VWVortex.com - 91 jetta na diesel $1500 17552 PA
    Results 1 to 10 of 10
    Thread: 91 jetta na diesel $1500 17552 PA
    1. Member Darkmark's Avatar
      Dec 18th, 2009
      81 Caddy, 86 GLI,96 JETTA
      05-21-2012 06:24 PM #1
      I purchased this n/a non-turbo Jetta in October of last year with a list of issues that I began to address. Since then the motor was pulled. The rings,crank bearings,head gasket,oil pan gasket,valve seals,intake gasket, and exhaust gaskets have all been replaced (as far as motor work goes).
      The windshield was replaced because of an obnoxious spider crack. As well as a new window lift/regulator in the drivers front door.
      I will disclose that the instrument cluster has "its days"...it tends to randomly loose power. The speed-o and the clock continue to work dispite this issue. I installed aftermarket temp/voltage gauges to remedy this issue until I got around to it.
      I have noticed that in the past the car HAS BEEN IN AN ACCIDENT. It was hit in the front pas. side. I dont want that to come as a surprise to any1 (I didnt notice this when I got it & it sucked ).
      Aside from the cluster issues the only other issue I noticed over the last 5 months I dailied it to work (about the last 6k miles@ 45mpg) is that for some reason i'm getting oil into the antifreeze reservoir. I am at a loss as to why it is moving from oil into antifreeze and NOT moving from antifreeze to oil....but after draining oil there is no trace of coolant in the oil?
      That being said this is a good project for someone to continue. Im just ready for a new car
      Anyhow...pics:
    2. Member Corrado118's Avatar
      Jan 4th, 2012
      Annville Pennsylvania
      1995 Volkswagen Golf, 1990 Volkswagen Corrado, 1988 Volkswagen Jetta Vr6
      05-23-2012 09:42 AM #2
    3. Member Darkmark's Avatar
      Dec 18th, 2009
      05-25-2012 12:28 PM #3
      Shoot me offers...i wont be offended
    4. 05-25-2012 05:02 PM #4
      $500
      98 JETTA TDI PP764s, RC3, 5deg adv, 0.68 5th, Kerma downpipe, IP and timing tweaks
      97 Ford F-250 Crew Cab 4x4 7.3L Powerstroke
    5. Member Darkmark's Avatar
      Dec 18th, 2009
      05-25-2012 09:22 PM #5
      Now thats a start..! 900 and its on to its next owner
    6. Member Darkmark's Avatar
      Dec 18th, 2009
      05-26-2012 01:09 PM #6
      It runs, it drives...All the parts are there. Make an offer or its gettin cut up n goin 4 scrap! Im tired of looking at it sit here!!!
    7. Member Darkmark's Avatar
      Dec 18th, 2009
      05-31-2012 07:30 PM #7
      Lets get it gone. Dont want my house to look like a junkyard with pieces of dub layin around...UP!
      $900
    8. 06-01-2012 06:41 PM #8
      $500 still on the table
    9. n00b jcb4tdi's Avatar
      Jun 4th, 2012
      Dunellen Nj
      1992 Calypso Golf gl
      06-04-2012 03:15 PM #9
      Do you still have the car?
    10. Member Darkmark's Avatar
      Dec 18th, 2009
      06-05-2012 09:47 PM #10
      SOLD
    « Back
