Results 1 to 29 of 29
Thread: Cam position sensor or Engine speed sensor?
  1. Member BIG DUB's Avatar
    Feb 13th, 2001
    MD/VA/DC Area
    1980 turboed moped
    05-22-2012 04:27 PM #1
    I took the car out for a little spin about 8 miles. We where about .5 of a mile from the house and there is a section where you have to stop on a little bit of a hill. I stalled the car due to the new Dm clutch then headed to the house and the car started to run like crap. I hooked up VAGCOM and had this code:
    17748.P1340 camshaft position sensor-G40/ Engine speed sensor-G28: incorrect allocation(#1)
    I swapped out the 2 cam position sensors and cleared the code and started the car and it still ran like crap. I just happen to have a new Cam position sensor(hall sensor) so I swapped it out in both cam positions one at a time and cleared the code and the car still runs like crap.
    Is there a way to check(test) with vagcom to see if its one of the engine speed sensors?
  2. Member fouckhest's Avatar
    May 22nd, 2003
    Up on the Mtn
    Danger Ranger
    05-22-2012 04:36 PM #2
    typically if an ESS is bad you wont be able to start the car...now granded i have only dealt with this on 1.8t's...but the tell tell sign if an ESS is bad is that when you crank the car over the tach will not move....
    you had the head off didnt you? are you sure that your not off a tooth on the timing? i know several people who have played hell with timing 24v VRs....
    good luck mate!
  3. Member haf1zur's Avatar
    Feb 20th, 2006
    UK Golf R32 2004
    05-22-2012 04:53 PM #3
    G40 is the camshaft position sensor towards the front of the engine
    Is it loose?
    Do you get the same error when the cable is disconnected from the connector?
  4. Member BIG DUB's Avatar
    Feb 13th, 2001
    MD/VA/DC Area
    1980 turboed moped
    05-22-2012 06:34 PM #4
    Quote Originally Posted by haf1zur View Post
    Is it loose?
    No its not loose, I know that was a common problem: the sensors getting loose.
    the car runs like crap either way..
    Runs rich and idles like crap and vaccum is only-2 or so
  5. 05-22-2012 06:44 PM #5
    Quote Originally Posted by BIG DUB View Post
    tooth out on the timing...or you have a bad chain tensioner in the back of the head....
    MK4 R36 x Precision 6776 Turbo = Large Grin
  6. Member BIG DUB's Avatar
    Feb 13th, 2001
    MD/VA/DC Area
    1980 turboed moped
    05-22-2012 10:05 PM #6
    Quote Originally Posted by Slapbladder View Post
    I replaced the chains and tensioner and sliders. I removed the valve cover and the chain is tight as can be and everything else looks good.
    I'll check TDC on # 1 tomorrow when i get home from work. And I have never seem a car with chains jump a tooth. Now a worn belt is different.
    I'll try to test the speed sensors..
    Thanks again for all the help.
    May 30th, 2006
    Mesa, Arizona
    '04 R32 - '95GTIVR6 - '02 TTQuattro
    05-22-2012 10:31 PM #7
    So, you replaced the chains. did you time the intermediate gear correctly?
  8. Member BIG DUB's Avatar
    Feb 13th, 2001
    MD/VA/DC Area
    1980 turboed moped
    05-22-2012 10:40 PM #8
    Quote Originally Posted by Arizman3 View Post
    Its a fresh 3.3 forged motor built by RAI motorsports. I did not personally check the intermediate gear. I did check the timing,tensioner,guides before i installed the valve cover.
  9. Member BIG DUB's Avatar
    Feb 13th, 2001
    MD/VA/DC Area
    1980 turboed moped
    05-23-2012 09:50 PM #9
    So I removed the valve cover and coilpacks and plugs, and set the motor to TDC on the #1 Cylinder. Now keep in mind that I run a the Nuespeed aftermarket crank pulley, but when I installed it I put a paint marker spot on it so I could time the crank.
    I don't have the cam timing tool so i used a ruler and it slide it pretty easy when I got the motor timed and then I checked the chain rollers between the cam timing marks and got 16 but the marks dont line up properly
    Is it possible that the chain is to tight with the new tensioner and guides? I have heard of this problem with guys running head spacers-But I am not running one but the chain seems to be super tight?
  10. Member spitfire481's Avatar
    Mar 20th, 2007
    Baltimore Md
    04 GTI 24vT, 2013 FR-S
    05-23-2012 11:07 PM #10
    jay, did you rotate both cam adjustment sprockets before setting the timing? if i remember correctly both need to be rotated towards the firewall until they stop, then you can continue setting the upper timing, 16 rollers, etc. its been a few years since i put my cams in but i did remember rotating the sprocket
  11. Member spitfire481's Avatar
    Mar 20th, 2007
    Baltimore Md
    05-23-2012 11:09 PM #11
    found the pic i used when i did it
  12. Member BIG DUB's Avatar
    Feb 13th, 2001
    MD/VA/DC Area
    1980 turboed moped
    05-23-2012 11:11 PM #12
    I'm not sure Bro RAI timed it, I'm looking at redoing everything soon to make sure its in time.
  13. Member spitfire481's Avatar
    Mar 20th, 2007
    Baltimore Md
    05-23-2012 11:21 PM #13
    hit me up if you do, ill come over and hang out and look it over with you. a second look never hurts
  14. Member BIG DUB's Avatar
    Feb 13th, 2001
    MD/VA/DC Area
    1980 turboed moped
    05-23-2012 11:26 PM #14
    i may knock it out tomorrow or Friday. Cheers Bro
  15. Member BOUDAH's Avatar
    Aug 15th, 2008
    Eldersburg, MD
    '04.:R32 , '13 CC
    05-23-2012 11:34 PM #15
    remember to check for the oil rings
  16. Member BIG DUB's Avatar
    Feb 13th, 2001
    MD/VA/DC Area
    1980 turboed moped
    05-24-2012 06:16 PM #16
    Quote Originally Posted by BOUDAH View Post
    Will do
  17. Member BIG DUB's Avatar
    Feb 13th, 2001
    MD/VA/DC Area
    1980 turboed moped
    05-24-2012 07:02 PM #17
    Is there a way to check the engine speed sensors with vagcom
  18. Senior Member PowerDubs's Avatar
    Jul 22nd, 2001
    NWNJ
    05-25-2012 12:49 PM #18
    Out of time. Off a tooth. Do over. Very common.
    Also, the oil you mentioned on your PM is very common on a newly rebuilt engine until everything wears together and seals up. Problem is, many bored motors never seal right ever again.
    - Josh
    -Josh
  19. Banned ThatVdub's Avatar
    May 28th, 2010
    Jax, FL
    Golf R
    05-25-2012 01:10 PM #19
    i see u have a bentley, did u follow EVERY step to the T, obviously not.
    not to be rude, but you should not do a job like that without doing everything precisely.
    do every step, not just tdc and cam orientation.
  20. Member BIG DUB's Avatar
    Feb 13th, 2001
    MD/VA/DC Area
    1980 turboed moped
    05-25-2012 01:14 PM #20
    Quote Originally Posted by ThatVdub View Post
    Thanks for your input... No i didnt time the motor a paid a shop to do it and its a tooth off so im retiming everything, now..
  21. Banned ThatVdub's Avatar
    May 28th, 2010
    Jax, FL
    Golf R
    05-25-2012 01:28 PM #21
    No i didnt time the motor a paid a shop to do it..
    Damn! Well, at least it will be corrected.
  22. Member spitfire481's Avatar
    Mar 20th, 2007
    Baltimore Md
    05-25-2012 01:30 PM #22
    the reason i trust no shop...
  23. Member BIG DUB's Avatar
    Feb 13th, 2001
    MD/VA/DC Area
    1980 turboed moped
    05-25-2012 01:31 PM #23
    Well i was new to the area and didnt have all my tools at the time. I'll get it figured out.
  24. Member spitfire481's Avatar
    Mar 20th, 2007
    Baltimore Md
    05-25-2012 01:36 PM #24
    yea i know. i wish i knew of somewhere better that i could have referred you to but i try to avoid shops in general, so i dont really know who is good and who is not
  25. Member BOUDAH's Avatar
    Aug 15th, 2008
    Eldersburg, MD
    '04.:R32 , '13 CC
    05-25-2012 02:55 PM #25
    I like NGP but they are a tad pricy.
  26. Member BIG DUB's Avatar
    Feb 13th, 2001
    MD/VA/DC Area
    1980 turboed moped
    05-25-2012 03:31 PM #26
    Oil rings are installed boss
  27. Member BOUDAH's Avatar
    Aug 15th, 2008
    Eldersburg, MD
    '04.:R32 , '13 CC
    05-25-2012 05:17 PM #27
    Huh ok
  28. Member BIG DUB's Avatar
    Feb 13th, 2001
    MD/VA/DC Area
    1980 turboed moped
    05-25-2012 07:26 PM #28
    Rai is coming to get the car and redo the timing.
  29. Member BOUDAH's Avatar
    Aug 15th, 2008
    Eldersburg, MD
    '04.:R32 , '13 CC
    05-26-2012 12:20 PM #29
    Cool cool
