Find someone with a vagcom to check for faults in 15-Airbags.
#1
The other day I got in my and started it up and the airbag light came on homes up an code reader an there where no codes
#2
OEM+ Bi-Xenon HIDs | Front & Rear Fogs | Highline CECM | Euroswitch | RNS-510 HW:08 SW:1140 w/ Software VIM | Backup Camera | 9W7 | Dash Cubby | Aspherical Mirrors | GTI Steering Wheel w/ .:R Badge | GTI 6MT Shift Knob | GTI E-Brake Boot | GTI Pedals | GTI 18" Detroits
Not so OEM+ Koni Coilovers | Gentex Homelink Mirror | Yaesu FTM-350AR
#4
I had one and even clearing the code it would not go away. Decided to pull the plug that vagcom indicated was at fault, then clean both sides of it with electro contact cleaner, reinstalled connector, connect battery, and clear code. Fault went away and has not been back since. I did this with the battery disconnected just incase since it envolved airbags. It could be an actual fault but if you get lucky its just high resistance in one of the components.
#5
#6
#7
#8
It was for the driver side explosive reel for the seat belt.
