Results 1 to 32 of 32
Thread: Need a clutch Kit for my car by the weekend
  1. Member B0rin's Avatar
    Apr 13th, 2010
    Barrie, Ontario
    04 .:R32 ,02 Jetta 1.8T,04 GrandPrix GTP CompG, 05 Envoy
    05-23-2012 09:08 AM #1
    Morning
    I think this is a long shot but I need a new clutch kit and throw out bearing for the .:R by the weekend any ideas ? Ecs wouldn't be able to get it in time, Something local would be best. I'm trying to avoid bring it to a shop to get her fixed because it would cost way to much, plus I just had the steering rack replaced, almost 3 weeks ago.
    the goal is the have the car back on the road for Spring Fling
    Thanks
    R32 Registry#867 WiTW '13
    Follow me on Instagram & TheTechSource YouTube Page
    PM Me about if you need Vagcom scan in the GTA or Barrie area
    - 2002 Vw Jetta1.8T
    - 2004 Vw Golf .:R32
  2. 05-23-2012 10:11 AM #2
    All the Worldpac sites show a Luk kit in stock for an R32.
  3. Member B0rin's Avatar
    Apr 13th, 2010
    Barrie, Ontario
    05-23-2012 10:30 AM #3
    Quote Originally Posted by GrahamRam View Post
    Thanks man Ill give them a call
    - 2002 Vw Jetta1.8T
  4. Member B0rin's Avatar
    Apr 13th, 2010
    Barrie, Ontario
    05-23-2012 10:36 AM #4
    I just called worldpac, he said they only sell to shops, and doesnt know what a R32 is . How did you find out they had the Clutch in stock and how would I order it
    - 2002 Vw Jetta1.8T
  5. Member Zookie's Avatar
    Jan 5th, 2004
    Toronto, Bombay, Kuwait
    Porsche 996 C4S, VW Passat B5.5 Sedan & VW Jetta VI Sedan
    05-23-2012 11:04 AM #5
    Zook – SCB | www.SportsCarBoutique.com Follow Us On www.facebook.com/SportsCarBoutique
    BOUTIQUE & TUNING: 905-731-0700 | 85 GLEN CAMERON ROAD, TORONTO, ON L3T 1N8 zook@sportscarboutique.com
    AUTHORIZED DEALER: Alpinestar, BMC Air Filter, Braille Battery, EVOMS, HJC Helmets, H&R, HANS, HRE Wheels, Pagid RS, Racelogic, Recaro, Motul, Schroth Racing, Stilo.
  6. Member JOHNS92JETTA's Avatar
    Mar 2nd, 2003
    Markham
    '92 Jetta 2.1L 16V, '08 Mazda3 GT
    05-23-2012 11:45 AM #6
    Quote Originally Posted by B0rin View Post
    Most sponsers in the FAQ use Worldpac. Carquest uses Worldpac too.
  7. Member B0rin's Avatar
    Apr 13th, 2010
    Barrie, Ontario
    05-23-2012 01:20 PM #7
    Carquest FTW, they are in Barrie and should be in tomorrow Feels GOOD MAN! can not wait to have the .:R on the road again. now lets hope this will be the last repair for some time ****s getting expensive
    - 2002 Vw Jetta1.8T
  8. Member smithgtivr's Avatar
    Jul 5th, 2007
    '02 S4, '11 Ducati, '04 R32, '98 GTI VR6, '90 Audi Coupe, '84 Jetta Turbo
    05-23-2012 01:30 PM #8
    Whaaaa happened!!!!!!
    Throw a single mass flywheel in there while you are at it, fourseasons tuning sells a billet steel one.
    Plus you avoid the possibilities of the deaded hamster wheel down the road
  9. Member B0rin's Avatar
    Apr 13th, 2010
    Barrie, Ontario
    05-23-2012 01:47 PM #9
    Quote Originally Posted by smithgtivr View Post
    Why a single mass? I'm just going to stick with stock clutch set-up I don't plan on bolting much more power on it, Plus I just replaced the steering rack 3 weeks ago and one power steering line that wasn't the cheapest.
    Here is the story its a big long.
    Last week I was leaving our Northern Euros meet, went to start the car clutch went right to the floor didn't come back up. Lucky Dave (keepinitkleen) could drive the car with out use of a clutch so swapped keys dove home. Found she was leaking brake fluid Friday morning and could've get any pressure back in the clutch system on Saturday after I put brand new New rotors and pads all around because the slave cylinder was leaking and since its next to the clutch, brake fluid has gotten on the clutch and now I have to do a full clutch job well the .:R isn't the easiest to do this job.
    But I found this DIY/How to
    http://forums.vwvortex.com/showthrea...-Quick-Version
    I Just hope to have the car back on the road soon its sad walking past it everyday and not driving it
    - 2002 Vw Jetta1.8T
  10. Member Punjabi_Dubber's Avatar
    Mar 28th, 2008
    Bagged Slow 4 Door
    05-23-2012 04:16 PM #10
    I really hope you know what your doing.
    Plus, do it once and do it right. Spring fling shouldn't be a make or break deadline.
    bankrupt.
    SymproCNC.com im for all your machining needs (spacers, adapters, center cap spikes etc)
  11. Member JOHNS92JETTA's Avatar
    Mar 2nd, 2003
    Markham
    05-23-2012 04:51 PM #11
    From what I understand (atleast with Mazda) you can not machine a dual mass flywheel. On a regular flywheel you machine IT when you change your clutch. (Just like brake rotors) You might have problems if you just put the clutch in. Especially if you have fluid contamination.
  12. Member B0rin's Avatar
    Apr 13th, 2010
    Barrie, Ontario
    05-23-2012 08:09 PM #12
    Quote Originally Posted by Punjabi_Dubber View Post
    If it gets fixed or not I'm going to spring fling but it would be nice to have the car fixed for it and ride in my car if not Ill be filming the entire drive and taking rolling shots.
    Quote Originally Posted by JOHNS92JETTA View Post
    Last time I did a clutch on a car it was a regular flywheel but I dont see why a you would need a new one, the old clutch is in good shape. I think it should be good but we wont know till I pull it all out
    - 2002 Vw Jetta1.8T
  13. Member smithgtivr's Avatar
    Jul 5th, 2007
    05-23-2012 08:45 PM #13
    i was surprised to see this thread, as the clutch was done around 60k miles
    r32's have dual mass flywheels, and cant be refinished as far as i know.
    you should also consider doing the rear main seal while in there
  14. Member B0rin's Avatar
    Apr 13th, 2010
    Barrie, Ontario
    05-23-2012 11:54 PM #14
    I'm as surprised as you are man, it was working 100% the day before it happened, the clutch was grabbing strong no slip in any gear when in and out of gear. You saw the car the Sunday before it happened at the meet and it was driving great that day just a little dusty because it rained the night before. I'll Check out the seal since I'm there. Do you know if the Clutch Slave Cylinder / Throw Out Bearing was changed when the clutch was last done ?
    I haven't been doing any hard take offs or even driving it that hard at all for that matter just up and down the highway and to the go station and back.
    - 2002 Vw Jetta1.8T
  15. Member Scotty_2.0's Avatar
    Jan 13th, 2005
    North York, Ont.
    Mk2 GTI VR6... .......................Mk5 Rabbit 2.5
    05-24-2012 12:21 AM #15
    Clutch kits will almost always come with a throw out bearing, but not a slave cylinder - pretty much a given. I would also advise to go for a single mass FW. Far better feel and no moving parts to crap out. And do the rear main regardless (leak or no leak).
    /// VRSociety Member #298 /// Mk2 Milita-VR6 Battalion-2dr Regiment /// Instagram @scottyvr6 ///
    My 2.9L BVH build and the machine shop #%@- up that almost ruined it all.
  16. Member JOHNS92JETTA's Avatar
    Mar 2nd, 2003
    Markham
    05-24-2012 08:22 AM #16
    When you are installing new friction material (clutch or brakes) you need to start with a fresh surface to do it properly. With a regular flywheel you resurface it. This can not be done with a dual mass. So just installing the new clutch you might end up with problems later.
  17. Member B0rin's Avatar
    Apr 13th, 2010
    Barrie, Ontario
    05-24-2012 08:54 AM #17
    Thanks for the heads up, good think this Friday is pay day so Ill be ordering a new flywheel then.
    - 2002 Vw Jetta1.8T
  18. Member JOHNS92JETTA's Avatar
    Mar 2nd, 2003
    Markham
    05-24-2012 10:07 AM #18
    Check the price on the OE fly wheel first. You'll drop a brick! This is another reason people go to a regular flywheel.
  19. Member B0rin's Avatar
    Apr 13th, 2010
    Barrie, Ontario
    05-24-2012 11:55 AM #19
    So it looks like a OEM is about $800 HOLY FCK !, and a luk OE is 480 ish still ouch but not as bad.
    - 2002 Vw Jetta1.8T
  20. Member 6speedvr6's Avatar
    Jan 20th, 2008
    Ajax Ontario
    WOB 012[R]
    05-26-2012 07:13 AM #20
    If youre going to do it do it right Get a single mass lightweight flywheel and a reputable clutch. Sooner rather than later you will have problems with your flywheel. Just be prepared to put up with the chatter at idle.
    H&R Street coilovers and upgraded sway bars, Unitronic Stage 2 HPFP, Milltek TBE, BBS, VW.:Racing CAI, Autotech HPFP, CTS FMIC, HPA BBK, Diesel Geek SSK. Aasco Motorsports aluminium flywheel, Bully Stg 3 clutch, Haldex Race controller.
    SEM Motorsports 416-636-7575. Toronto. Simply Tire 416-916-9233.
  21. Member B0rin's Avatar
    Apr 13th, 2010
    Barrie, Ontario
    05-26-2012 10:58 AM #21
    Quote Originally Posted by 6speedvr6 View Post
    Iv drivin a car with a single mass I didn't like the chatter, plus I want to keep the car OEM I liked how it felt the clutch didn't make any extra sounds.
    - 2002 Vw Jetta1.8T
  22. Member The Maytag Man's Avatar
    Apr 5th, 2002
    Toronto,ON
    VW GTI 20th AE BMP, 1983 VW Rabbit GTI(sold), 1978 VW Rabbit L
    05-26-2012 11:03 AM #22
    this chatter at Idle you speak off....
    chatter or ticking??
    does it go away with a quick rev for a bit?
    Buy My Things!
    Buy My 20th!
    What She Order?
    ლ(•益•ლ) Why you no buy my stuff!?
    78 HÄRE
  23. Member B0rin's Avatar
    Apr 13th, 2010
    Barrie, Ontario
    05-26-2012 01:12 PM #23
    Quote Originally Posted by The Maytag Man View Post
    It wasnt my car that was doing it. A friend that was at the barrie meets he was telling me about his.
    - 2002 Vw Jetta1.8T
  24. Member 6speedvr6's Avatar
    Jan 20th, 2008
    Ajax Ontario
    WOB 012[R]
    05-26-2012 03:34 PM #24
    Chatter yes it goes away when you rev or are moving.
    Keeping it OEM I recommend you buy a new flywheel and Sachs or Luk clutch kit. OUCH.
  25. Member The Maytag Man's Avatar
    Apr 5th, 2002
    Toronto,ON
    05-26-2012 04:03 PM #25
    hmm, i wonder if thats what I hear from my 20th (1.8t) , i always thought it was valve ticking, but maybe its the flywheel?
    Buy My Things!
    Buy My 20th!
    What She Order?
    78 HÄRE
  26. Member Scotty_2.0's Avatar
    Jan 13th, 2005
    North York, Ont.
    05-26-2012 05:08 PM #26
    Have a feeling you guys might be confusing gear rattle with clutch chatter. Clutch chatter is typically from aggressive friction discs that grab quickly and don't slip so engagement is rough. Gear rattle is typically caused from light flywheels that don't dampen the power pulses from the engine as well so the gear teeth load and unload.
    Read this
  27. Member The Maytag Man's Avatar
    Apr 5th, 2002
    Toronto,ON
    05-26-2012 05:38 PM #27
    Whatever my 20th does, my mk4 8v did the same thing, tick tick tick tick a good rev and it went away for a bit but would always come back.
    Buy My Things!
    Buy My 20th!
    What She Order?
    78 HÄRE
  28. Member B0rin's Avatar
    Apr 13th, 2010
    Barrie, Ontario
    05-26-2012 06:10 PM #28
    I have the Luk Clutch kit in the trunk now I picked that up yesterday just Got to find a good price on a flywheel.
    - 2002 Vw Jetta1.8T
  29. Member Rizzyfbaby's Avatar
    Jan 25th, 2011
    Brampton
    Mk4 Golf 1.8t
    05-26-2012 09:12 PM #29
    I just got a CM fx300 and im debating on running the stock flywheel or a 14lb lightened one. any suggestions?
  30. Member B0rin's Avatar
    Apr 13th, 2010
    Barrie, Ontario
    06-01-2012 08:41 AM #30
    Ordered a new OE Flywheel and bolts but Im having a hard time finding the part number for the rear main seal , I found out the 3.2l uses the same one as the 2.8 24v Vrs so Anyone know the part number ?
    Thanks
    - 2002 Vw Jetta1.8T
  31. Member Scotty_2.0's Avatar
    Jan 13th, 2005
    North York, Ont.
    06-01-2012 09:23 AM #31
    At work, so no ETKA but according to MJM Autohaus the P/N is 068 103 051 G
    http://www.mjmautohaus.com/catalog/p...oducts_id=1084
  32. Member B0rin's Avatar
    Apr 13th, 2010
    Barrie, Ontario
    06-01-2012 09:38 AM #32
    Quote Originally Posted by Scotty_2.0 View Post
    Thanks man I'm going to see if I can order it local if not ill buy it online.
    I plan on doing all the work next Saturday should be fun
    - 2002 Vw Jetta1.8T
