Results 1 to 9 of 9
Thread: Brake Pad warning light
  1. Member Defex's Avatar
    Nov 20th, 2010
    Croatia
    07 Passat 2.0TDI DSG Highline
    05-25-2012 09:27 AM #1
    I've had the brake pad warning light intermittedly come on and off in the last week.
    I took the front left wheel off and had a quick look and there is still 10mm of pad on the outer, also the connection going to the pad seems to be fine.
    Is this warning light just an over precaution from VW and I still have plently of meat left on my brake pads and km's, or should I thoroughly check them all or take it to the mechanic to be on the safe side.
    This one
    Aug 16th, 2010
    Indiana
    B5 A4,B5 4 Motion, B6 2.0T
    05-25-2012 09:48 AM #2
    does it happen after you have been driving for a while?
  3. Member briankstan's Avatar
    May 22nd, 2009
    West Jordan, Utah
    06' 3.6 Passat 4-Motion
    05-25-2012 10:24 AM #3
    I'd check them all just to be safe.
  4. Member Tutti57's Avatar
    Jun 20th, 2011
    Rochester, NY
    2006 Passat 2.0T and 2008 Touareg VR6
    05-25-2012 02:22 PM #4
    Check the back too since the rear brakes wear out faster on these cars.
    2006 Passat 2.0T Tiptronic | Unitronic Stage 1+ | Rokkor Coil Overs | White Line Control Arm Bushings | BFI Tranny Mount | Nuespeed P-Flo Intake | Newsouth Boost Gauge | Rev D Diverter Valve | BSH PCV fix | eBay Climate Knobs | Autotech Exhaust | DDM HIDs | Stereo Upgrades | Bentley Manual | VCDS
    2008 Touareg VR6
  5. Member pq46er's Avatar
    Aug 22nd, 2007
    Ottawa
    2007 Passat wagen
    05-25-2012 02:28 PM #5
    I recall reading somewhere that the pad thickness sensors are only on the rear. I would check there first.
  6. Member low_passat's Avatar
    Sep 11th, 2010
    Goodyear, AZ
    05-25-2012 02:42 PM #6
    Quote Originally Posted by pq46er View Post
    Sensors are only on the front.
    2007 Candy White/Black Passat 2.0T Wolfsburg Edition| APR Stage 2+ | APR HPFP | Forge WINtake | S3 Intercooler | B&B 3" Turbo-Back Exhaust | Dogbone Insert | FK Silverline+ Coilovers | Front Lip Spoiler/Hi-Def Sideskirts | Votex Trunk Lip Spoiler | R-Line Fog Grilles | Clear Corners | HID Kit - low beams & fogs | RCD-510 | Podi Boost gauge | R-Line Pedals | GTI Steering Wheel |
    Oct 14th, 2008
    '07 Passat 3.6 4mo wagon; '05 GLS 4mo wagon
    05-25-2012 03:08 PM #7
    I had a warning light when my brakes were good and it turned out to be a short in one of the wires connected to a sensor.
  8. Member Tutti57's Avatar
    Jun 20th, 2011
    Rochester, NY
    05-25-2012 03:36 PM #8
    Well then!
    2008 Touareg VR6
  9. Member Defex's Avatar
    Nov 20th, 2010
    Croatia
    06-16-2012 03:04 AM #9
    In the end as in Incrementals case it was a bad connection in the sensor wiring, so they just replaced the harness.
    Took 20min and they didn't charge me anything.
