Results 1 to 6 of 6
Thread: Is this safe?
  1. Member haf1zur's Avatar
    Feb 20th, 2006
    UK Golf R32 2004
    05-21-2012 01:24 PM #1
    Hi
    Fitted arp bolts to the main caps and noticed that the nuts dont cover the bolts flush
    Is it safe to run like this or should i remove the washers?
    Just spoke to arp technical support and the guy mentioned they dont do a kit for the 3.2L and the kit i have is for a 2.8/2.9 (P/N 204-5403)
    Now since its only the difference of the washer, should i just back the stud out a couple of threads so the nut sits flush with the top of the stud?
  2. Member IMAN973's Avatar
    Jun 1st, 2006
    Big Turbo Land NJ
    08 2.1L Fsi 67'd SFWD Gti, mk2 67'd VRT Jetta
    06-22-2012 03:19 AM #2
    Quote Originally Posted by haf1zur View Post
    Thats what i would do. I would not remove the washer or leave the nut not fully threaded.
  3. 06-23-2012 02:11 AM #3
    I had the same picture on my VR 12V engine. Seems ARP main studs are a bit short. I didn't want to lose 1-2 nut threads so I backed that much the studs.
  4. Member Schnell VR6's Avatar
    Jul 1st, 2006
    North Carolina / Maine
    2012 Golf R, 2004 R32T, 1990 G60 Corrado, 1988 Vanagon
    07-15-2012 08:47 AM #4
    I would make ARP send me the proper fit bolts... I don't know what you are running but I have a high Hp R32 and don't have any room for guesses. Either way If you just backed the stud out from the block a bit and retained the washer then torques the nut cap to specifications then you should be fine as long as there is at least 3-4 threads covered in the block from the stud then it should hold.
    Good luck with it man.
  5. Member vwmaniac16vr6's Avatar
    Nov 17th, 2004
    North-west NJ 07838
    08-13-2012 01:00 AM #5
    Ive run them like this on 600+ motor with billit main caps and no problems, they are a bit under cut but not a problem.
    ME7 MK4 1.8T/VR6 IMMOBILIZER DEFEATS available, NJ local, IM for details or call 908 303 7937
    Launch control NOW Available for most ME7 ECU's Coming soon... MK4 VR6 Turbo Software with Launch Control and No Lift Shift!!
  6. 08-15-2012 11:00 PM #6
    i backed out the stud so the whole nut fits. i used the crank scrapper as the washer and the side that had no scrapper I used a washer. No problems with the main caps or bearings.
    Racing Improves the breed..
    "I have fought the good fight, I have finished the race, I have kept the faith"- 2 Timothy 4:7
    CrossroadsLI
    MY ALL MOTOR BUILD THREAD
