VWVortex.com - FS. INA Engineering STEEL Oil Pan for 1.8T
    Results 1 to 17 of 17
    Thread: FS. INA Engineering STEEL Oil Pan for 1.8T
    1. Member artur vel 2 hoot's Avatar
      Nov 25th, 2006
      Chicago - Schaumburg IL
      05-18-2012 07:09 PM #1
      This Pan is brand new , dont have inside baffling and space for oil level sensor .
      A must fot those who run low ;-)
      My asking price is $100 +shipping
      TTQ / 2.0T / EFR7670 / ..............
      New Stage Build : http://forums.vwvortex.com/showthrea...Audi-TTquattro
    2. Member artur vel 2 hoot's Avatar
      Nov 25th, 2006
      05-24-2012 12:50 AM #2
      TTT
    3. Member elgringogillao's Avatar
      Jun 1st, 2005
      New York, NY
      2012 Golf R
      05-26-2012 12:04 AM #3
      Does this fit the TT225 AMU motor?
    4. Member artur vel 2 hoot's Avatar
      Nov 25th, 2006
      05-26-2012 03:05 AM #4
      Yes and no
      It will fit but dot't have a spot for oil level sensor .
    5. Member 1fast2liter's Avatar
      Apr 3rd, 2005
      beaver dam WI
      2000 audi tt 180q
      05-30-2012 02:29 PM #5
      Will yhis work on a 2000 tt 180q
      Sent from my Motorola Electrify using Tapatalk 2
      infinity front and sides,votex rear,st coilovers,eurodyne tapp 1000cc tuned,hks ssq bov, pte 5857 pagparts turbo kit with 38mm tial wastegate. spec stage 3, custom intake, bbm fuel rail, billy boat 3in exhaust,ecs bleeder block,mbc,fmic,bfi mounts,cm flywheel,front mount interccoler, aeb head cat 3652 cams, scat rods je pistons super tech valves and springs.
    6. Member 1fast2liter's Avatar
      Apr 3rd, 2005
      beaver dam WI
      2000 audi tt 180q
      05-30-2012 02:36 PM #6
      And what is needed for install
    7. Member ejg3855's Avatar
      Sep 23rd, 2004
      Rochester, NY
      1993 UrS4
      05-30-2012 02:47 PM #7
      Quote Originally Posted by elgringogillao View Post
      Quote Originally Posted by artur vel 2 hoot View Post
      Yes and no
      Quote Originally Posted by 1fast2liter View Post
      read the thread.......
      CUSTOM TUNING - IMMO DEFEAT - AWD DYNO - FABRICATION - MACHINED/DESIGNED PARTS
      NOW OBD FLASHING MK6/MK7 2.0T
      BREAKOUTMOTORSPORTS
    8. Member 01ttgt28's Avatar
      Jun 23rd, 2009
      dartmouth ma
      audi tt gt3076r 01 aston martin db7 04 land rover disco 99rolls royce seraph
      05-30-2012 07:46 PM #8
      Quote Originally Posted by ejg3855 View Post
      Lol
      http://forums.vwvortex.com/showthrea...t-done-I-guess
      ^^^Big Turbo build lots of pics^^^
      Best shop for repair and custom workin ma
      http://www.wentworthmotorsports.com/
    9. Member 1fast2liter's Avatar
      Apr 3rd, 2005
      beaver dam WI
      2000 audi tt 180q
      05-30-2012 08:20 PM #9
      Thats why i am asking what it needs or how do i trick the sensor sence i cant put one in?
    10. Member 01ttgt28's Avatar
      Jun 23rd, 2009
      dartmouth ma
      05-30-2012 08:43 PM #10
      You would have to resistor it intergrated should have it but the bad would be if you crack the pan you would never
      Know that your leaking oil ???
    11. Member artur vel 2 hoot's Avatar
      Nov 25th, 2006
      05-30-2012 09:35 PM #11
      Or you can make space for sensor
      Thanks guys
    12. Member artur vel 2 hoot's Avatar
      Nov 25th, 2006
      06-17-2012 03:51 PM #12
      BUMP for new price ;-)
    13. Member elgringogillao's Avatar
      Jun 1st, 2005
      New York, NY
      2012 Golf R
      07-24-2012 09:35 PM #13
      Thanks guys
      Who did this one? Ina?
    14. Member artur vel 2 hoot's Avatar
      Nov 25th, 2006
      10-16-2012 01:18 AM #14
      BUMP For price reduction . Need it gone
    15. Member artur vel 2 hoot's Avatar
      Nov 25th, 2006
      10-20-2012 05:00 AM #15
      TTT
    16. Member artur vel 2 hoot's Avatar
      Nov 25th, 2006
      10-27-2012 04:02 PM #16
      BUMP
    17. Member 04VDubGLI's Avatar
      May 20th, 2005
      Pittsburgh, PA ish
      04.5 VW GLI 1.8T
      10-28-2012 11:11 PM #17
      Any reason this wouldn't work for a MK4? The factory plastic baffling and such would still work? What size is that return? male -10an?
