make damn sure you know how to line up everything after you install the timing belt, cause its an interference motor, meaning if you screw up aligning things just a little bit, youll bend valves and smack pistons....enjoy!![]()
#1
So this weekend I'm doing my timing belt, cam seal and valve cover gasket on my 88 16V. I've never done any of these before.
I've got time and my friend Bentley along for the ride; anything I should be aware of or look out for? Thanks! Wish me luck.
#2
My 91 GTI 8V, original owner stylz, yo!: http://www.flickr.com/photos/4144775...13544433/show/
#3
#4
Here's a dumb question i just thought of--if I'm changing the water pump do I need to drain all my coolant?
#5
#6
#7
You'll find out very fast when you take the water pump off if you need to drain coolant lol.
But yes, you should drain unless you just wanna take the bottom radiator hose off that goes to the water pump. That's what I did.
#8
If your doing the tb you should change the wp & thermostat while you're in there as well![]()
YOU'RE WELCOME
#9
