Results 1 to 7 of 7
Thread: Transmission swap on 01 jetta 2.0
  1. 05-21-2012 05:26 PM #1
    Does anyone know If a 6 speed transmission from a 2002 Gli with v6 engine will fit on a 2001 Jetta 2.0 5speed transmission.
  2. Member Jetta02AWP's Avatar
    Feb 27th, 2003
    Eastlake,OH
    02 Mercedes C230 Kompressor Coupe 6 MT, 2012 Nissan Cube, 00 VW Beetle 1.8t
    05-21-2012 06:07 PM #2
    Quote Originally Posted by Socal213 View Post
    No
    Instagram: jetta02awp
  3. Member JayDD007's Avatar
    Feb 27th, 2012
    Pottstown, PA
    12v jetta
    05-21-2012 06:18 PM #3
    Will it fit a 12v 5 speed?
  4. Member Jetta02AWP's Avatar
    Feb 27th, 2003
    Eastlake,OH
    05-21-2012 06:33 PM #4
    Quote Originally Posted by JayDD007 View Post
    Yes, but you need axles, hubs, linkage, and I may be missing something
  5. 05-21-2012 07:52 PM #5
    What about a 6 speed transmission from a 04 GLI 1.8t fit on a 2.0 jetta
  6. Member Jetta02AWP's Avatar
    Feb 27th, 2003
    Eastlake,OH
    05-21-2012 08:13 PM #6
    I believe that will work with the above mentioned parts changed out. The reason that the VR tranny won't work is because the bell housing is different on the VR vs. the 4 cylinders
  7. 05-21-2012 10:26 PM #7
    Ok thanks
