Results 1 to 5 of 5
Thread: i have apr in my 20th how to know in which mode am i on????
  1. Member drzr32's Avatar
    Oct 27th, 2007
    copiague ny
    20th gti yellow mk3 jetta trek, audi a4 b7, mk2 golf gl/ mk3.5 cabrio
    05-21-2012 10:00 AM #1
    i disconnected my battery and im wondering if reset which mode i was on. the previous owner told me i have 2 modes stock mode and stage 1 or2 i dont remember which one he said. is there a way to know which mode i am in when i turn on the car and look at the cluster? thanks.
    Jul 24th, 2010
    Kirkland, WA
    B5 Passat Wagon
    05-21-2012 12:12 PM #2
    If you have both stock and then a tuned set up, the way to tell is this. Turn the car off, have the key in, cruise control on. Hold down the "SET" button on the cruise control until the CEL Light starts blinking. When it starts blinking 1 time per second that is the first tune (most likely the stock one), and then when it is blinking twice per second (should be the tuned set) let go of the set button. Turn the key to the off position and turn it back on and let the lights on the dash cycle through and then start the car.
    Quote Originally Posted by scirockalot8v View Post
    delete your account and start over.
    Oh the Mark 4 forums.., how I will miss you.
  3. Member drzr32's Avatar
    Oct 27th, 2007
    copiague ny
    05-21-2012 12:38 PM #3
    bingoo!!!!!!!! the answer i was looking a bottle for you my friend drink up
  4. Member BRANT#2766's Avatar
    Oct 31st, 2011
    North Al
    2003 20th anniversary GTI, '87 Cabby. 2003 Chevrolet Z71, KTM SMC 690
    05-21-2012 04:05 PM #4
    uhh.. i dont think disconnecting the battery does anything with these cars. but, what he said.
    Mar 8th, 2012
    Long Valley, NJ
    2002 GTI 337
    05-21-2012 04:10 PM #5
    disconnecting doesn't reset the mode, however, it depends on what order the PO had the modes installed. For instance. My car has APR Stage I and I have (in order) 93, Stock, 100, Valet.
    When you order the ECU upgrade, you designate the order you want as well as your security code.
