Results 1 to 4 of 4
Thread: Leak @ Crank Position Sensor? OBDII ABA
  1. Member boraIV's Avatar
    Jan 8th, 2001
    six.oh.two.
    '13 Cayenne Diesel, '08 Passat Variant 2.0T Stg 2, '81 ABA Caddy
    05-22-2012 06:17 PM #1
    I have a caddy with an ABA swapped in it and there is an oil leak at the CPS. Is this fairly common? At first I thought it was because I was missing the o-ring, which I was. I have since add one and it didn't seem to stop the issue.
    Any insight?
    Mar 6th, 2002
    Morris Plains/Parsippany, NJ
    1998 GTI 2.0
    05-22-2012 10:48 PM #2
    No, it's not a common failure.
    Make sure you've the correct O-ring. Make sure the sensor and hole are clean, and the sensor isn't damaged from being installed without an O-ring. Install the sensor with the O-ring and a little sealant.
    1998 GTI 2.0
    1993 Jeep ZJ 4.0
    World Automotive
  3. Member dan0954's Avatar
    Mar 4th, 2009
    Southeast
    96 Jetta GL, 98 Jetta Wolfsburg
    05-22-2012 11:43 PM #3
    I think I read about it once when I was having the same problem. Anyway he used sensor safe silicone and it fixed his problem. I tried the same thing and the problem went away and that was a long time ago.
  4. Member boraIV's Avatar
    Jan 8th, 2001
    six.oh.two.
    05-24-2012 03:33 PM #4
    Thanks guys!
