VWVortex.com - MSnE V1 2.2 going lean at elevation
    Page 2 of 2 FirstFirst 12
    Results 26 to 37 of 37
    Thread: MSnE V1 2.2 going lean at elevation
    1. Geriatric Member need_a_VR6's Avatar
      May 19th, 1999
      Oxford, PA
      15 Jetta 92 Corrado VR6
      07-26-2012 08:13 PM #26
      Decent amount 5-10min warm.
      -Paul
      1992 Corrado - ALL MOTOR Drag Project
      1995 GTI VR6 - Retired - 12.90@106 R32 power - 12.833@106 12v power
      KPTuned - Official MegaSquirt: Sales - Repair - Installation - Tuning
    2. Member frechem's Avatar
      Oct 19th, 2002
      Lawndale, CA
      '91 ITB GTI, '96 .:R32 Harlequin #22, '07 X-Runner
      07-27-2012 06:59 AM #27
      So what does everyone think of my MSQ?
    3. Member ps2375's Avatar
      Aug 13th, 2003
      Meridian, ID
      80 Rabbit(DEAD), 94 Golf, '69 Type1 Sedan
      07-27-2012 08:21 PM #28
      I might later, I deleted the "project" to allow me to load a HR msq.
    4. Member frechem's Avatar
      Oct 19th, 2002
      Lawndale, CA
      07-29-2012 09:29 PM #29
      Still no feedback about my MSQ?
      Well I did go out this weekend and try to do some data-logging but for some reason I only got a minute or so recorded. I'll go out tomorrow after work and try again.
      In the mean time here is a noisy video of my run.
      Enjoy.
    5. Geriatric Member need_a_VR6's Avatar
      May 19th, 1999
      Oxford, PA
      07-29-2012 10:19 PM #30
      Nothing odd in the msq offhand other then the main fuel table looked very lean/low just off idle and until pretty high load/rpm. The 15.x afr targets in the middle of the table seemed a little odd as well. Datalog vs that msq might make some sense.
      -Paul
    6. Member frechem's Avatar
      Oct 19th, 2002
      Lawndale, CA
      07-29-2012 10:45 PM #31
      Quote Originally Posted by need_a_VR6 View Post
      OK thanks for the feedback.
      Here are what the tables used to look like before I had -RalleyTuned- try and help me out with the altitude issue a while back.
    7. Member frechem's Avatar
      Oct 19th, 2002
      Lawndale, CA
      07-30-2012 06:14 PM #32
      I was able to go out and do a log today. Let me know what you think.
    8. Member Dubrunner's Avatar
      Nov 8th, 2000
      Portland, OR
      07-30-2012 07:20 PM #33
      Wow, glad to see you might be making some progress! I went out today and having set EGO Step and Authority, with the Target AFR table now set, did not make much difference.
    9. Member frechem's Avatar
      Oct 19th, 2002
      Lawndale, CA
      07-30-2012 10:46 PM #34
      Quote Originally Posted by Dubrunner View Post
      No progress here. I haven't had enough feedback to make any changes.
    10. Geriatric Member need_a_VR6's Avatar
      May 19th, 1999
      Oxford, PA
      07-31-2012 10:39 AM #35
      Here is my feedback looking at the logs:
      You have no MAP range to speak of, which is common on ITBs. Make your lower kpa bin ~45-50 and spread the load bins out a ton more over that range. All of your low kpa should be handled by overrun fuel cut so you'll have to set that up. I would also change your afr targets a bit and get rid of anything leaner than 14.7:1 for now, the old AFR table with a tweaked MAP range would work better.
      -Paul
    11. Member frechem's Avatar
      Oct 19th, 2002
      Lawndale, CA
      07-31-2012 12:08 PM #36
      OK great, thanks for the advice!
      Would it be possible to have you tweak my tables and MSQ to what you you were thinking?
      You have a lot more knowledge and experience in this area than I do.
    12. Geriatric Member need_a_VR6's Avatar
      May 19th, 1999
      Oxford, PA
      07-31-2012 05:23 PM #37
      Perhaps, email me at kandpperformance@gmail.com
      -Paul
