any chance you'd have an engine cover?
#1
SOLD:
- Speedometer cluster
- Engine
- Door Handles
- Front Seats
- Rear springs
- Front Motor Mount bracket
- Injection Pump
- three Pedal cluster
- shifter cables with box
- mounting bracket for Booster and clutch
- Engine wiring harness
- Turbo with manifold
- Front subframe (but I have one more)
- Fuel Level Sender
- Compressor
- 120A Alternator
All prices include shipping unless stated otherwise
- Transmission: $350. no shipping, unless you pay an extra $150
- clutch line from master to slave: $50
- pass side axle: $50
- 'BK' ECU: $125
- Cooling harness: $50
- Cluster harness: $50
- Injector hard lines: $75
- Intake manifold: $75
- Alternator/Inj Pump carrier bracket (cast iron): $95
- Alternator/AC carrier bracket (cast alum): $60
- Turbo inlet pipe (plastic): $30
- Turbo outlet pipe (alum): $55
- Intercooler piping (plastic): $85
- Intercooler: $50
- Accessory belt Tensioner & roller: $35
- Downpipe with flex and CAT: $140
- Like-new OEM VW Exhaust: $150 - PICK UP ONLY
- Turbo oil return line: $45
- Turbo oil feed line: $45
- Vacuum pump: $40
- Starter: $75
- PS bracket: $25
- Fuel lines from filter to IP: $30
- Upper TB cover plastic: $30
- Coolant glow plugs/housing: $30
- Front subframe with rad support: $80
also have hood, grille, headlights, bumpers, rad-fans, radiator/condenser, and a bunch of other stuff I'm forgetting.
#2
99.5 Jetta TDI GL - T Red: DLC520 Nozzles, ASR Retrofit, VR6/1.8T Brakes, F&R Fogs, GLI Tails, Red/Black Sports Seats, Rear Sunshade
#4
How much for the O2A front motor mount bracket and starter?
#6
Still have the motor tranny and ecu? If so maybe some sort of package deal?
Rocco's getting a TDI!!!
#7
I have the motor/trans/ECU and the complete harness, yes. I will not ship to Oregon, unless buyer arranges shipping.
#9
thanks for the mm bracket.great seller and super quick shipper
DO NOT BUY FROM 2.8DOHCVTACH (now is harryballzonya) HE IS A SCAMMER
#10
I need the front caliper carriers(only) Might you still have those?
#12
#15
PM'd
#16
Hey I need a few parts...
pedal assembly
body side engine wiring harness
brakebooster/clutch master
front lower subframe
let me know
Thanks![]()
#19
#20
If you still have the ecu, what are the last two letters on the model#?
#22
#23
