Results 1 to 10 of 10
Thread: P1113 & P0134 codes?
  1. Member caveman1's Avatar
    May 16th, 2011
    wasaga beach
    1997 golf vr6 sold, 2000 bora 1.8t sold, 2000 jetta vr6
    05-22-2012 04:20 PM #1
    these codes keep popping up. i replaced the precat o2 sensor 3 times within 6 mnths. 2 aftermarket bosch & the last an oem from the stealer. is there anytin else that could be wrong? could the octane level in shell 91 be too high that it keeps burning it out? its a 2000 bora 1.8t completely stock with a cai & resonator delete. motor has 240,000 kms & all maintenance is done with oem parts.
    Lowered black jetta with yellow hid's, roof racks and always in winter mode.
  2. Member caveman1's Avatar
    May 16th, 2011
    wasaga beach
    05-22-2012 05:26 PM #2
    bump
  3. Moderator groggory's Avatar
    Apr 21st, 2003
    Long Beach, CA
    2002 VW GTI 1.8 BT
    05-22-2012 05:33 PM #3
    Do you have vag com?
    My Build
  4. Member caveman1's Avatar
    May 16th, 2011
    wasaga beach
    05-22-2012 06:33 PM #4
    not yet. still waiting on my cable. i used a generic matco tool scanner.
  5. Moderator groggory's Avatar
    Apr 21st, 2003
    Long Beach, CA
    2002 VW GTI 1.8 BT
    05-22-2012 06:36 PM #5
    Until the vag com gets here go do some tests.
    * Check all your grounds. Fix anything that isn't grounded nicely.
    * Check your alternator cable. Ensure it is working at low resistance.
    * Seafoam test for exhaust leaks (with a rag in the tail pipe). Fix all leaks
    * Pressure test your intake to 10 psi. Fix all leaks.
    Post back when all that's fixed, what you found, and when you have your vag com. There are some vag com tests that'll tell more.
    My Build
  6. Member caveman1's Avatar
    May 16th, 2011
    wasaga beach
    05-22-2012 06:43 PM #6
    ok thanks. it might take about a week because my free time is very limited. i hope to have my cable by then, but i will keep you informed. thanks!
  7. Member caveman1's Avatar
    May 16th, 2011
    wasaga beach
    05-22-2012 06:45 PM #7
    quickly before i venture into the unknown. might sound stupid, but, how do you pressure test your intake?
  8. Member turbo2205's Avatar
    Apr 30th, 2005
    IA
    '03 jti 1.8t
    05-22-2012 07:28 PM #8
    click the link in groggorys sig n you'll find the diy in there
    or i believe its also at the very top of this forum now
  9. Member caveman1's Avatar
    May 16th, 2011
    wasaga beach
    05-22-2012 07:38 PM #9
    thank you found it. i should of looked there first will keep everyone posted
  10. Member caveman1's Avatar
    May 16th, 2011
    wasaga beach
    06-19-2012 02:19 PM #10
    just to update everyone. found a couple craked vacuum lines. car runs great, boost is up there and gas mileage is excellent. cleaned and replaced several grounds also, no exhaust leaks. still dont have a vagcom. cel is showing p1113 and p1128. could my egr valve and combi valve be on the way out?
