Results 1 to 8 of 8
Thread: Power Locks Help??
  1. 05-23-2012 09:30 PM #1
    My locks have suddenly stopped working from both the inside buttons and my remote. So I can only lock my driver door with the key and have to push down and pull up the passenger door lock all the time. I am assuming that it is a fuse, relay or faulty connection of some sort.
    Any help is appreciated as I can not even find where the fuse for the power locks is as it is not labeled in the fuse box under the steering column.
    Thanks
  2. Member CajunSpike's Avatar
    Mar 11th, 2009
    New Orleans, LA
    91 Burgundy Etienne(2), 92 Green Carat, 99 Passat Sedan, 01 Passat Wagon
    05-23-2012 11:51 PM #2
    Year/model of car, setup in your profile...would be helpful.
  3. Member backinthegame's Avatar
    Dec 13th, 2004
    Virginia Beach, VA
    92 Cabriolet(RIP),89 Cabriolet, 03 A6 Avant, 93 Trek mtn. bike
    05-24-2012 07:28 AM #3
    When you turn the key, do you hear the pump in the trunk run? If not, check the fuse and the connection at the pump. If you hear it, you have a broken vacuum line to track down. Usually the fitting at the door hinge is the culprit.
    Sent from my Droid using an escape pod to Tattoine.
    Quote Originally Posted by mad8vskillz View Post
    they're trying to skip out on their contracts via rapture. not very christian of them
  4. 05-24-2012 12:56 PM #4
    I have the same problem with a 2002. Can you tell me which fuse to check? Thanks.
    Sent from my LG-LS670 using Tapatalk 2
  5. 05-25-2012 10:00 AM #5
    Quote Originally Posted by foltz61 View Post
    Everything I read says fuse 21. Just womdering if there was another.
  6. Semi-n00b
    Jul 24th, 2010
    Chestnut Ridge NY
    99' CABRIO MK3.5
    05-25-2012 10:32 AM #6
    I had the same problem , i went to a junk yard and found a used pump and its been working ever since.
  7. 05-26-2012 10:49 AM #7
    Are you supposed to hear a relay clicking when you hit the lock/unlock switch in the car? I don't hear anything?
  8. 05-27-2012 11:51 AM #8
    How do you unhook the vacuum line tubing? Feels like I'm gonna break it.
