i would prob solder them up and grind it down. i wouldn't weld because the metal is already going to be a bit thin and you may make the pin holes bigger.
#1
hey guys, after sandblasting i have several spots were the rust left holes. whats the best way to fill and close em?
#2
#4
actually welding is the best way to fix it, your replaceing metal with metal. All you have to do is put a piece of different type of metal ie. brass or aluminum, behind the hole and hit it with the welder, grind it and you have a solid metel piece again.
