Results 71 to 105 of 137
Thread: Saving a Jetta
    Mar 23rd, 2007
    North Jersey
    2008 TR .:R32, 01 1.8T Jetta, 01 2.0 Jetta, 95 Ram 2500
    06-29-2012 10:00 PM #71
    hmmm this makes me wanna come back to the mk4 forums. don't worry it will be ruined by the next thread i go into. nice build so far. keep it up.
  2. Member Pat @ Pitt Soundworks's Avatar
    Nov 14th, 2008
    Pittsburgh
    07-03-2012 01:19 PM #72
    AVCR boost controller solenoid mounted
    Made the harness modular, and plugs in to the OE engine harness to receive power, throttle position, rpm, and vehicle speed. I didn't want to hardwire, in case I ever needed to pull harnesses.
    And spend 8 hours yesterday working on a TT engine harness. I figured I had to tear apart the existing harness to relocate the throttle body, map, iat, and other stuff, so I might as well just start on a different harness. I had to relocate a few sensors, relocate the coil pack plugs, convert coil packs to ls2 ends, fix some cracked insulation, de-electrical tape, and re-loom the whole thing.
    Another bad note, I found my tranny doesn't have 1 or 2. there's no clunking going in to gear. The gear selection fork must be broken. Thankfully I have another quattro 02m sitting here that I'll clean up this afternoon. I'll open this one up eventually to see what's going on inside it.
  3. 07-11-2012 06:04 PM #73
    Pat would you have any need for an entire a6 quattro parts car it has brand new st coils ill give you a killer deal.
  4. Member Pat @ Pitt Soundworks's Avatar
    Nov 14th, 2008
    Pittsburgh
    07-12-2012 01:01 AM #74
    tore down the turbo for the rebuild.
    And finally finished the intake manifold (plate is for IAT and vac ports
  5. Member 410CrewDubber's Avatar
    Oct 5th, 2010
    MD
    2001 Jetta Wolfsburg Edition
    07-12-2012 01:11 AM #75
    So far i like what i see!!
    _TheSteveGangBang11.21_ l RIP alrighty, im bored 2011_111 The mods may have taken you away, but you are in our hearts forever. Flickr www.facebook.com/RKSPhotography Instagram: @RKSchiller
    Quote Originally Posted by .Ant View Post
    When I was a kid my buddy took a sht in the garden of the prosecutors office. The police made him pick it up and bring it home with him.
  6. Member Pat @ Pitt Soundworks's Avatar
    Nov 14th, 2008
    Pittsburgh
    07-12-2012 01:11 AM #76
    Jetredd, perhaps. but only the driveshaft and rear end to sub in to my scirocco. Wanna pm me some info?
  7. Junior Member McHensley12's Avatar
    Jun 18th, 2012
    Maine
    2003 Volkswagen Jetta Wolfsburg Edition 1.8t
    07-12-2012 03:06 AM #77
    is all i can say
  8. Member JrJanowski's Avatar
    Sep 11th, 2011
    Dallas, TX
    05 GTI 1.8t
    07-12-2012 10:48 AM #78
    So Much Win in this thread.
    MY GTI BUILD/Instagram: JrJanowski<--Do It
    CCTuned-I Got the Hookup
  9. Member Pat @ Pitt Soundworks's Avatar
    Nov 14th, 2008
    Pittsburgh
    07-12-2012 01:43 PM #79
    Manifold, downpipe, and turbine housing vband adapter came back from the machine shop. Started adding wg port. I forgot to pick up more purge gas, so I'm there now.
  10. 07-12-2012 02:41 PM #80
    Great work, as always.
  11. Member Pat @ Pitt Soundworks's Avatar
    Nov 14th, 2008
    Pittsburgh
    07-14-2012 02:17 AM #81
    Did a lot today. Not as much as I wanted to. Built the fmic air dam. Finished the cold side piping. Pulled the motor in preperation for the clutch install. Split the tranny to confirm 1/2 gear selector fork rivit is damaged. Only have pictures of the first though.
    I need to shift the fmic 1/8th to the passenger side. Not a big deal. My buddy, Buddy, came over and said "not sure if rice, or functional". I said hold on, threw the bumper on. Then he said "Ah, most definitely functional"
    2am "opening the tranny" car-party.
  12. Member Pat @ Pitt Soundworks's Avatar
    Nov 14th, 2008
    Pittsburgh
    07-26-2012 07:41 PM #82
    Been busy, and not a lot of time to work on the car. Got the vacuum lines done, and the intake started. I need to order another cobra head, because I cut this one a little too short, and a 4" alu 45*, and filter.
    I had to cut down the inlet flange on the turbo, and weld a 90 to the outlet flange. I also had to seal the OE wastegate port.
  13. Member Pat @ Pitt Soundworks's Avatar
    Nov 14th, 2008
    Pittsburgh
    08-02-2012 02:12 AM #83
    About damn time.
    After I did a TB alignment, it idled like a champ.
    (lifter tick from sitting)
  14. Member
    Jun 2nd, 2005
    city of champions
    04.5 blue lagoon gli, bmw 2002
    08-03-2012 10:33 AM #84
    ballllingggg, cant wait to come out and see her...hope all is well buddy, lets get together soon, still gotta get that stupid o2 sensor innovate bulls hit fixed too...
    GLI- GT28rs, Porsche ECS stage 2v2, Mocal, and hopefully Clutchmasters fx350 come summer time...
    http://forums.vwvortex.com/showthrea...28rs-gli-build
  15. Member 18T_BT's Avatar
    Sep 15th, 2005
    Silver Spring, MD
    2002 1.8T JETTA & 2000 TTQ
    08-03-2012 12:45 PM #85
    those poor stock motor mounts
  16. Member one_fast_vw's Avatar
    Feb 10th, 2011
    660 BFE
    03 static BT Jetta, 2.slow jetta RIP
    08-03-2012 01:56 PM #86
    Great work subscribed
    Sent from garage
    Quote Originally Posted by Miller7204 View Post
    Only reason you're low is because there's a whale on top of your car
    Because Racecar: CTS 5857 IE rods, custom 2.5 ic piping, Eurodyne 630cc tune, HKS boost controller, Greddy turbo timer, tial bov, Walbro 255 w/ custom fuel lines, Tial WG w/ Open dump, stripped interior, A/C delete, PS delete. And I need more power
  17. Member mike4-vr6's Avatar
    Jun 11th, 2011
    01 jetta vr6
    08-03-2012 02:36 PM #87
    Like what you did with the intercooler.
  18. Member Pat @ Pitt Soundworks's Avatar
    Nov 14th, 2008
    Pittsburgh
    08-03-2012 03:08 PM #88
    Hey now, they aren't stock mounts. They're 90 durometer filled stock housings. Once I get some more cash, they need to get replaced.
    I had her on the road just a little bit ago. The fx400 isn't too easy to drive, but I'll get used to it. And I think I have the boost controller lines on backwards, because she scares the **** out of me. Once it spools up (around 3500-4000 full boost), all my gauges go flying and I can't see ****. I put it in a higher gear and watched it spool. I'm shooting for 19psi on the stock block. Once it hit 19, I shifted. But it spooled up so fast that I saw it go to 35..... Good thing I'm quick on the clutch.
    The completely open exhaust sounds like a damn freight train on the road. I love it.
  19. Member Pat @ Pitt Soundworks's Avatar
    Nov 14th, 2008
    Pittsburgh
    08-03-2012 07:52 PM #89
    Video is being uploaded right now.
  20. Member Brandon_Schulze's Avatar
    Nov 11th, 2011
    SoCal
    2002 Volkswagen Jetta 1.8T
    08-03-2012 08:36 PM #90
    Wow. Good Work Man
    Quote Originally Posted by Guitarman355 View Post
    You know what you need to do. . .
    once you sit your frame on the ground, you're low enough
    Follow me on Instagram: Brandon_Schulze
  21. Member Pat @ Pitt Soundworks's Avatar
    Nov 14th, 2008
    Pittsburgh
    08-03-2012 10:36 PM #91
  22. Member RDIRTYTOO's Avatar
    Oct 4th, 2007
    syracuse, ny
    98 glx,01 jetta glx,01 wolfsburg,00 gls vr6,11 wrangler sahara, 04 bmp turbo R sold,97 glx
    08-03-2012 11:25 PM #92
    so what was the cause of the fire??????
  23. Member Pat @ Pitt Soundworks's Avatar
    Nov 14th, 2008
    Pittsburgh
    08-03-2012 11:28 PM #93
    95% sure the oil pressure gauge line melted and sent oil down the shifter cables. The rubber on the shifter cables shift what caught fire. If I had put the heat shield back on, there's no way we would have got the fire out. And my dumb ass forgot to take the fire extinguisher.
  24. Member ZLaSalle's Avatar
    Jul 5th, 2011
    Central New York
    Racekor
    08-04-2012 10:58 AM #94
    What's the damage?
    Quote Originally Posted by troyboy96 View Post
    im gonna retrofit my nuts in your mouth
  25. Member Pat @ Pitt Soundworks's Avatar
    Nov 14th, 2008
    Pittsburgh
    08-04-2012 12:07 PM #96
    Block is toast, but I don't care about that.
    heater core fittings, which I wasn't hooking up anyway
    turbo blanket
    silicone 90
    2x tbolt clamps
    firewall insulation is a little crispy, but ok
    The biggest thing is some insulation on the wiring for the avcr got Burnt. Ill repair it and hopefully avcr is ok.
  26. Member deejaaa's Avatar
    Aug 30th, 2006
    Baytown, Texas
    2002 Jetta GLS TDI 5 speed
    08-04-2012 12:35 PM #97
    when you first bailed from the car, it looked like you weren't coming back and you wanted to sit back and watch it go up. the flames kept getting higher and it looked like it was going to be tragic.
    2002 GLS Jetta TDI 5 speed with Ariettas no more LOL!!15" avus and lovin' it!
    Brought home 2-22-2012
    ……"I put it back to a driveable height"…….vr6gti727, 6/7/12
    .."avus are 15s anyways so you clearly don't care about looks"..tar, 07-23-2011
  27. Member Pat @ Pitt Soundworks's Avatar
    Nov 14th, 2008
    Pittsburgh
    08-04-2012 12:58 PM #98
    I thought it was going to be a total loss. We got it out on the last water bottle. I got away hella lucky
    Sent from my HTC ThunderBolt using Tapatalk 2
  28. Member Pat @ Pitt Soundworks's Avatar
    Nov 14th, 2008
    Pittsburgh
    08-05-2012 12:30 AM #99
    Got the 2.0 block/crank ready for the machine shop.
    Got the next customer car in the garage: 94 acura legend getting a 3.5/6spd swap and custom 6768 turbo kit.
    Gave my buddy some tig welding lessons
    Also started a clutch swap on a 02 G20
  29. Member
    Jun 2nd, 2005
    city of champions
    08-06-2012 10:44 AM #100
    you ar e one busy man and have a great attitude dude...keep up the awesome work! gotta get out your ways just to say whatup, hope all is well holmes!
  30. 08-11-2012 04:18 AM #101
    damn that legends sexy! to bad its a 92 and not a 94 LOL
    < owner of that legend also the guy who video tapes all of this crazy stuff
  31. Member Pat @ Pitt Soundworks's Avatar
    Nov 14th, 2008
    Pittsburgh
    08-11-2012 05:07 AM #102
    Whatever. It's rusty and will never run again.
  32. Forum Sponsor Quintin@USRT's Avatar
    Oct 6th, 2009
    DC
    A founding Member of the 8v 350+whp Club, Now rocking a B7 S4 mmmmm V8!
    10-11-2012 10:16 PM #103
    make more power than the 8v.........DO IT.
  33. Member Pat @ Pitt Soundworks's Avatar
    Nov 14th, 2008
    Pittsburgh
    10-11-2012 10:23 PM #104
    Your 8v? Pfftt
  34. Forum Sponsor Quintin@USRT's Avatar
    Oct 6th, 2009
    DC
    10-11-2012 11:04 PM #105
    HEY last 20v i saw with an HY35 was a pansy...so i hope...scratch that.. I KNOW you can do better.
