interested in trade and cash on top....
one lap of america is over. Car build is over...Time to build a new car to promote the business and build for one lap next year. This car has completed its job for us and is now for sale. This R32T was a great car, fast, handles and great to drive! it will be missed but its time for a new project....so this one must go!
2004 R32 turbo full built. All new or super low miles. 36k miles on the car. Under 3000 on drive train. Street legal road track race car. Over $42k invested not including labor. We have SO much into this car. Someone will get a great deal on a pre built, low mile built car verus paying for all the parts and labor to build it!
Now the long list.....
-C2motorsports tune, no SAI, no cat. 550 fuleing, 2nd inline pump, 4'' intake and maf
-IE rods and JE pistons Forge internals with arp everything. fully machined and all new block and head. valve job etc. ALL NEW gaskets, waterpump, chains, guides, tensioners etc
-Mk5 baffles plated oil pan and new pump,
-new Southbend clutch and flywheel.
-Innovative Design & Fabrication Tubular control arms and modified ball joints.
-H2sport Camber plates.
-Rear adjustable arms.
-14.5" 2 piece rotors with 996 front bbk.
-Rear ECS 13.1 2 piece bbk.
-3" turbo back no cat, passes emissions.
heat wraped downpipe, wg tube, cables, firewall, intake manifold underside etc
-Water cooler tial mvr wasteagate.
-new Precision 6265 s-trim- 4'' inlet and 2.5 out, 3'' vband .82 ar exhaust.
-Auto power race cage.
-Yarrowsport rear strut bar.
-Hockis hollow race adjustable swap bars.
-CAE vwms shifter.
-Momo wheel.
-boost and AF Gauges.
-bigger Aluminum rad. Low temp fan and tstat.
-Brass subframe bushings and shifter mounts.
-Bilstien pss9.
-Bildon wheel stubs and steel race lugs.
-HPA awic intake manifold and a 2x12x24 core and rear water box.
-Forge Super dv. 4" intake and air box.
-Brail 7lb battery.
-Lightened 380lbs. Carbon hatch and hood. No rear seat. Still has AC and radio.
-5 1552 Tarmac 18x8.5 wheels with 5 new dunlop tires and 4 65% used tires.
-Carbotech 10 race pads and new street front pads.
-No rubber anything in front end.
-Lightened crank pulley.
-SS brake lines.
-Dual stage boost controller.
-HPA comp haldex cotroller.
-pull fire system in engine bay(needs a bottle)
-real, not show tow hooks front and rear
-BFI green stg3? motor mounts
-5 point harness,
-carbon hood and hatch. have factory hatch still
-all new fluids
-still has full front interior, ac, ps and radio- kept for one lap comforts
-has a wrap on the sides, paint and body is very clean. no damage at all, no crashes, no repaint on any parts! stickers and wrap can come off with now issue.
-has a velo driver seat. you will have to pay extra for the seat if you want it(not mine, borrowed for the year) i have a stock golf seat in the pass side because it is the lightest of all vw seats. i will include another stock golf seat for the drivers seat if you do not with to buy the velo. best race seat i've ever used though! velo's are amazing!
-may have forgot a few things! will add more when i think of them
car is 100% street legal and registered and inspected/emission tested in PA as of now. i drove it for a daily to break in things.
asking $32Kobo without the velo seat. includes everything above. will not part out.
possible trades depending on what it is. mostly looking for cash, a lotus, mk1 plus cash, etc
as the car looks now.
front end off(not now)
