Page 1 of 4 1 2 3 4 LastLast
Results 1 to 35 of 137
Thread: Saving a Jetta
  1. Member Pat @ Pitt Soundworks's Avatar
    Nov 14th, 2008
    Pittsburgh
    05-19-2012 01:57 AM #1
    So my buddy had a jetta. He let his drunk friend move his car and at 5mph in a parking garage, somehow managed to run it in to a concrete barrier, totalling it. My buddy carried liability only, and got nothing for the car. It wasn't worth it to pull parts and scrap the body. I wanted out a car payment, so I traded him my 425whp saab for the wrecked jetta and some cash, and am now fixing it up.
    About this time last year, the car started out as a heavily molested 2.0l automatic semi-base model. Power windows were the only option, and poorly done plad headliner and door cards. First thing was to swap the 2.0 and auto out for a 5speed and 1.8t. Second, was to get rid of the plad, and put cloth door cards back in. Third, retrofit heated seats
    This is how I received the car:
    02 body, ~185k
    01 Aww 1.8t, 115k
    01 2.0L 02J tranny
    ls2 coils
    g60/vr6 clutch/flywheel
    kw v1 coils
    poly bushings all the way around
    uni 830 ecu
    siemens 830 injectors
    How the car will progress:
    fix body damage
    golf front end, r32 front bumper, r-style side skirts, vortex rear bumper
    built 2020 with hy35 turbo
    custom nubworks surge tank
    awic
    climatronic swap
    heated mirror/washer nozzles
    6spd quattro swap
    20th brakes, tt spindles & control arms
    and some other stuff
    Current list (as is):
    stock 1.8t longblock
    Custom turbo manifold
    Custom 3" downpipe to catless 2.5" exhaust
    Custom intake manifold
    Custom intercooler piping
    31x12x3 CXracing front mount
    Tial MVS wastegate
    Tial 50mm BOV
    LS2 truck ignition coils
    Siemens 830cc injectors
    Uni830 cc tune
    Hemi throttle body
    Bosch inline 044 + stock intank
    Audi Quattro TT DQB transmission and axles
    Clutchmasters FX400 clutch on stock DM flywheel
    Custom coolant res
    Mishimoto radiator
    20th front brakes
    Audi TT control arms and ball joints
    Audi TT drop spindles
    KW V1 coilovers
    On to body repair stuff:
    Tomorrow, I'll weld out the front end, get the 1.8t back in, and make sure everythings kosher. Then, I'll started on some other body repairs that need done.
    Harvesting parts from the tt:
    Transmissions:
  2. Member _MASH_'s Avatar
    May 25th, 2010
    san mateo to placerville WTF
    03,vw,jetta glx
    05-19-2012 02:17 AM #2
    5mph
    $0 car payment is a good feeling....
    4wd jetta with 6spd quattro swap... win
    VRSociety #100...
    " YOU CAN'T GET RICH IN LIFE IF YOU ONLY WORK THE DAYS YOU FEEL LIKE MAKING MONEY"- JULIAN GARCIA
  3. Member Pat @ Pitt Soundworks's Avatar
    Nov 14th, 2008
    Pittsburgh
    05-19-2012 09:33 AM #3
    That's what I was told. I don't believe it.
  4. Member 85vrcoupe's Avatar
    Oct 7th, 2002
    Central NJ
    TDI Wagon
    05-19-2012 09:42 AM #4
  5. Member 24ValveGLI's Avatar
    Mar 20th, 2005
    CT
    A never ending story // 2.8 // 2.9T
    05-19-2012 10:10 AM #5
    Do you have the TT fuel door and cap?
  6. Member dopesauce's Avatar
    Aug 21st, 2008
    MD
    24v gti
    05-19-2012 12:23 PM #6
    everything sounds good minus the golf front end
    but good luck with everything
  7. Member projektmk1vr6's Avatar
    Nov 11th, 2011
    Ironwood, MI
    81 diesel caddy, 83 rabbit gti, 00 gti vr6, 98 passat 1.8t, 95 passat glx
    05-19-2012 12:59 PM #7
    I'll be watching this.
    VRalliance #39
  8. Member JayDD007's Avatar
    Feb 27th, 2012
    Pottstown, PA
    12v jetta
    05-19-2012 01:31 PM #8
    Quote Originally Posted by dopesauce View Post
    ^^agreed but ill definitely be watching
  9. Member 2.slowerr's Avatar
    May 4th, 2011
    New Jersey
    '02 .:Retta Big Snail, '95 M3(Sold), '03 jetta 1.8t (sold), 2002 Golf 2.0 (sold)
    05-19-2012 01:36 PM #9
    .:R front end
    Gonzo Tuning represent.
    My newest on going disaster
  10. Member 02vwgolf's Avatar
    Oct 6th, 2009
    SE-PA
    02 vw golf gls
    05-19-2012 01:43 PM #10
    Projects are always fun Cant wait to see what you do with it because I have seen your work in the fabrication forum and you sir have skillls
  11. Member
    Apr 9th, 2012
    CT
    2004 VW GTI 1.8t
    05-19-2012 03:43 PM #11
    gnarly
  12. Member Symphony's Avatar
    Oct 16th, 2011
    Winnipeg, MB
    Blue Turd
    05-19-2012 03:53 PM #12
    I am giving you soooo much props for trading a fully finished Saab car for a f-ed up Jetta. It's gona take hard work but I know you'll make the car great.
    Good luck man.
    slam.poke.drop.tuck.dope
    raise.sunk.lift.gap.snow
  13. Member Pat @ Pitt Soundworks's Avatar
    Nov 14th, 2008
    Pittsburgh
    05-20-2012 02:27 AM #13
    Knowing the exact history of the car (I pretty much built it for my friend), all the extra parts that come with it, and all the spare stuff I have warehoused, the only problem is the bodywork. Speaking of which.....
    front end is welded on. I found out the divers side frame rail is also bent, so I'll be cutting and re-welding that tomorrow to line it back up right. It wasn't nearly as bad as the passengers side was, though.
    and I started mocking up the motor. I'm pulling off the k03 and putting on the hy35. I'll run it on a stock block, low boost, for the month or two until I finish building the real motor. I will be test-fitting the motor with a quattro tranny in the AM, and working on the new downpipe. I'm still going to drop the 02j back in for now, until I get a chance to pick up some TT axles, control arms, and 02m clutch.
  14. Member vortexpert.'s Avatar
    Sep 27th, 2009
    Avondale AZ
    98 GTI VR6 S/C, 98 GTI VR6, 02 2.0L 5 speed jetta wagon, Haro Mirra 540 Air
    05-20-2012 02:38 AM #14
  15. 05-20-2012 03:46 PM #15
  16. Member 1.8tCrayon's Avatar
    May 12th, 2011
    Central Minnesota
    Black Crayon
    05-20-2012 04:05 PM #16
    Promising thread.
  17. Member 03_uni-B's Avatar
    Sep 6th, 2005
    Lexington, Louisville, Bowling Green, KY
    bagged 03 24v, 65 Mustang Fastback
    05-20-2012 04:32 PM #17
    im down to see this
    1965 Mustang Fastback build
    BUY MY BBS'S
    Quote Originally Posted by Will@BagRiders View Post
    I really comes down to personal preference. Some like it fast, some like it slow.
  18. Member jolf43's Avatar
    May 10th, 2011
    East Cleveland
    Transgender Girl Car
    05-20-2012 05:00 PM #18
    damn, good work here. not a fan of golf front ends on jettas though.
    in for this
    -Dan
    Instagram: dan_berhent
  19. Member SirSmokeAlot's Avatar
    Jun 12th, 2010
    BFE Az
    2002 Jetta Wagon
    05-20-2012 05:08 PM #19
    in
    Quote Originally Posted by Mr. Rictus View Post
    How about no, Chauncey.
    I'd tell that ho to gtfo my roof.
    Lowengo - Car enthusiast blog
  20. Member
    Jul 18th, 2011
    Lawl, MA
    VR6
    05-20-2012 06:10 PM #20
    oooh
    wibbly wobbly... time-y wimey... stuff.
    VRalliance #73
  21. Member
    Jan 25th, 2010
    2005 **** Box GTI
    05-20-2012 06:26 PM #21
    I suppose I'll have to see what comes of this.
  22. Member agentmaddock's Avatar
    Apr 11th, 2007
    Huntington, WV
    02 TDI, 89 Cabby
    05-20-2012 06:46 PM #22
  23. Member Eeaazzzyyy's Avatar
    Sep 4th, 2011
    Passaic/Bergen NJ
    High-tech storage device, 03 Civic (daily douche)
    05-20-2012 07:22 PM #23
    Interested
    Quote Originally Posted by zero_x_soul View Post
    i only clicked on this thread because it said gay
  24. Member Easy Dubs It's Avatar
    Jan 22nd, 2012
    the 815, IL
    01' GTI Vr6
    05-20-2012 07:50 PM #24
    Lets see that Saab!
    VRalliance #136
    Quote Originally Posted by GtIVR6-RJ View Post
    I want to get the lsd because with the tires and what not about this there when I round about 10.
    What with the hills couldnt keep the who now.
  25. Member Pat @ Pitt Soundworks's Avatar
    Nov 14th, 2008
    Pittsburgh
    05-20-2012 10:05 PM #25
    Not much got done today. Didn't get started until almost 1pm. Calling it an early night at 9:30, instead of 2-3am like I've been doing. Most of the day was eaten up by relocating the drivers side frame rail to get everything to line up. It looks a little funny with the bay stripped out, but once it's painted and the bay is full, it'll be fine. I spent a bit of time pissing around with my friend on the engine, looking at coolant and vac lines, and doing minor stuff.
    Mocked up passenger side bay with surge tank. The small AC line for some reason needed a little massaging to get back in place. I need a replacement, unbroken, fuel/evap plastic conduit piece, that goes under the ac lines. Does anyone have one?
    Here's the rerouted coolant lines, ready for an external oil cooler. I stripped the wiring harness off to clean and fix it. The car has a PCV leak and everything's covered in ****.
    Welded up an oil return flange. Turns out I can still weld aluminum - I haven't done it in a few years. This is anodized to anodized, hence why it looks so unsmooth and unshiney. I don't know why the camera went crazy on the AN fitting....
    I would have had the turbo drain flange done too, but I can't seem to find where I put it this morning? I really want to get the engine back in and downpipe done tomorrow. That'll be the first thing I work on, for sure. That, and pick up a new saw for cutting pipe.
  26. Member Pat @ Pitt Soundworks's Avatar
    Nov 14th, 2008
    Pittsburgh
    05-22-2012 12:58 AM #26
    me guesta le boosta
    Can't start on the exhaust till tomorrow - had to order solar flux
  27. Member Kujiwara's Avatar
    Apr 13th, 2012
    Calgary,AB
    2003 GLI
    05-22-2012 01:09 AM #27
    MADD! but isnt the quattro on TTs are just 4motion?
    My little factory style GLI http://www.eurodrivers.ca/forums/sho...hina-with-Love
    VRalliance #259!!!
    Santa Monica/ Monte Carlo polishing tutorial http://forums.vwvortex.com/showthrea...Dummy-tutorial.
  28. Member Pat @ Pitt Soundworks's Avatar
    Nov 14th, 2008
    Pittsburgh
    05-22-2012 01:12 AM #28
    Correct. Sames as in the R32's
  29. Member eurolicious's Avatar
    May 13th, 2009
    Grocery Getter
    05-22-2012 01:18 AM #29
    Watching
    Sent from my toolbox using pliers and a screwdriver.
    Quote Originally Posted by dubvinci View Post
    liking/appreciating static is one thing, but to think its better that airride is a whole nuther story....better ride and handling while driving, more drivability, and looks better when parked....you might as well say its better to always have a hard on...id rather deflate it when im not using it and then pump it up when its time to go....lol...
  30. Member Pat @ Pitt Soundworks's Avatar
    Nov 14th, 2008
    Pittsburgh
    05-24-2012 10:20 PM #30
    Doing more werk.
  31. Member Pat @ Pitt Soundworks's Avatar
    Nov 14th, 2008
    Pittsburgh
    06-01-2012 03:35 PM #31
    Intercooler is due in today!
  32. Member Fastvolks's Avatar
    Apr 30th, 2003
    Somewhere in MA
    MK4 & MK6 GTI • 1986 Audi 4000CS Quattro
    06-01-2012 03:46 PM #32
  33. Member GliGirlDriver's Avatar
    Dec 15th, 2009
    NH
    2003 GLI VR6
    06-01-2012 03:54 PM #33
    Quote Originally Posted by _MASH_ View Post
    5mph
    x2 on $O car payment
    Quote Originally Posted by Pat @ Pitt Soundworks View Post
    And I believe it, my first 01 golf managed to be totaled by another car that crossed in front of me and I was going about 10-12mph since it was a small downtown area. Sucked, but if that didn't happen I wouldn't have gotten a fat check and my GTI
    in for progression..
    faceoff
    Quote Originally Posted by the mad conductor View Post
    So my new girlfriend doesn't give Dome?
    Quote Originally Posted by 1.8Tquattro View Post
    You spelled ex-girlfriend wrong.
  34. 06-01-2012 04:19 PM #34
    20/20
    4wd (assumed from 'quatrro trans')
  35. Member foundubbedriver's Avatar
    Jan 10th, 2006
    tempe, az.
    mkiv gti - rip. mkiv .:r32.
    06-01-2012 04:23 PM #35
    watching this..
    instagram @jcdubb3r - exklusiv motorsports.
