Results 1 to 6 of 6
Thread: Help Please !!!!! Loud Hissing noise ???
  1. 05-23-2012 03:30 PM #1
    Hey everyone whats going on ??? today i went out side to warm up my car before heading out to work ... When i started my car i got out and i hear a Loud HISSING sound ??? So i popped the hood and it just got louder ?? sounds like its coming from the top of the motor and also on the left side by the belts ??? its a 2004 R32 and i just hit 80K miles?? anyone have this problem or know what it could be ?? Thank you
    Jul 11th, 2011
    Colorado
    mkiv r32
    05-23-2012 03:54 PM #2
    I had a mild hissing sound at idle, but it got removed when I did a SAI block off.
  3. Member DarkSideGTI's Avatar
    Aug 11th, 2001
    SL,UT
    Bagged R32T
    05-23-2012 05:08 PM #3
    sounds like a vac leak to me. check all your lines.
  4. 05-23-2012 05:15 PM #4
    thank you for the quick responses ... I found the problem and it was the secondary water pump vaccum line it was cracked in half ... i called volkswagen $90 for a plastic line !!!!! insane lol
    May 30th, 2006
    Mesa, Arizona
    '04 R32 - '95GTIVR6 - '02 TTQuattro
    05-23-2012 05:27 PM #5
    Quote Originally Posted by bigturbo4life View Post
    Our secondary water pump has a vacuum line?
  6. Member macximus's Avatar
    Oct 21st, 2007
    Lafayette, CO
    2004/.:R32/BMP
    05-23-2012 07:19 PM #6
    def sounds like the SAI line.
    I work at VW, if you live in CO I can take care of you
