VWVortex.com - The deal with timing chains/belts on the 2.5
    Results 1 to 10 of 10
    Thread: The deal with timing chains/belts on the 2.5
    1. Member ajd187's Avatar
      Feb 6th, 2012
      Palmyra, NY
      05-22-2012 12:18 PM #1
      What's up with timing chains/belts on the 2.5 engine?
      This weekend I mentioned to a friend that I had gotten a VW. He used to own an 00 Jetta and said "do the timing chains when they say to, it's expensive when you don't", and then went on to recount a story about his car and a timing chain failure that led to an $1800 repair.
      I know that was before the 2.5 engine was out and it looks like this was a VR6, a 1.8, or a 2.0T.
      On my 09 2.5 do I need to worry about the timing chains/belts and a change interval? I recall reading somwhere that these are "lifetime" belts but I wasn't sure if that was the case.
      2008 Ford Fusion SEL (Grandma edition)
      Quote Originally Posted by J-Tim View Post
      Still fail to see how a jacked up hatchback or wagon is better than the standard height one. Yes, putting the kid may require you to bend down a bit, but if the car is German, you're kind of used to that anyway.
    2. Member LampyB's Avatar
      Apr 2nd, 2007
      Boston
      MKVI GLI + Rabbit
      05-22-2012 02:18 PM #2
      no, you're good to go on your '09 model's timing chain. it will last a very long time, and i believe it's technically rated by VW as a lifetime part. the only years that experienced premature issues with the timing chain were '05-'07 2.5l models, and it wasn't the chain itself the plastic guides wore down easily. from '08+ we're good to go!
      your buddy's old car most likely had a rubber belt, which should be replaced around the 75K mile mark. and often it was the water pump that went bad before the timing belt on the older models that caused everything to blow out.
      2006 GLI / 2008 Rabbit - United Motorsports (used to be Flex Fuel)
      Quote Originally Posted by pete@blackforest View Post
      I remember when people modified their Volkswagen to enhance the driving experience. What ever happened to Fahrvergnugen?
      Bags are for kids that grew up watching Pimp My Ride. Turbo is for all of us that enjoy actual motorsport.
    3. Member ajd187's Avatar
      Feb 6th, 2012
      Palmyra, NY
      05-22-2012 09:21 PM #3
      After I posted this I saw that the recommended interval in the manual was 110K miles, "where applicable".
      I have another friend who has an 07 Wolfsburg which I think is the 2.0T, and she was complaining about the cost of some maintenance at a 70K service interval.
      Good to know that it is good to go. I figured as much, this seems to be a newer improved breed of VW engine.
    4. 08-24-2012 02:49 PM #4
      I just picked up a clean 07 2.5 Jetta, are there updated plastic guides that I could put on that would remedy this issue?
    5. Member alwaysdutch's Avatar
      Oct 19th, 2011
      Marietta, GA
      2005.5 Jetta 2.5 Package 2
      08-25-2012 12:32 AM #5
      Yes. If you buy the guides now, you will get the ones that will be good. However, you will probably also need tensioners, a new chain and some tools to do this job. There are many threads about this matter....
      **- 2005.5 VW Jetta Package 2 with 2008 2.5L -**
      BFI stage 2 transmission mounts
    6. Awaiting Email Confirmation pete@integrated's Avatar
      Jan 1st, 2009
      Salt Lake City, UT
      '92 Gti 20v, '96 M3, '10 Shop Van :)
      08-25-2012 01:09 PM #6
      We're actually putting together two kits- one with the parts to rebuild the upper chain, and one to rebuild ALL the chains.
      We made the cam locking tools, so they are cheaper then the OE ones. The whole thing should be quite reasonable. Time to see some of these engines getting FIXED, not replaced.
    7. Junior Member
      Sep 19th, 2011
      Golden Lake
      2006 Jetta 2.5L
      08-27-2012 12:09 PM #7
      Quote Originally Posted by pete@integrated View Post
      I have an '06 with approx. 116,000km (72,000 miles), no issues so far (knock on wood), but I would be happy to have the peace of mind with replaced, updated parts.
    8. Member quaudi's Avatar
      Jun 25th, 2001
      Cincinnati
      2004 DBP .:R32, 2013 JSW 2.5S MT
      09-11-2012 10:49 AM #8
      Did upper and lower chains on my 05.5 VE at 132000 miles. Slight stretching in chains due to metal wear but other than that, never a problem. All new components in there now. Cannot believe how quiet and smooth and responsive the engine is. I'm sure syn oil changes every 5K had a bit to do with the chain life.
      Also just had my first part failure at 138000...right side rear wheel bearing.
    9. Member Gott ist gut's Avatar
      Jul 2nd, 2010
      Sarasota, FL
      2007 Jetta 2.5l
      09-11-2012 04:59 PM #9
      Quote Originally Posted by quaudi View Post
      Good to know Quaudi.
      I've been stressing about my timing chains, did you purchase the pieces separate or buy the IE kit? How much did you pay for parts? Did you install yourself? And I'm at 101k and my front right bearing started howling about 5k miles ago.
    10. Member quaudi's Avatar
      Jun 25th, 2001
      Cincinnati
      09-11-2012 05:51 PM #10
      Quote Originally Posted by Gott ist gut View Post
      I never stressed about the chains, just always changed oil religously. I purchased a complete kit from ECS Tuning for about $550. It is a pretty heavy duty job to do upper and lower chains so I had a great indie shop perform the work. The ECS kit has absolutely everything needed. As I mentioned earlier, the new chains and components worked wonders on the car. As the tech explained to me, its a job that addresses a lot of adjustments and settings that over time slowly deteriorate. It is a very noticeable difference. FWIW, I'm not a big fan of ECS but their kit for this is fantastic. A to them for this.
