Results 1 to 3 of 3
Thread: Transmission stuck in reverse
  1. Member VWBugman00's Avatar
    Mar 16th, 2009
    Kennewick Wa
    00 Beetle
    05-21-2012 10:25 AM #1
    Hello. I just did a complete rebuild on my 1.8t, and am now in the process of reinstalling everything. I've been doing work using the Bentley. When I removed the transmission, I put the tranny into maintenence mode as the book suggested. Now that I've put everything back in the car, and got the cables and counterweight installed, I shifted through the gears to make sure everything was engaging correctly. I also put the switch back over into running position. The tranny felt like it was binding, and when I put it into reverse gear, it locked into place and won't come out. Any ideas on how to get it to pop back out? Thanks.
  2. Member VWBugman00's Avatar
    Mar 16th, 2009
    Kennewick Wa
    00 Beetle
    05-21-2012 02:41 PM #2
    For clarification, the car is a 2000 1.8t Beetle with a O2J Transmission.
  3. Member VWBugman00's Avatar
    Mar 16th, 2009
    Kennewick Wa
    00 Beetle
    05-24-2012 12:10 PM #3
    Sad day, no one has had this issue?
