VWVortex.com - 1994 Audi S4 165k North NJ $4900
    Results 1 to 5 of 5
    Thread: 1994 Audi S4 165k North NJ $4900
    1. Member oleg_8831's Avatar
      Feb 12th, 2006
      b5 s4/urs4/2 mk4 bt 20v gti's/3B6 a4's
      05-21-2012 04:18 AM #1
      Up for sale is 1994 Audi S4 a.k.a. URS4 with 167,000 miles, its emerald green with ecru leather seats. It's 5 speed manual with rear differential lock (this car never gets stuck in snow, impossible), the engine is Audi's legendary inline 5 cylinder AAN 20 valve 2.2 liter turbo, (K24 turbo, these are known to go for 300k miles), the car starts, runs and drives amazing. It will outhandle many newer cars on the road, I upgraded the tires and wheels with Audi B5 S4 OEM Avus 17" wheels and 225/45/17 low profile tires. I still have the original 225/250/16 Fuchs Original Wheels with tires too. The title is clean, never been in accidents, I believe I am the second owner. Always put synthetic oil every 4000 miles. In the past 10,000 miles I put timing belt, water pump, pulleys, drive belt, crank and cam seals, valve cover gasket, new front and rear brake pads and rotors, heat works, A/C is freezing cold just charged a week ago, the tires are new just put them on last week, the clutch is perfect, transmission shifts smooth and tight. Also done last week brand new control arm bushings and passenger side tie rod, with alignment done, the car handles like its on rails with thees tires and rims, and of course quattro. Now has all the body mouldings except on rear passenger door bottom, also just been aligned.. The interior dashboard bulbs were upgraded with Audi OEM 2watt bulbs, I put in low beam 4300k 55watt H.I.D. lights and 3000k yellow H.I.D. fog lights, the car has double projector headlights, with glass lenses. The car also has heated front and rear seats, and an aftermarket pioneer H.U. with bose speakers. These are very rare cars, not many around, in 1994 only about 400 were imported from Germany, the inline AAN 5cyl motor is known to be bulletproof, and were used in many rally cars in the past. Alot of work has been put into this car, over $2500 worth of labor and parts in the past 6 months, just needs a nice wax. $4300 obo (two 0 one eight 8 one six 4 nine two) no joyrides, these cars are rare.
      more info on the car: http://en.wikipedia.org/wiki/Audi_Ur-S4_/_Ur-S6
      FS:B6 A4 Partout,MK4 VF Trans & Dogbone Mounts, WRD Engine Mount,
    2. Junior Member
      Apr 22nd, 2010
      New Jersey
      2004 Audi A6 2.7t
      06-13-2012 08:14 PM #2
      I'm from nj, wanted if its still available?
    3. Member oleg_8831's Avatar
      Feb 12th, 2006
      06-25-2012 08:37 AM #3
      still available, im coming back on wednesday
    4. Member oleg_8831's Avatar
      Feb 12th, 2006
      08-13-2012 12:14 AM #4
      ok so Im back the car is now for sale, bump
    5. Member oleg_8831's Avatar
      Feb 12th, 2006
      08-31-2012 04:06 AM #5
      BUMP Price DROP
