we are all left hand drive.....Your best bet would be a wilwood setup to get rid of the vacuum assit
#1
hi guys i've been working on this project for about a year now it is a 2.0 APK with a AGU head Ko3 turbo custom exhaust ,will be running megasquirt ecu ,i have a bit of concern,the cam shaft pulley is soo bloody close to the brake master cylinder how do u guys handle this problem
the problem
ignore the dates on the pics my camera is getting ahead of itself
#3
^ this is one option. I can't see ur pics
Bajan 4G
scIROCco 16v / quattro sport *VOLKSHORE/A dutty dub*
- ANYTHING UNATEMPTED REMAINS IMPOSSIBLE
#5
#6
I've been contemplating this one... in one of the clubgti threads, dude overcame the clearance by spacing up his rear motor mount to give another half inch or so of clearance.
#8
I've got the one from the mk3, you can try that and see if it works.the problem
#10
i'll be watching this![]()
#11
hey are you still having problems wirth engine clearance , if i remember correctly the skoda had a smaller booster set up and or it on the left hand side with a brake bar running over to the right to the pedel box. check it out i dont know if it will be any help (use to work for simpson motors back in the day)
