Results 1 to 3 of 3
Thread: mkV front headrest stuck
  1. Junior Member
    Jul 16th, 2010
    Mystic CT
    2003 GTI 20AE BMP #1169, 2008 GTI 6MT
    05-21-2012 09:38 AM #1
    Tried searching for a DIY/info about this but came up short....
    Just got a mkV GTI..Passenger headrest is stuck all the way up. Release button has tension on it so I think it's working, but the headrest isn't moving in or out. Any suggestions?
  2. Junior Member
    Jul 16th, 2010
    Mystic CT
    05-21-2012 10:48 AM #2
    update: release button doesn't seem to be actuating the unlock mechanism. Is there a way to manually disengage the headrest?
  3. Member ghostdriver's Avatar
    Jun 15th, 2006
    WESTSIDE CT.
    1992 Corrado, 2012 Durango, 2007 Dakota,1991 Jetta VR6 Coupe(Sold),2001 Jetta 1.8T
    06-15-2012 08:37 PM #3
    Quote Originally Posted by bck6780 View Post
    I had the same problem on my Jetta, and if you pullup hard on the headrest it will come out with the base on the side that is jammed. Remove the plastic base from the shaft and there will be a little metal piece protruding from the shaft. Gring that off and you will be able to put it back all the way down. The downside is the headrest will not work properly, but who the phuck really uses them anyways.
    Hope you get it to work, Good luck.
