Results 1 to 13 of 13
Thread: 2010 Golf has water on backseat floor when it rains
  1. 05-23-2012 01:28 PM #1
    I've had my 2010 4-door Golf since new and had been noticing a mildew odor, but could never find the problem, it would come and go. Finally discovered that the backseat floor behind driver's seat was soaking wet under the mat. It was raining and I could see the water coming in from under the back door, over the plastic "curb" and dripping down under the mat. Took it in for service last week, they said they could not make it leak and they looked under carpet and said it was dry and odor-free (it had dried up by the time I had the appt). Well, it's been raining this week and the floor is soaked again and the car stinks! Going back in next week. Has anyone had this problem?
  2. Member tstahlGTI's Avatar
    Mar 25th, 2012
    Statesboro, GA
    2012 GTI 6MT
    05-23-2012 01:40 PM #2
    Haven't had that issue w/ mine. Per chance, do you happen to have any aftermarket audio or suspension mods on the car? Just curious, if you do, sometimes installers will run cabling under the vehicle and bring it in through the floor, making a hole that if not sealed could let water in.
    Also, check the spare tire well.
    Quote Originally Posted by Air and water do mix View Post
    They have the structural integrity of origami, the reliability of a drunk on New Year's Eve, and they're based off of a '70s Fiat design but built under communist labor (You now, guys who know they can't be fired for any reason.)
    Current: 2012 CSG GTI 6MT
    Past: 2007 Audi A4; 2009 Tiguan S; 2007 Rabbit (with the Guitar! ); 1985 VW Cabriolet
  3. Member SoCalMK6GTI's Avatar
    Apr 4th, 2010
    Rancho Cucamonga, CA
    2010 GTI 6MT DBM
    05-23-2012 01:54 PM #3
    First things first, no reason to wait for an appointment. If you throw a code, get it in ASAP and let them document the code. If you have water leaking in, get your car in immediately so they can document it. My dealership is great about this, they promote this kind of thing so that the customers issues are documented and resolved.
  4. Member
    Aug 13th, 2008
    Minneapolis, MN
    1995 M3, 2012 GLI
    05-25-2012 12:50 AM #4
    I've experienced a bit of this lately. About a week ago, I was vacuuming my Golf's carpets. When I lifted the rubber floormat in the rear (drivers side), the bottom of the floormat was covered in condensation. More recently, I've noticed a musty smell inside my car. I haven't done anything about it because my life is super busy right now and, frankly, I'm stumped as to what could have caused this.
    My Golf is a 2010 2-door.
    DD: 2012 GLI
    Gone but not forgotten: 2010 Golf 2.5
    Summer fun: 1995 M3
    Former E36 318i driver and self-appointed Chairman of the Momentum Preservation Society.
  5. Member Smoky_Llama's Avatar
    Nov 21st, 2005
    Bellevue, Nebraska
    12' GTI, 10' Specialized Hardrock
    05-25-2012 02:26 AM #5
    You guys have sunroofs?
    Need Vag-Com in Eastern Nebraska and Western Iowa? Send me a PM.
    Quote Originally Posted by Arin@APR View Post
    We don't run a business where we inspect damaged ECU's, completely destroy them, and/or whatever you were saying about your penis.
  6. Member
    Feb 17th, 2010
    2010 GTI 4DR 6MT Tomato Red
    05-25-2012 06:31 AM #6
    Quote Originally Posted by Smoky_Llama View Post
    Don't you mean "rainroofs"?
    Aug 13th, 2008
    Minneapolis, MN
    1995 M3, 2012 GLI
    05-25-2012 09:03 AM #7
    I don't.
    DD: 2012 GLI
    Summer fun: 1995 M3
  8. n00b
    May 25th, 2012
    Orlando ,FL
    2010 MK6
    05-25-2012 09:54 PM #8
    If you have a sunroof then its most likely your drain holes or drain tubes are clogged you should have four drain holes up there in each corner and if they happen to be clogged the water will overflow into the car either through the headliner or find its way down a pilar to the floor
  9. Member SoCalMK6GTI's Avatar
    Apr 4th, 2010
    2010 GTI 6MT DBM
    05-25-2012 10:22 PM #9
    Make sure there isn't a rip or tear in your fuel door as well, that would allow water in the rear quarter panel under heavy rain, or car washing. There was a thread a long time ago when someone had removed their hatch interior and found water inside the rear quarter panels at each side, along with dirt and debris that had somehow gotten in there.
  10. Member Justin14's Avatar
    Jan 7th, 2012
    USA
    2012 Golf 2.5 manual
    05-26-2012 10:47 AM #10
    As a future 2010 owner, this is concerning. Keep this thread updated. Kinda scary. That water can cause all kinds of issues.
  11. Member dstackmasta27's Avatar
    Mar 13th, 2010
    Severn, MD
    SBM 6MT 4dr MK6 GTI | UG DSG 4dr MK6 GTI
    05-26-2012 01:27 PM #11
    I don't know if the Golf has a cabin filter like the GTI (I would think that they would), but if you have a 2010 and haven't replaced that it could be contributing to the musty smell. I replaced mine because I would get some serious stank when I turned the A/C on.
    Now it smells great
    Good luck finding the source of the leak.
    APR Carbonio Stage I Intake | APR Stage I tune | Euro Shift kit | misc light aesthetic mods
    Aug 13th, 2008
    Minneapolis, MN
    1995 M3, 2012 GLI
    05-27-2012 12:12 AM #12
    Quote Originally Posted by dstackmasta27 View Post
    Mine has had the cabin filter TSB performed.
    DD: 2012 GLI
    Summer fun: 1995 M3
  13. 05-27-2012 01:16 PM #13
    I recall a thread from a couple years ago, when the MkVI was brand new, about some cars having faulty welding above the back hatch. If I remember right the owner had to threaten to sue VW to get it fixed. Dunno if that is relevant. Perhaps it is if you are seeing water in the spare tire area.
