Results 1 to 3 of 3
Thread: help how to change spark plugs on my VW transpoter 1994 van
  1. 05-18-2012 10:57 PM #1
    can any one help pls trying to change spark plugs but not sure how to get access to the spark plugs looks difficult
  2. 05-19-2012 12:41 AM #2
    Nah it's a piece of cake.
    Remove two 10mm bolts each side of the radiator support.
    Lift up on the hood latch "loop" (the sort of oval shaped thing) and also work your hand under the lowest trim piece of the grille panel and as you're lifting up to pull the bottom outward a bit. The whole radiator support assembly will lift up and outward and sit on top of the bumper. (Yes it's designed to do this for servicing.)
    Now you have lots of spark plug access.
  3. 05-19-2012 10:58 PM #3
    Quote Originally Posted by gti_matt View Post
    GREAT thanks will give this a try wish me luck
