe)
      Manual timing belt tensioner
      Forge splitter valve
    6. Member turtledub's Avatar
      May 10th, 2006
      05-22-2012 07:16 AM #6
      Anyone have any thoughts on a manual timing belt tensioner? IE has a nice set up for the 058 block. Bahn Brenner also has one but it is just the tensioner and the stud. I ham hoping to order today or tomorrow.
    7. Member sdezego's Avatar
      Apr 23rd, 2004
      Hurricane Central FL
      '90 Corrado | '62 Harley Panhead
      05-22-2012 10:50 AM #7
      The problem with the manual tensioner is not the tensioner itself, it is the corresponding belt due to dimeter diffs. The AEB used two differnt belts. The early with used a horrid tensioner setup that was prone to failure and used a (152T belt). The Revised hydro tensioner similar to later 20vs used a 153T. The IE setup accounts for this belt length difference for the Later 20vs and uses that extra roller bracket.
      You can use the 16v manual Tensioner on the 058 block and AEB head. You will need to flip the roller and use a Shim behind it along with the proper Stud due to mounting depth diffs on the head. I am not certain on what tooth belt you would need for this setup, but my guess is that either the 152 or 153T would work. YOU NEED to VERITY THIS though
      Another option is using the later AWP Roller, removing teh hydro tensioner bracket and placing a washer between the bolt and roller to make the tensioner fixed when you tighten. THis Roller has a slightly larger diameter than the 9a though and would most definitely require the 153T an would hopefully be long enough. My gut says yes, but you need to verify.
      I used both setups on the AEB and other 20v heads for various reasons. All were on the ABA tall block, which is why I disclaim knowing the exact belt lengths. I seem to recall though that 153t was perfect for 20v on G60 Block (same deck height as AEB) using the 9a roller.
      Finally, the 9a is MUCH cheaper than the AWP route, but just so you can see what I mean, here is how you would make the AWP work.
      Build: Project sc2020
      My G60 now on MS3 | 4Cyl Torque Plate Rental | 02M Mounts
    8. Member turtledub's Avatar
      May 10th, 2006
      05-22-2012 11:10 AM #8
      [QUOTE=sdezego;77488882]The problem with the manual tensioner is not the tensioner itself, it is the corresponding belt due to dimeter diffs. The AEB used two differnt belts. The early with used a horrid tensioner setup that was prone to failure and used a (152T belt). The Revised hydro tensioner similar to later 20vs used a 153T. The IE setup accounts for this belt length difference for the Later 20vs and uses that extra roller bracket.
    9. Member sdezego's Avatar
      Apr 23rd, 2004
      05-22-2012 11:17 AM #9
      Quote Originally Posted by turtledub View Post
      This is going to be an AEB 1.8t swap.
      Right, but what I am saying is that the AEB and G60 are both 058 blocks and both have the same Block Deck height and would use the same timing belt lengths when using custom tensioner options as well as the Crank Serp Pulley.
    10. Member turtledub's Avatar
      May 10th, 2006
      05-22-2012 02:31 PM #10
      I think that I am going to go with the Integrated Engineering timing belt set up. It seems to have a bit more crank pulley wrap.
      Its also red.
    11. Member sdezego's Avatar
      Apr 23rd, 2004
      05-22-2012 02:37 PM #11
      haha, nice. I don't think you can go wrong either way. Extra wrap is beneficial on the 06a blocks where it is also driving a waterpump. Not needed on the 058 as the 16v and other engines have proved for years.
      But... you have a point. Anodized AL sure looks nice
    12. Member turtledub's Avatar
      May 10th, 2006
      05-22-2012 03:06 PM #12
      That and I am also picking up their FSI coil conversion adapter plates so I can use my 2.0t coils. I figure I might as well buy most of the stuff from one place.
      Hopefully I can get back in the garage on wednesday. I want to start tearing the AEB down to get some things powder coated or painted. Motor mount brackets, valve cover, AGU manifold, and the occasional coolant line. Idealy I would like to get them all powdercoated but if the cost turns out to be crazy I will go with a high temp paint. I think a wrinkle black would look nice and OEM-ish. I did my previous valve cover in the wrinkle and I really liked it.
    13. Member VR6 EDM's Avatar
      May 10th, 2010
      Boulder, CO
      1990 purple G60 + 1992 black VR + 93 black VR
      05-23-2012 02:41 AM #13
      haha! nice... do you have some more publicly noted trolls that can trump this? Im really interested in the videos that have more views so it can be supported and funded by Wikipedia's urban dictionary!, ur arguement is invalid, and I dont have anything to surpass ur knowledge of google searching so there is, and never will be an answer to your technical and scholarly findings!
      CORRADO LANYARDS CAN BE BOUGHT HERE!...
      http://www.ebay.com/itm/171244440438...84.m1555.l2649
    14. Member
      Sep 11th, 2009
      MN
      1990 Corrado AWP 20v 1.8T
      05-23-2012 03:15 AM #14
      funny, I am building an AWP 1.8T Corrado and am aiming to have it done before dooms day
      it's not that I can't do it, it's that I don't know how yet...
    15. Member turtledub's Avatar
      May 10th, 2006
      05-23-2012 07:30 AM #15
      Quote Originally Posted by 2OVT View Post
      It is a race then!
      I have been secretly watching your thread like a creeper. You will most likely get done before me though. I still have a rocker to weld up(if you read this and are close and can weld and want to help, by all means) and then paint. The body work and paint are going to take the most time.
      On another note. I am probably going to do the 9a manual tensioner. Just from a cost stand point. I just cannot justify the extra coin when I can spend that elsewhere.
    16. Member turtledub's Avatar
      May 10th, 2006
      05-24-2012 07:38 AM #16
      No work was done last night.
    17. Member turtledub's Avatar
      May 10th, 2006
      05-28-2012 09:17 AM #17
      Spent about half an hour in the garage. I pulled the valve cover off the AEB and there was no sludge. This was pretty exciting.
    18. Member turtledub's Avatar
      May 10th, 2006
      06-05-2012 07:33 PM #18
      Valve cover is cleaned up. I am getting ready to paint it. Work on this is much slower than I hoped. I also made an order with IE. While mocking things up I noticed that the AGU manifold is not compatible with the AEB fuel rail. A quick search and I found a transverse rail in the classifieds. Hoping to get all the parts painted by the end of the week.
    19. Member sdezego's Avatar
      Apr 23rd, 2004
      06-05-2012 11:18 PM #19
      What injectors are you going to run? The AEB Ev1 style? If so, you are cool with the transverse rail. If you are wanting to run the EV6/12 shorter style, you will need to make modifications to the intake like I did or get creative.
    20. Member turtledub's Avatar
      May 10th, 2006
      06-06-2012 08:33 AM #20
      Quote Originally Posted by sdezego View Post
      Right now I am keeping the stock AEB ones. This will be running on a stock ecu so I am trying to keep things as close to stock as I can. I want to get it running before I start to add more power by getting the ECU chipped.
    21. Member sdezego's Avatar
      Apr 23rd, 2004
      06-06-2012 10:12 AM #21
      ...I want to get it running before I start to add more power by getting the ECU chipped.
      Outstanding idea
      Did you get the AGU throttle Cable bracket too? I made one, but after I got the mockup set, I am not sure it will clear the hood on the ABA tall block.
    22. Member turtledub's Avatar
      May 10th, 2006
      06-06-2012 10:20 AM #22
      Outstanding idea
      I did get the throttle body cable bracket. I am also a little concerned with the hood clearance because I have a G60 hood.
    23. Member turtledub's Avatar
      May 10th, 2006
      06-07-2012 11:56 AM #23
      Last night I got the intake manifold and the rear motor mount bracket painted. I hope they turned out because I used a wrinkle paint.
    24. Member
      Sep 11th, 2009
      MN
      06-07-2012 11:59 AM #24
      It is a race then!
      Where are you located? I'd love to help if you're close but odds are you aren't...I'm in Minnesota, where there are hardly any Corrados.
      What are you doing for managment, OE or standalone?
      oh and just noticed your AEB has 90K on the clock...my AWP has 89,098 exactly
      good luck friend, hopefully we can be some use to one another.
      ps: take lots of pics
    25. Member turtledub's Avatar
      May 10th, 2006
      06-07-2012 12:38 PM #25
      I am in PA. Last night I did plan to paint the valve cover but it had a crack in it around one of the bolts holes that hold it on. Now I need a new one. Hopefully I can find one soon. Also I hope my Integrated order shows up soon.
      Next step is to pull off the oil pan to take a peek. It will be swapped out with a Shrick pan. I am waiting for a new oil pick up tube so I can use the newer pan. I will also pull off the timing belt and check to see if I have a step on or step off head. This will let me know what manual timing belt tensioner to go with.
