mk3 obd2 aba tb -40
mk2 seatbelt -4
mk2 jack flap- 4
aba spark plug wires all worked when pulled -20$
#1
hello everyone i've been a vender at Dustoff for the past 2 years and selling on here since 06.
if i do not respond to your PM within 24 hours, please email me ! @ durtyeuroperformance@comcast.net
items location is southeast mass 02747 will ship most items, dont be afraid to ask if you do not see something on the list that you think i might have, because i probably do !
i ship via usps using flat rate shipping. bigger items i ship ups. please use your judgement on what items will fit in flat rate box .( please try not to flood my pm box with how much would this be ship to 85xxx zip code) i always add tracking so shipping would be approx 6-17$ depending on size box coast to coast.
PARTS ADDED DAILY
mk2 bumper clips 1 each!
mk3 cup holders-5$
mk2 window switches(have atleast a full set) mk2 fog light switchs, 2 mk2 defrost switchs,mk3 defrost ,mk3 door lock switch, mk2 late headlight swtich, mk3 ac switchs, mk2 hazzard switch, door chime relays, misc relays
digi2 intake boot -5$
mk2 hub cap - 4$
aba fuel rail, injectors and fpr -30
audi c4 master window switch-10
aba oil pump-40
mk2 door pocket -5
mk3 hvac controls (no panel)-8
mk3 interior door mirror covers 3 each 5 pair
1.8 16v tb body -35
bosch ecu 40
vw oil caps 3 each
mk3 center dash vent -5
mk2 brown b -pillars -30
mk2 digi2 8v engine harness -25
mk3 fan module with pigtail harness (have 2)-10
mk3 (jetta) wiper motor & linkage -35
mk2 pass door buckle -2
dist caps (8v)-5
8v oil baffle (topend)-2 each
aba valve cover -8
mk3 ebrake w/ switch and pigtail -25
mk3 vr6 expansion tank-10
mk2 ignition modules -10 (have 2)
mk4 2.0 exhaust manifold (missing studs, has small crack) -35 or i can restud , weld small crack and heat heat temp coat for additional 20
battery tie down- 2 each
mk3 aba ac compressor -30
mk3 ochit handles -10 set will separate
mk2/3 linkage rods -5
untagged goodness(bbs blank centers, mk2 blanks, mk3 blanks, mk3 misc interior odds and ends . make me a offer on these
mk2 cruise control module -30
digi2 booster vacuum line -3
mk2 door grab handles -4 set
8v fpr-5
mk2/3 washer pumps, spare tire tie downs, mk3 exterior handle, mk3 sunroof crank , misc relays
MK4 RH window regulator broken clip fix kit. DONT pay for a new regulator when all u need is the clips. this a oem vw part never used -20
mk3 wiper and turn signal stalk-10
aba belt tensioner /bracket -10
8v cam gear -5
,mk2 plate lens, mk2/3 brake fluid cap/sensor, c4 lock switch ect
early 8v coil -15
audi c4 marker lens (small chip )-10 pair
mk2 o chit handles -10
1992-94 audi c4 100 ecu - works great - 50$
mk2 8v late throttle cable -15
mk2 120mph cluster 183,243 miles, 1 prong -40
various b5 & mk4 1.8t TB's -50 each
8v front motor mount bracket and bolts -5
mk2 quad inner pigtails and covers-20
mk2 rear seat buckles (4 door) -4$
mk3 horn and pigtail -10
mk2 paintable emblem -2
020 secodnary tranny bracket -4
mk3 obd1 aba tb-25
digi2 ecu-45
mk2 cis boxes -15 each
mk3 obd2 aba cam and gear-25
mk2 power steering pulley -4
mk3 fuel cap -4$
mk2 16v glovebox -40
mk2 shifter surround -2
mk2 jetta trunk button/handle -10
mk2 ashtray-4 each
mk2 starter-15
mk2 dome light -3
aba rear motor mount bracket -5
mk3 pass mirror (manual)-15
early 8v valve cover -10
mk3 hood latch handle -3
mk2 dome light non sunroof -15
aba lower intake manifold -4
mk4 egr -40
tire wrenchs -3
early 8v valve cover brackets -3
mk3 pass side vent -4
aba upper intake manifold - 5
mk2 rear motor mount -5
mk3 light harness (uncut)-25
aba maf -25
mk2 2.0 cis intake intake boot -10
1.8 t valve cover -15
mk2 tranny mounts -5 each
mk3 ac drier -15
mk2 water pump pulley-4
mk2 hella inner quad light-15
1.8 16v box plastic -2
grassroots racing to knuckle busting scenestahs
we do it.
VIVA LA DEP
http://www.facebook.com/TeamDep
teamdep.com
#2
mk3 obd2 aba tb -40
mk2 seatbelt -4
mk2 jack flap- 4
we do it.
VIVA LA DEP
teamdep.com
#3
Damn.. I didn't know you were in town. I could've used that "mk3 light harness (uncut)-25" 2 months ago when I fixed up a MK3 for my mother in law.
Free bump for local goodness.
My MKV APR Stg II+ build thread: The build...the blog...the boosted...
My MKIV project thread: New to 1.8T and need some guidance
#4
ha i didnt think anyone else in dartmouth was on vortex haha. well when ever you need something i'm probably only a hop and skip away .
we do it.
VIVA LA DEP
teamdep.com
#5
all pm's replied . sold intake hose and boots
we do it.
VIVA LA DEP
teamdep.com
#7
shhh im trying to scam people brah
thanks for pointing that out. looks like the tags got mixed up.... now wheres the real 20v valve cover ...
we do it.
VIVA LA DEP
teamdep.com
#8
still have window cranks for sale? need on for my drivers side, and i live in somerset MA, so i could pick up.
#9
pmd
we do it.
VIVA LA DEP
teamdep.com
#10
BUMP for a good seller and quick shipping! Thanks for the parts!
#11
thanks!
bump
we do it.
VIVA LA DEP
teamdep.com
#12
bump stuff sold
we do it.
VIVA LA DEP
teamdep.com
#13
bump
we do it.
VIVA LA DEP
teamdep.com
#14
those icm s you have are they digi2 ? 8 valve?
i might need a coil too
thanks
#15
bump
we do it.
VIVA LA DEP
teamdep.com
#17
ttt
we do it.
VIVA LA DEP
teamdep.com
#19
yes i have them
we do it.
VIVA LA DEP
teamdep.com
#22
all replied ! ttt
we do it.
VIVA LA DEP
teamdep.com
#23
Hey man i see you have alot of parts. Im looking for a uk passenger side mirror deleat. So i can put it on my us 89 jetta so i can have a drivers side deleat plate. Could you get ahold of one? If so how much to ship to 97304?
