View Poll Results: KW Street Comfort Coilovers vs H&R Street Performance Coilovers
Voters
6. You may not vote on this poll
  • H&R Street Performance Coilovers
    2 33.33%
  • KW Street Comfort Coilovers
    4 66.67%
Results 1 to 25 of 25
Thread: H&R Street Performance vs KW Street Comfort Coilover thread
  1. 05-18-2012 01:42 PM #1
    So I think it is time to drop the Passat. H&R Street Performance Coilovers vs KW Street Comfort Coilovers?
    Right now H&R is on back order, but KW is in stock. KW is about $300 more and free shipping. I am looking to put coilovers on because I was the car to be more responsive and handle better but I don't want to get shaken up all day long. I have a tow hitch so I am not looking to drop it on the floor either. I drive 80 miles every day and I have already done one mod that didn't get the wife approval and it is starting to lose my approval so I don't want to add another one to that one. Any help would be greatly appreciated and in the end I will post photos once I actually install it.
    Below is a little about each one.
    H&R Street Performance Coilover Kit
    Unrivaled comfort and performance. Average lowering of 1.25"-2.0"F 1.25"-2.5"R
    H&R suspension components are synonymous with quality. Since the inception of H&R in the late 1970s, they have been making some of the highest quality suspension components available. With a need for an improved suspension in the automotive aftermarket, H&R essentially created the modern-day coilover that we are all used to. Not only concentrated on “stance,” H&R considered high quality materials and ride comfort extremely important.
    Bring some of that German engineering to your vehicle with a set of H&R street performance coilovers. With the adjustability of ride height, the fully threaded, custom valved suspension system will offer high performance with superb ride comfort and handling. Progressive rate springs both front and rear assure that no matter what height you have your vehicle set at, your ride will be great. By lowering the vehicle's center of gravity, less body roll will be experienced during hard cornering with a more balanced vehicle weight.
    H&R has dedicated almost four decades to the suspension industry and it definitely shines through in the end product. Their teams of engineers and designers have consistently produced products obtaining the coveted TUV & ISO certification for safety and quality.
    100% German made, the line of H&R coilovers is the original aftermarket suspension, but still one of the best.
    VS
    KW street comfort – No more hard times!
    Your sport suspension kit is too hard for you? Do you want a sportive,dynamic suspension with remaining comfort? With street comfort suspension KW offers you the solution, you can create that sportive look while keeping as much comfort as possible. Long trips on the highway will be a pleasure; fun can be had on county roads.
    KW street comfort – The most individual sport suspension with maximum comfort
    With the individual height adjustable KW street comfort coilover kit a lowering of 10-40 mm can be realised, depending on the vehicle. This way the customer has the flexibility to improve the look, with consideration of bigger wheels and tyres. At the same time the lowering has a positive effect on the driving dynamics and road contact. With discreet but effective lowering more spring travel will be left to combine a comfortable spring with harmonic damper, this way the best driving comfort is guaranteed. With this product KW offers the perfect compromise of driving dynamic and driving comfort.
    •Maximum driving comfort for a perfect performance and more driving pleasure
    •Guarantees more comfort, flexibility and sportive as regular OE sport suspensions
    •Comfortable adjustment
    •Better handling due to less body roll
    •With TÜV tested adjustment range for a individual lowering of 10 to 40 mm (.39 inch-1.5 inch)
    •Trapezoid thread for a easy height adjustability
    •High quality damper components for a long durability
    •Adjustable rebound damping
    •Complete delivery content inclusive detailed documentation for a easy use
    Current: 2012 VW Passat TDI SEL Premium
    Previous: '07 VW GTI 2.0T, '07 BMW K1200LT, '00 VW Golf 1.8T (4DRGTI), '92 GTI 2.0 16V, '04(2) Nissan Altima, '83 Rabbit GTI, '85 Golf GTI, '86 cabrio, '91 GTI 2.0 16V, '93 Passat VR6 and a couple others that I won't mention.
    My 2012 Passat TDI SEL Premium Fuelly Record
  2. 05-18-2012 02:45 PM #2
    Anyone know about camber kits or adjustments, and if that is needed with either of these set ups?
  3. Member cheapa55TDI's Avatar
    Sep 30th, 2011
    2012 Passat TDI SE
    05-18-2012 06:48 PM #3
    I'm biased towards KW since I have the V3 installed in my car. I still want to lower it more but haven't had time. I'm pretty sure you don't have to adjust camber and I'm not even sure if you can (I don't know for sure).
  4. 05-18-2012 07:01 PM #4
    Quote Originally Posted by cheapa55TDI View Post
    Can you comment on the ride quality? even if just stock to KW, have you messed with any of the settings and how low did you take it?
  5. Member cheapa55TDI's Avatar
    Sep 30th, 2011
    2012 Passat TDI SE
    05-18-2012 07:06 PM #5
    I've done 0 adjustments so far. The ride quality was one reason I didn't want to buy the Passat. Coming from 2 BMWs with sports suspension, I really didn't want to give that up. That's the main reason I got the V3. I wanted to be able to adjust to my liking. Fortunately after the install the ride quality was excellent, not too bumpy but much tighter than stock. I think this is as close to sports suspension on a bmw that I was able to get. But I haven't tried adjusting anything. Maybe this summer if I have time, I'll lower it another 1/4-1/2". Anyways, I couldn't be happier. I think everyone who has lowered their Passat here with any suspension, springs or coilovers, have been happy with it. So I want to say you can't go wrong with either one.
  6. 05-18-2012 07:10 PM #6
    Quote Originally Posted by coffeemade View Post
    VS
    Did you ever get the front swaybar installed and if so what did it do for the handling?
  7. 05-18-2012 07:12 PM #7
    Quote Originally Posted by DGC View Post
    Nope still haven't had time. In the next couple weeks I plan to do the coils and the front sway bar.
  8. 05-19-2012 11:36 AM #8
    Have the KW SC coilovers on my 20th GTi and can say the product delivers as marketed.
  9. 05-19-2012 12:03 PM #9
    Quote Originally Posted by Imola Yellow GTi View Post
    I think I am going to go with KW but I am not sure KW SC or KW V3?
  10. Member
    Apr 2nd, 2012
    San Jose
    2012 Passat SEL 3.6 // 2010 Chevy Equinox 2LT
    05-19-2012 12:55 PM #10
    Question: is this a reason for getting coilovers vs. springs? I've only done some research on this, but the vast majority of people who get coilovers installed never adjust them and you typically need re-alignment done if you do. Just wanted to throw it out there if springs would possibly do for your needs.
  11. Member cheapa55TDI's Avatar
    Sep 30th, 2011
    2012 Passat TDI SE
    05-19-2012 12:56 PM #11
    I don't think you can go wrong with either one.
  12. 05-19-2012 01:02 PM #12
    Quote Originally Posted by writeb View Post
    Springs are not an option for me because I am sure the tow hitch would scrap. I remember the last set of coilovers I purchased and you are right, I installed them and messed with them right after but never again. While in my mind I think I want to adjust them the reality is during the first week I would adjust them, but after that....I bet I will never touch it as long as they are smooth and comfortable. Just debating if $300 is worth my peace of mind to make sure I got the best product I could for my B7.
  13. Member
    Jan 30th, 2006
    2012 Passat TDI
    05-19-2012 03:17 PM #13
    You can also use H&R 36258-1 kit which is the Street Performance SS with damping adjustment on stainless shcok bodies, thats what I just installed on my car, so far so good, there is a noticable difference, much firmer than stock but not to the point of being annoying, just got them on last night so I need more time behind the wheel
  14. 05-20-2012 09:06 PM #14
    Going to order KW Street Comfort because I am not looking for a drastic drop but I want it to ride better. I kept hearing over the past few days KW SC's are really comfortable and supportive.
  15. Member
    Jan 24th, 2012
    Phoenix, AZ
    2012 Passat V6 SE
    05-21-2012 01:41 PM #15
    do they have KW for the B7 yet? or are you gonna order for a dif year/make/model?
  16. 05-21-2012 01:50 PM #16
    Quote Originally Posted by mtoger View Post
    KW Suspension makes them for 2012 Passat's. At this point I am just waiting to hear back from a company that says their price on the KW's can't be beat. I will update once I find out.
  17. Member
    Apr 2nd, 2012
    San Jose
    05-26-2012 01:56 AM #17
    Any word?
  18. 05-26-2012 07:07 AM #18
    Any word?
    Ordered KW Street Comfort Coilovers from Redline and they do have the best deal no question, but you must call the to get that deal. Now just waiting on shipping confirmation
  19. Member
    Jan 24th, 2012
    Phoenix, AZ
    2012 Passat V6 SE
    05-29-2012 02:10 PM #19
    whats the part number for the KW coilovers?
  20. 05-29-2012 02:59 PM #20
    2012 VW Passat TDI ( I don't think motor matters) KW Street Comfort Coilovers part number is 18080110
    I am still waiting on a shipping update for mine...
  21. 06-13-2012 09:16 PM #21
    Got the KW Street Comfort Coilovers and H&R Front sway bar installed today. Set the dampers to 9 as recommended in the installation guide. The front is set to the lowest thread and the rear is installed WITHOUT the coilover adjustment to obtain the most drop which wasn't much from stock. This coilover set up is awesome, very responsive but not bouncy. I was smiling all the down the road because this car keeps getting closer and closer to my GTI.
    This is my Google Plus Gallery for the Coilover and front sway bar install.
  22. 06-13-2012 10:33 PM #22
    I got the H&R Coilovers on my B7 2.5 SE and couldn't be happier. They ride a little bit firmer than stock with zero bounce while being on the lowest setting. Anyone in Northern NJ who wants to try to feel the setup for themselves PM me and I'll take you for a ride. I'm sure you won't be disappointed.
  23. 06-14-2012 06:40 AM #23
    Quote Originally Posted by 2012psst View Post
    No photo think someone is lying j/k
    Waiting on pictures
  24. Junior Member
    May 16th, 2011
    Raleigh, NC
    2012 tdi se 6m, 2012 tdi se dsg
    06-14-2012 08:48 AM #24
    Were there any major install issues? I remember you mentioning having to remove the subframe for the front swaybar........the car looks just right. Any tire rubbing on bumps or potholes? Does ride quality suffer much?
  25. 06-14-2012 10:23 AM #25
    Quote Originally Posted by byrdman27615 View Post
    Well during the install we had it reversed on making it as low as possible, so the first time we set it down it was as high as it could be and extremely stiff but after lowering the front all the way down and removing the spring perches in the rear it was all good. Unless you have done a suspension install on the ground before or at home, I wouldn't attempt as having a real lift it still took about over 4 hours not including the front sway bar and alignment. It was a great time to install the front sway bar as everything was off and out of the way except for the sub frame and it would need an alignment since the sub frame would have to be moved.
    No rubbing at all, I try not to hit potholes. The ride quality is wonderful, it's like my 2007 GTI but even a tiny bit more responsive. My wife likes it a lot.
    Totally install took about 6-7 hours using a lift. This also includes the time it took to align the car, which due to the bigger sway bar made the technician have to lower the subframe to access a few of the bolts. I will post up alignment specs to show that I am in the green and for the first time since I owned this car it doesn't drift or track to one direction or another. It drives low straight and really a dream to drive now.
    This is the way the car should've been from stock.
