Results 1 to 6 of 6
Thread: looking for a dual weber manifold for a 16V engine where to buy?
  1. 05-20-2012 12:00 PM #1
    Hi i am looking for a good 16V manifold for dual webers ,where to buy?
    I know that Search google is one option ,but there are bunches of sellers ,i am looking for a recomendation.
    Regards
  2. Member SGLoki's Avatar
    Dec 12th, 2004
    The Ham
    88 fox RIP 86 jetta RIP 81 rabbit RIP, 1984 GTI RIP, 03Ranger RIP, (03 Legacy, 03 Allroad, 86 Jetta)
    05-20-2012 12:23 PM #2
    redlineweber will hook you up with a local retailer.
    a "good" manifold is the hard part, a lot of people have to grind and file them for bolt clearance, not sure if those are just the 8v versions, or if the 16v ones have the same issues.
    Maybe Kris has some ideas... anyone seen Kris clewell on lately?
    1% defined: Lone wolf, no club. Duct tape it yourself. It is broken down 1% of the time, and work is always 1% completed.
    2% defined: I'm too old to drive broken sh*t and VW people are cool. DBVW!
    Quote Originally Posted by nsindel View Post
    May I introduce Senor SGLoki -
    the man, the myth, the slamdancer...
    Jun 14th, 2001
    Music City USA
    79 Scirocco 82 Rabbit Truck 85 Golf D 87 GTI 97 Passat TDI 03 TT
    05-20-2012 03:11 PM #3
    I bought the entire redline kit. The Weber 16V intake is a tight fit on cylinders 1&2 it required some clearancing and some ingenuity for something that should "bolt on" It is by far the most common manifold in the US. I bought 6mm shouldered nuts that require a 10mm wrench. I drilled and tapped them to 8mm and used loctite.
    I think this one might be better:
    http://www.dbilas-shop.com/Produkte/...-PL::6453.html
    Collin and Randy had some intakes from South America or South Africa at Techtonics but I think they sold out. you might check with them. I would buy darn near anything besides the Weber intake if I could find it.
  4. 05-20-2012 07:40 PM #4
    I will check
    Regards
    Mar 7th, 2011
    Colorado
    05-20-2012 09:43 PM #5
    injunsummer is now gromel
  6. 05-20-2012 10:57 PM #6
    looks very good
    thanks
