Results 1 to 19 of 19
Thread: Searching for any TCL favorites in 'round town trucks
  1. Member coderedcomputing's Avatar
    Sep 22nd, 2011
    DC Metro Area
    2008 Passat 2.0T TSI; 2005 Scion xB
    05-19-2012 11:13 PM #1
    Evening folks, looking to tap the collective knowledge-base and search for a 'beater' truck. About to buy another house, have 2 DD already, and looking for a truck to add to the garage for basic home use. Planning for mostly trips around town, getting plants, mulch, fences, kitchens, and other appliances...the typical house-related tasks. 2wd is fine, nothing fancy needed.
    Last truck I bought for this sort of work was a Nissan Frontier 4x4, it fared well but rusted out VERY quickly. I'd love to avoid this as much as possible. Hoping for a truck that will last a few years, and one that is easy enough to work on myself.
    What sort of recommendations does TCL have for a sub $5k beater?
    2008 Passat 2.0T TSI - Unitronic Stage 1+ / BSH True Seal Intake Stage 2 / AWE Diverter Valve / 42DD Boost Tap / MKV MFSW with Paddles / Driver Gear Springs & Koni FSD / Euro Spec F/R Turn Signals
  2. Member emmettlodge's Avatar
    Nov 7th, 2007
    Ohio
    2012 Tacoma 4x4, 2010 Tacoma 4x2, 1990 E30
    05-20-2012 12:08 AM #2
    At sub-$5k, you won't have to worry about it eventually rusting out because the rust will already be there.
    All rights reserved. No fur-bearing animals were harmed during the creation of this post. Caution: May cause irritability, sleeplessness or warts after prolonged reading. May cause some laboratory rats to rip through their cages, fly across the room and brutally murder hundreds of innocent people. Not to be combined with other posts except under the advice of a physician.
  3. Geriatric Member BRealistic's Avatar
    Dec 16th, 2005
    Tennessee
    88 F150, 04 RX8
    05-20-2012 12:59 AM #3
    I like the older F-150s (late 80s to mid 90s) as work trucks as they were designed and engineered back when trucks were trucks- and are durable and easy to repair/maintain.
    But they are getting very hard to find in good condition...
    Here is a long bed 1998 F-150 with a V6 and manual (later gen than the really durable ones).
    Long beds make great work trucks, and the long bed usually makes them cheaper since they don't look as good.
    http://washingtondc.craigslist.org/n...012772141.html
  4. Member coderedcomputing's Avatar
    Sep 22nd, 2011
    DC Metro Area
    05-20-2012 09:46 AM #4
    Very true, guess the question is more - is truck X known to rust in spot Y so check there or just pass that model up....
    Similar to knowing old civics rust out in the wheel wells.
    Sent from my Samsung Galaxy Note
  5. Member retro_rocket's Avatar
    Apr 17th, 2002
    Akron, PA
    08.5 Mazda 3
    05-20-2012 11:09 AM #5
    Since you are not picky about having 4WD, you should be able to find a decent early to mid-00's Silverado in work-truck spec, with higher mileage, in your price range.
    http://washingtondc.craigslist.org/n...026313023.html
    http://washingtondc.craigslist.org/n...026798469.html
    http://washingtondc.craigslist.org/n...023478020.html
    Put it in H!
    2008.5 Mazda 3i - 9/3/08 - present | 1983 VW Rabbit GTI - 4/30/03 - 5/6/11
  6. Member
    Apr 28th, 2009
    Palm Beach County, FL
    05-20-2012 11:24 AM #6
    Just hunt your local CL and buy the nicest, cleanest, anything not too oddball that you find. That means stick with mainstream brands (Ford, Chevy, Dodge, Nissan, Toyota) and buy on condition; good tires, clean paint, a bedliner, interior not destroyed, etc. ANY 2WD truck will do what you want it to do; no sense saying "Go find a Ranger" if you find a destroyed ranger when a clean basic Silverado is available in tip-top shape.
    Jared
    Originally user 22691
    "I'm trying to live vicariously through jrod here and my vicarious
    life would be better if he had a twin turbo. Or a ****ing pirate
    ship." nm+
  7. Geriatric Member BRealistic's Avatar
    Dec 16th, 2005
    Tennessee
    88 F150, 04 RX8
    05-20-2012 11:26 AM #7
    Quote Originally Posted by coderedcomputing View Post
    Well, we don't get the rust issues in my area that they get up north.
    But the spots you usually see rust on older trucks (or trucks from up north) are the rocker panels, cab floor, truck bed and over the rear wheel wells.
    The cab mounts are a common but dangerous spot for rust on older trucks.
  8. Member efrie's Avatar
    Mar 19th, 2008
    Arkansas
    2000 7.3PSD, 99.5 7.3PSD, 1998 4.0L XJ
    05-20-2012 11:31 AM #8
    If you're looking for something under $5,000 you've got a plethora of trucks to choose from.
    Hell, I bought this for right around $1,500. No rust, it's a little rough around the edges, but the AC works, electric windows and door locks work, 4x4 works, what's not to love?
    I threw some headers on it and an intake just for sh*ts and giggles, sounds great.
  9. Geriatric Member BRealistic's Avatar
    Dec 16th, 2005
    Tennessee
    88 F150, 04 RX8
    05-20-2012 11:41 AM #9
    True... and it is easy enough to search any one model/year to see if they have any major known issues to watch out for.
    On that note.... if the OP can get this for $5k (and it is in great shape)...
    http://washingtondc.craigslist.org/n...026152185.html
    I had a base 02 Tundra longbed.
    But mine was the automatic.
    A manual would made made it more enjoyable to drive (engine needs to rev to make power so tranny kicks down a lot)..
    But this truck even in base vinyl and rubber interior form was very comfortable and very well put together.
    I was impressed.
    That being said- look for rust on the frame.
  10. Member efrie's Avatar
    Mar 19th, 2008
    Arkansas
    05-20-2012 11:43 AM #10
    My dad has a 2001 Tundra, 2WD, 3.4L V6 with the 5 speed manual. He's right around 195,000 miles now and the truck still runs like brand new.
    With the stick shift it really does have more than enough power. These earlier Tundras weren't built as heavy as the new ones, so they're relatively light compared to their domestic counterparts.
  11. Geriatric Member BRealistic's Avatar
    Dec 16th, 2005
    Tennessee
    88 F150, 04 RX8
    05-20-2012 11:46 AM #11
    Quote Originally Posted by efrie View Post
    But I was a bit pissed off that even REAR WHEEL ABS was not standard on the Tundras back then.
    My 88 F-150 has that (and it still works).
  12. Member efrie's Avatar
    Mar 19th, 2008
    Arkansas
    05-20-2012 11:47 AM #12
    The rear end on the manual Tundra can get pretty happy, especially with the manual trans. It's hard not to let them slip if it's even a little bit wet.
  13. Member coderedcomputing's Avatar
    Sep 22nd, 2011
    DC Metro Area
    05-20-2012 04:44 PM #13
    I've noticed that many of the trucks being bantered about here are V6... more power is always good, but any reason to not look at 4cyl models?
    I just got done looking at a 90's Ranger V6 that had rust issues in the cab mounts and the bed/frame area looked suspect as well. Passed on that one, even at $1k it looked ... iffy.
    Of course, then I come across things like this:
    http://washingtondc.craigslist.org/n...026908396.html
  14. Member Live-Wire's Avatar
    Jun 9th, 2005
    Guelph Ontario
    2008 BMW 335i
    05-20-2012 07:05 PM #14
    That's some goooooood frame flex right there!
    Awesome find for $1500 tho!! The old F150's don't last up here in Ontario... salt eats them alive. Basically, you don't find old pickups here in general - people tend to use them for work, and drive them year round - they get destroyed after 400-500k kms and 15 years of salt/hard work.
    I'd be shopping 10 year old Silverado's... They seem to hold up the best as far as 10 year old trucks go. See a lot of older Dodge's too, but I hear suspension on them is not an if, but a when... among other things. Don't see very many 10ish year old F150's tho (from the rounded off style era)... I always wonder why, since they supposedly outsold the GM trucks (which are everywhere).
  15. Member efrie's Avatar
    Mar 19th, 2008
    Arkansas
    05-20-2012 10:04 PM #15
    Yeah, truck had no rust that I could find. Only leak was the rear main, and it just sweats. I put 5,000 miles on it after the last oil change and it only went down 1/4 a quart.
    She's sitting pretty at 163,000 miles right now. I think I got the better end of the deal.
  16. Member urbancynic's Avatar
    Apr 19th, 2007
    Phoenix, AZ
    2011 Chevy Silverado
    05-20-2012 10:53 PM #16
    That's basically what I did when I bought used trucks. My budget was way less than 5k though.
    In my case I went for cheap, decent shape, easy to work on and as simple as I could get. First one was a 74 f250 with a 460. Fantastic truck. But I bought it to sell it.
    Second time around I wanted another one but couldnt find one in decent shape. Ended up with my 73 c10.
    I personally like the 73-85, and 92-96 Ford full size trucks as well as the 67-87 Chevrolet full size trucks.
    Beyond that I haven't seen a Toyota I didn't like besides maybe the t100.
    Current: 2011 Chevy Silverado
    Previous: 84 Jetta diesel, 00 Jetta TDI, 04 Frontier, 05 Tacoma, 01 Jetta VR6, 05 GTI, 85 Jetta diesel, 06 Tacoma V6, 81 Rabbit diesel, 81 Rabbit 16v, 86 GTI, 86 325e, 89 GLI, 99 MK3 Jetta, 73 Stupid Beetle, 89 GTI 16V, 92 Jetta Carat, 74 F250, 86 325es, 77 MGB, 73 C10, 06 MCS
  17. Geriatric Member BRealistic's Avatar
    Dec 16th, 2005
    Tennessee
    88 F150, 04 RX8
    05-20-2012 11:48 PM #17
    Quote Originally Posted by urbancynic View Post
    Why is that? The t-100 seems to have a loyal following.
  18. Member muffintop's Avatar
    Oct 15th, 2009
    UT
    NA Miata
    05-20-2012 11:55 PM #18
    Get one of these bad boys:
    Make sure your tetanus shots are up to date.
    I'll be in my bunk.
  19. Member urbancynic's Avatar
    Apr 19th, 2007
    Phoenix, AZ
    05-21-2012 01:42 AM #19
    There isn't really any rhyme or reason to it, I just don't like them. Could be due to lack of experience with them, but they've never caught my attention.
