VWVortex.com - Lubro moly 5w40 is a very bad quality oil
    Page 1 of 2 12 LastLast
    Results 1 to 25 of 50
    Thread: Lubro moly 5w40 is a very bad quality oil
    1. Junior Member VWVR624V's Avatar
      Mar 30th, 2011
      VR6 24 VALVE JETTA
      05-25-2012 10:02 AM #1
      Liqui Moly 2332 Is Good
    2. 05-25-2012 12:41 PM #2
      I believe that people change brands of oil and then suddenly become more aware of the normal engines noises. Bear in mind, 95% of lube products contain the exact same additives and base oils.
      As long as you're happy, nbd. Come winter, maybe try German Syntec, if you like Castrol.
    3. Junior Member VWVR624V's Avatar
      Mar 30th, 2011
      VR6 24 VALVE JETTA
      05-25-2012 01:02 PM #3
    4. 05-25-2012 01:06 PM #4
      Send it all to me then!
    5. Junior Member VWVR624V's Avatar
      Mar 30th, 2011
      VR6 24 VALVE JETTA
      05-25-2012 01:14 PM #5
      Valvoline Synpower MST 5W40 Is A Weak Oil with a Low Additive Package which is shown with a low TBN number & a Low SAPS Formula.
      http://www.bobistheoilguy.com/forums...2405398&page=1
      Valvoline Should Introduce their HST Formula which is the Valvoline Synpower HST 5W40 In Bottles, They Currently Only Have It Available In Drums
    6. 05-25-2012 01:23 PM #6
      MST isn't for our market, and doesn't work with our high sulphur fuels.
      The thing about our Synpower is that Ashland uses organic additives which don't show up on UOA. Funny though, I always say Synpower is one oil I don't mind paying full price for.
      Run the 10w-30, or mix it with a quart of 20w-50, like I do with my stash of Valvoline Racing Synth. Then do a UOA....it's the bomb.
    7. Junior Member VWVR624V's Avatar
      Mar 30th, 2011
      VR6 24 VALVE JETTA
      05-25-2012 01:25 PM #7
      Liqui Moly 5W40 2332 Is Good
    8. Junior Member VWVR624V's Avatar
      Mar 30th, 2011
      VR6 24 VALVE JETTA
      05-25-2012 01:28 PM #8
      MST Valvoline Synpower 5W40 Is Very Bad For Use With Ethanol Based Fuels Also
    9. 05-25-2012 01:45 PM #9
      Quote Originally Posted by VWVR624V View Post
      I would think so.
      I use some 2-cycle oil in my gas at 500:1, fwiw.
      Here is my reply to your PM:
      different oils use different additives. when you change oil, it 'scavenges' off the old anti-wear layers and could lead to some excess sound... temporary, until the new AW package layers lays down on the metal.
      I'm just trying to give a scientific analysis instead of hating on a decent product. Louder doesn't mean more wear or anything ill. imo, a lot of underhood noise is just belts and pulleys. Maybe spray your belts down w/dressing and listen again. How about a sound recording after you change oil....just saying.
      visc is usually the big factor w/engine sound.
      Sound is a tough factor to consider. Maybe you bumped an electrical connector or a vacuum wire when you changed, I dunno. The oil filter is another thing that got changed...?
    10. Member
      Jan 26th, 2012
      Central NJ
      2011 Audi Q5 3.2; 2004 Subaru Forester XT; 2013 TTS Oolong Gray P+
      06-05-2012 09:23 AM #10
      I put this Lubro Moly 5w40 in my 24V VR6 Jetta MK4 and the engine just disliked it, with bad lifter noise and not running smooth at all. I changed out the oil after only 3000 miles and switched to Castrol Edge 5W40 SPT which is a far superior oil which has recently been reformulated
      http://www.castrol.com/liveassets/bp..._Sept_2011.pdf
      While I do not doubt that the reformulation to API SN for Castrol Edge SPT 5W-40 may have improved the oil, please provide some comparison data showing that Lubro-Moly is bad or crap oil.
      -Dennis
    11. Member
      May 1st, 2009
      Colorado Springs, CO
      2013 BMW X5 35d, 2011 Tiguan
      06-08-2012 11:58 AM #11
      Are you promotor of Castrol or?
      All your posts are about Castrole Edge SPT 5W40.
      You can find dozen better oils than 5W40 SPT, starting with Castrol 0W30!
      13' BMW X5 35d
      11' Tiguan SEL 4Motion
    12. Member stupakjim's Avatar
      Sep 17th, 2005
      Illinois
      06 jetta 2.5
      06-08-2012 01:31 PM #12
      Rotella T6 5w-40, isn't this what a lot Vr6 guys run???
      ALWAYS Mention VwVortex FOR OUR DISCOUNTS!!!Need a Quality Mechanic? J's REPAIR AND PERFORMANCE, PLAINFIELD, IL VAG-COM EQUIPPED-815-556-0027 01E/01X TRANSMISSION REBUILDER BEST price for OEM VW parts- ERIC @ autobarn vw (mt prospect, IL_they ship) 866-308-0049 Need paint work? Collision Revision Plainfield, il talk with Tony Combs 815-439-7401
    13. 06-08-2012 04:06 PM #13
      I reviewed a few UOAs last night, and I'd have to say the BMW Castrol 5w-30 (LL-01) is an amazing product.
      BMW has been using their 5w-30 in the US market for a long time. Maybe they see it as I do, with temps and driving conditions here leaning toward lighter-is-better. Also, idk if they have the fuel dilution VWs have to contend with.
      The dealer today had bricks of M1 5w-40 ESP. That must be for the diesels. Everyplace retail seems to be featuring the new low saps oils like ESP and SLX, but they are imo, less than ideal with our ****ty fuels and rich tune for US low NOx emissions.
    14. Junior Member VWVR624V's Avatar
      Mar 30th, 2011
      VR6 24 VALVE JETTA
      06-08-2012 11:33 PM #14
      So what i had a good experience with the reformulated castrol edge spt 5w40, my brothers v8 touareg loves german castrol spt 0w30, which i have not tried yet on my 24v vr6
    15. Junior Member VWVR624V's Avatar
      Mar 30th, 2011
      VR6 24 VALVE JETTA
      06-08-2012 11:35 PM #15
      Where do you find BMW CASTROL (LL-01) 5w30
    16. 06-08-2012 11:56 PM #16
      Online/ebay prices are remarkably decent.
      One of the few products I don't mind paying (full price) for.
    17. Member rajvosa71000's Avatar
      Jun 8th, 2004
      '04 VF Stg.2 24v GTI VR6, '10 B6 Passat 2.0T, '14 B7 Passat TDI
      06-09-2012 01:51 AM #17
      I'm running Lubro Molly 5w40 on my 24v VR6 and it seems to like it, it runs very smooth, I haven't done any uoa with this oil but I might send it in to see what happens. I also ran Total and Amsoil 5w40 before and it also ran smooth. Try Amsoil and see how you like it.
      Sent from my HTC Sensation 4G using Tapatalk 2
    18. Member
      Jan 26th, 2012
      Central NJ
      06-11-2012 04:27 PM #18
      I put this Lubro Moly 5w40 in my 24V VR6 Jetta MK4 and the engine just disliked it, with bad lifter noise and not running smooth at all. Cold weather lifter noise was even worse like a diesel. Dennis M what kind of oil do u use that you are asking me for the proof of Lubro Moly 5w40 issues, i had a bad experience with Lubro Moly 5w40 that is the only proof i have and many other people have the same experience listed below.
      http://www.amazon.com/review/R1RLBAN...R1RLBAN52PHB9Z
      http://www.amazon.com/Lubro-Moly-Syn...rBy=addOneStar
      Lubro Moly Also Changed The Formula For The US Market
      http://www.audizine.com/forum/showth...p-IV-synthetic
      The reason that I would like to see some data, is because someone stating that their car dislikes an oil doesn't hold much weight to the claim that Lubro-Moly is bad quality.
      Also, base stock type tells you absolutely zero about an oils performance. Group III oils are narrowing the performance gap with Group IV oils and Group III's are actually taking over as the more popular synthetic in Europe (by sales) according to some oil additive supplier statistics that I've seen (I forget if it was Lubrizol or someone else). XOM created the first Group III base stock, Visom, capable of being used to produce a 0W oil.
      I'm not loyal to brand or base stock and I've used various oils - M1 0W-40, GC, Syntec 5W-40, Pennzoil Ultra 5W-40, Motul X-lite 0W-30, Motul X-clean 5W-30, Motul Eco-nergy (in the Forester) - all with good uoa results. While a $30 random uoa isn't the be all and end all of determining oil performance, I'll still take that over "OMG! Lubro Moly is Group III and sux and your car will explode!!!". Look on bitog for some Lubro Moly uoa's.
      -Dennis
    19. Junior Member VWVR624V's Avatar
      Mar 30th, 2011
      VR6 24 VALVE JETTA
      06-11-2012 07:01 PM #19
      rajvosa71000
      How many miles do u have on the 24v vr6 and what part of the country do u live
    20. Member rajvosa71000's Avatar
      Jun 8th, 2004
      06-12-2012 12:40 AM #20
      I got just under 103k on it and the car has been supercharged since 61k with the VF stage 2, and I live in Las Vagas, it gets very hot.
      Right now I'm running Longtime High Tech 5w30 that I put in in January and it has little over 2k on it, and when I check the oil it still looks clean and at the right level, before I was running synthoil 5w40 with the same results. I might send my current oil to Blackstone for uoa and see what happens. I always change my oil at 5k or 6 months.
    21. Junior Member VWVR624V's Avatar
      Mar 30th, 2011
      VR6 24 VALVE JETTA
      06-13-2012 03:35 PM #21
    22. Member rajvosa71000's Avatar
      Jun 8th, 2004
      06-13-2012 05:04 PM #22
      Yeah but it is VW 502.00 approved, plus I was just gonna run it firming colder weather, the only reason I didn't switch it was due to the low mileage...anyway, I did order some Lubro Molly 0w40 like recommended above, so as soon as I get it I would switch it.
    23. Junior Member VWVR624V's Avatar
      Mar 30th, 2011
      VR6 24 VALVE JETTA
      06-13-2012 10:04 PM #23
    24. Member rajvosa71000's Avatar
      Jun 8th, 2004
      06-13-2012 10:26 PM #24
      Yeah I've used Castrol Syntec 5w40 till about 60K miles, than I started using different brands like Amsoil, Elf/Total, and Lubro Molly. I asked the guys at Castrol about Castrol Edge and they said that they dont recommend it on our car, they would just use Castrol Syntec (but that was long ago, dont know if they made a formula now for our car).
      How do you know about LM (Lubro Molly) 5w30? have you use it in your car and done some UOA? Im gonna send it in after my oil change and I'll post results, wish I did that woth LM 5w40.
      I think that Castrol SPT is same as Syntec just renamed.
    25. Junior Member VWVR624V's Avatar
      Mar 30th, 2011
      VR6 24 VALVE JETTA
      06-13-2012 10:33 PM #25
      The new Castrol Edge SPT 5W40 BMW LL-01 was reformulated over the previous Castrol Syntec 5W40 which was BMW LL-98 approved, which was the old approval for BMW which was replaced by BMW LL-01 You must be thinking about Castrol EDGE FST which is only made for US grades not European Car Grades. In the USA Castrol EDGE FST Meets Specification for cars like Toyota, Honda, Ford, and GM in the USA Only
