Page 4 of 4 FirstFirst 1 2 3 4
Results 106 to 119 of 119
Thread: What's wrong with your car?
  1. Member simple's Avatar
    Mar 29th, 2001
    Golden, CO
    Subaru OB XT, Previa LE S/C Alltrac
    05-23-2012 11:45 AM #106
    Outback Rear brake pads and rotors.
    Maybe new clutch this year
    Previa Fuel Pump (drained tank last night)
    EGR Valve line clean out
    Rewire stereo w/ factory amp & sub
    Replace leaking coolant hose at engine
    Find oil leak (gasket)
    Flush differentials
    The Previa list was a lot longer just 2 months ago. I've been plugging away at it
    If you can't measure it, you can't understand it; if you can't understand it, you can't control it.
    Sep 15th, 2001
    The PNW
    '12 CW Golf TDI, 2013 Evil Undead
    05-23-2012 12:32 PM #107
    The problems with my car:
    It's a B5 A4
    A/C compressor has siezed
    Interior lights are inoperable (central locking control unit)
    Needs clutch
    Needs tires, uneven tire wear even with good alignment and new CAs/TREs
    Puking oil out of the front crank seal
    Front left door speakers are inoperable (door wiring harness)
    Left headlight has condensation
    Crack in one of the foglights, yellow film prevented worse damage and is holding it together
    Bearing noise from front end, haven't isolated it yet
    Minor leak at rear diff, level is ok
    Missing lower engine cover
    Tear in center armrest cover
    Front bumper cover is misaligned
    Various small scratches and dings, nothing out of line for age/mileage/use
    Repairs and maintainance since I've owned the car (Oct 2006, started at 117k, now at 197k:
    ABS control module
    Cam tensioner seals (x2, V6)
    Tie rod ends (x4)
    Front brake pads and rotors
    Tires (a few times)
    Wheel bearings (x3)
    Timing belt/water pump
    Suspension (PSS9s and Bilstein HDs)
    I feel like I'm forgetting a few things.
    At least the heated seats work.
    Lately I have been testing "tip-in events". Just the tip-in. Just to see how it feels. Response time is typically on the order of 2-3 seconds. Sometimes the injection timing is a little off...
    May 26th, 2006
    Chattaboogie, TN
    2011 GTI #yolo
    05-23-2012 12:37 PM #108
    2011 GTI:
    Nothing has gone wrong in 33,000 miles. This is honestly the first time I have EVER owned a VW (or any car for that matter, though I have owned 4 VWs and 1 Hyundai) that didn't have at least one thing broken.
  4. Member FBMphil's Avatar
    Feb 18th, 2006
    Chicago 'burbs
    Focus hatch
    05-23-2012 12:38 PM #109
    Woke up this morning to a cracked thermostat housing and a puddle of coolant in the driveway
  5. Member BMW4L1F3's Avatar
    Oct 7th, 2004
    East Mesa, AZ
    1992 BMW 325i (gone), 1997 GTI VR6 Sequoia Green (Parting soon), 2013 Jetta Sportwagen
    05-23-2012 12:43 PM #110
    Engine coolant temp is running 1 notch warmer than normal. fans are working, coolant isn't leaving. hmmmm. gonna check tstat, but I think it might be the secondary waterpump. any way to test it?
    Josiah "Mac"
    '97 GTI VR6: GIAC, Schrick Intake Manifold, TT-catback.
    VRSociety Member #114
    '13 Jetta Sportwagen TDi DSG Tempest Blue - Stock, for now
  6. Member chickenium's Avatar
    Aug 10th, 2007
    2006 Cayman S
    05-23-2012 12:59 PM #111
    07 GTI : Aux input doesn't work even after 300$ worth of time at the dealer.
    **** JUST GOT CHAEL
    May 26th, 2006
    Chattaboogie, TN
    2011 GTI #yolo
    05-23-2012 12:59 PM #112
    Quote Originally Posted by BMW4L1F3 View Post
    You'll hear your secondary waterpump keep running after you shut your car off in a VR6
  8. Member BMW4L1F3's Avatar
    Oct 7th, 2004
    East Mesa, AZ
    05-23-2012 01:00 PM #113
    Quote Originally Posted by FissionMailed View Post
    i will have to test that today.
    Josiah "Mac"
  9. Member fighters_of_foo's Avatar
    Jan 4th, 2004
    Baltimore, MD
    05 Forester XT
    05-23-2012 01:11 PM #114
    Slight oil leak on turbo side and an odd idle probably from a vacuum leak somewhere, coming up on the 105k service but aside from that the Forester runs like a top!
    Quote Originally Posted by Señor Peligro
    Subaru wagons: Why go Euro when you could go lesbian?
    Aug 20th, 2010
    Illinois, USA
    1987 Scirocco DLX
    06-05-2012 10:01 PM #115
    Scirocco's old style parking brake lever needs to be customized again. The 3rd attempt at locking the notched piece to the body of the car. That little tab welded to the unibody is way underdesigned. Embarrassing to have to use a bar of aluminum or a piece of pipe to hold the lever up.
    Already have installed galvanized steel angles to reinforce the pivot pin area.
    Wish I could deduce how to convert to a newer design with one cable to the lever back to a force divider and then to each wheel. A very nice lever assembly from a 1985 Porsche is just sitting available.
  11. Member Kar98's Avatar
    Apr 20th, 2002
    DFW
    2007 Stark Industries Runabout 1500
    06-05-2012 10:17 PM #116
    Fog light lenses broken.
    High beam out on one side.
    Fascia under pass. side headlight hanging loose.
    Head light mirrors corroded.
    Pitted and cracked windshield.
    Circ. air button light out of order.
    Pass. side window doesn't roll up or down, probably off its rails.
    Key works only hatch and ignition, and barely in the latter.
    Awful racket when in reverse.
    Power locks don't.
    Suspension is in dire need of replacement.
    None of the doors lock, except driver's door, and that one only with the button.
    Mushy brakes.
  12. Junior Member Exhaust Muncher's Avatar
    Jan 31st, 2012
    NYC
    Pumas sized 11
    06-05-2012 10:20 PM #117
    Front brake pads and rotors seemed to have been glazed and even though I roughed them up moderately, they still give off an ear bending squeal.
    How close are you to Checkmate in this game we all call "Life?"
    *Best Thread on the Internet ----> Official Everything Dope Shizz Thread
  13. Member pontiac's Avatar
    Aug 3rd, 2009
    Nova Scotia, Canada
    06-05-2012 10:40 PM #118
    Could use a front bumper thanks to a hit and run and meeting a suicidal cat at 90kmh, and the back bumper has been run into a few times and could use a repaint, windshield has about a million rock chips, the brakes are mushy and front rotors are warped, aftermarket gas cap = constant CEL, It has a weird squeak in the front end and more rattles than every other car I've ever driven put together, and rides like s**t. I could afford something newer but for whatever reason I still like the POS and with the exception of one wheel bearing its been dead reliable for over 70 000k now and I just cant justify getting rid of it.
    Edit: just remembered the drivers door is pulled forward from betting caught in a gust of wind which busted the thing that tells wether the door is open or closed so the lights don't turn on when the drivers door is opened.
  14. Member Mosbius Designs's Avatar
    Dec 2nd, 2006
    2012 Honda HRX217, 2 Golfs, and a 944.
    06-05-2012 10:42 PM #119
    In the GTI, need to diagnose a boost leak.
    In the Porsche, too many things to mention
    The Golf is doing good so far.
    I love all cars, I just happen to own a few pieces of german crap at the moment.
