Results 1 to 7 of 7
Thread: engine code gone...
  1. Junior Member new87gtiowner's Avatar
    Apr 13th, 2012
    Beautiful British Columbia, Mission BC
    87 1.8l 8v gti, 87 Cabby
    05-22-2012 02:16 PM #1
    Is there any other place way to find it
    TIA
    Cleaned it up and still no codes
    87 gti 8v
    You are all right!!! Bentley is the ONLY manual
    http://brokevw.com/
    Great guys in Maple Ridge
    http://www.eurowerk.ca/
    Apr 16th, 2006
    Brokelyn, NY
    90 fox, 85 gli
    05-22-2012 08:07 PM #2
    you have reason to believe the engine was changed? should be rd
    I really suck at smog.
    Mar 31st, 2008
    PNW - Oregon
    05-23-2012 01:28 PM #3
    prolly a GEX engine, or block..
    they didnt come with engine codes..
  4. Junior Member new87gtiowner's Avatar
    Apr 13th, 2012
    05-23-2012 09:34 PM #4
    i had a thought that may be the case and bang on you were correct, found a yellow sticker with another one directly under coated in oil etc. Gingerly peeled it off and cleaned it up and voila it is an EXCHANGE sticker with the statement MAY BE USED WITH ENGINE CODE HT
    so i am going to gather it is an HT
    [IMG][/IMG]
    http://brokevw.com/
    Apr 16th, 2006
    Brokelyn, NY
    90 fox, 85 gli
    05-24-2012 12:06 AM #5
    HT motors were used in 85 GTI/GLIs, although I'm not sure if it's the same for Canada. The RD superceded it in 86, although there aren't really any major differences that I'm aware of. The RD has a better cam and 4-2-1 exhaust setup. The HT had the 4-1.
    Not sure if that sticker means it's an HT or that it can be swapped in place of an HT without issue. Do a compression test and you should be able to semi-conclude whether it's a high compression motor or not.
  6. Junior Member new87gtiowner's Avatar
    Apr 13th, 2012
    05-24-2012 01:11 AM #6
    thanks after i posted i did a search and as you said that is an 85 motor. I suspect that it may be a reverse swap or ? The compression test is what i will do this coming weekend and I will let you all know the results, i'm sure your all waiting with bated breath for the nOOb to find out
    So i can check the compression or simply check the exhaust setup i gather?
    Thanks again for the info
    D
    Last edited by new87gtiowner; 05-24-2012 at 01:14 AM. Reason: additional info asked
    http://brokevw.com/
  7. Junior Member new87gtiowner's Avatar
    Apr 13th, 2012
    05-24-2012 01:50 AM #7
    Quote Originally Posted by Glegor View Post
    A pic of where the code should be
    [IMG][/IMG]
    also there is another sticker on the block which has a vw stamp and states vw remanufacturing
    you can see a sliver of it in the pic bottom left which leads me to belief it is not a gex but still not sure
    http://brokevw.com/
