Results 1 to 12 of 12
Thread: 2 Questions For Those Who Have Removed The Whole Top---Frame And All
    Dec 1st, 2011
    Cleveland, OH
    '83 Cabby Wolfsburg "Nimbus"
    05-26-2012 04:45 PM #1
    We had wind here last night. My friend's '82 was parked outside. Tree decided to shed a limb right on top of the car. Ruined the top and crushed the frame (No, no comprehensive. Don't ask why.). He knows where there is a complete wrecked '88 with a good top and frame for cheap. Since he's a mechanical nitwit, I've been elected to retrieve it. Here are the questions:
    (1) Will the '88 top--frame and all--fit onto the '82?
    (2) For those who have done the swap, know that I'm not inclined to be dragging a bunch of tools to the site of the donor car. The have a tendency to disappear. What are the fewest tools needed to remove the top and frame as a unit. I'm thinking a wrench or wrenches to unbolt the frame from the rear. (what kind and what size?) and a wrench to loosen and remove the rear cable assembly from the body (same questions).
    Thanks in advance for your well-thought-out replies.
    DW
  2. Member kamzcab86's Avatar
    Feb 13th, 2002
    Arizona
    1986 Cabriolet Best Seller, 2000 Jetta VR6, 1990 Vanagon Westfalia
    05-26-2012 05:36 PM #2
    Quote Originally Posted by Dragonwing View Post
    Yes.
    http://www.cabby-info.com/Files/FrameRemoval.pdf
    Cabby-Info.com -- Your online guide to the VW Cabriolets
    Old Blue's Blog -- The adventures of a 1990 Westfalia
    "Fashion is a waste of money that could be better spent on, say, maintaining your car." ~James May
  3. Member backinthegame's Avatar
    Dec 13th, 2004
    Virginia Beach, VA
    92 Cabriolet(RIP),89 Cabriolet, 03 A6 Avant, 93 Trek mtn. bike
    05-26-2012 08:46 PM #3
    13mm socket (for strut hinges), 10mm socket (for rear window strap bolts), 10mm wrench (for rear cable unless you just cut it. a gear wrench will help tons) 5mm open end wrench (to hold the rear cable unless you just want to cut it), 17mm socket (for top hinges), flathead screwdricer (to remove strut retainers) phillips head screwdriver (for defroster ground and cap snaps).
    Sent from my Droid using an escape pod to Tattoine.
    Quote Originally Posted by mad8vskillz View Post
    they're trying to skip out on their contracts via rapture. not very christian of them
  4. Member
    Dec 1st, 2011
    Cleveland, OH
    05-26-2012 10:38 PM #4
    That's what I was looking for! Thanks--as usual, you've saved me from what could have turned into a colossal headache.
    DW
  5. Member 1956dub's Avatar
    Jun 12th, 2010
    Castle Rock, WA
    I own the SLC parking experience
    05-26-2012 10:58 PM #5
    Quote Originally Posted by backinthegame View Post
    This forum kicks a$$!!!
    Quote Originally Posted by Rento_VW View Post
    Needs a real Zender wing.... lower it.
  6. Member backinthegame's Avatar
    Dec 13th, 2004
    Virginia Beach, VA
    05-26-2012 11:12 PM #6
    I would bring a 15mm socket as well. Upon rethinking, the top hinges may have been 15mm.
  7. Member egranlund's Avatar
    Jul 21st, 2008
    Lafayette, CA
    1986 and 1987 Cabriolet
    05-29-2012 11:11 PM #7
    Also, make sure to be careful with the hinges that attach to the parcel shelf after you have removed the top. They are very sharp and will rip a nice hole into the headliner of the new(er) top. I learned this one the hard way.
    Dec 1st, 2011
    Cleveland, OH
    05-29-2012 11:19 PM #8
    Alas! The whole thing was but an exercise in futility. This so-called 'perfect' top had the misfortune of having someone toss a tire iron directly through the center of the whole assembly. Why do people have to be such dopes?
    DW
  9. Member egranlund's Avatar
    Jul 21st, 2008
    Lafayette, CA
    05-29-2012 11:30 PM #9
    Happened to me more than once when I was looking for a new top for my car...
    If the frame is still good it may be worth it to still take it and have a new top put on it...
  10. Member sehaare's Avatar
    Aug 4th, 2003
    Palatine, IL. But I'll NEVER call Chicagoland home.
    2013 TDI Sportwagen, 81 Rabbit Convertible, 92 Cabby (Daughter's), 98 SUV, 2011 Legacy
    05-30-2012 02:58 PM #10
    Quote Originally Posted by egranlund View Post
    X2 - grab the frame that will be harder to get then the rest of the top.
    "I'm a man, but I can change, if I have to, I guess." - Man's Prayer
    "Quando omni flunkus moritati"
    Handyman's corner
  11. 05-30-2012 08:49 PM #11
    if there was an easy way to ship tops i have 4 sitting on a shelf
    A Dutty Dub
  12. Junior Member Dinobeavis's Avatar
    Dec 16th, 2007
    Raleigh, NC
    1989 Cabby 1.8L/020, 1997 Jetta GL 2.0L/020
    05-30-2012 09:43 PM #12
    Like they said ^^. I pulled a top last year from a yard just for all the seals. The frame and the seals are pretty hard to come by, but tops, pads and headliners are all over the place new.
    Also, I agree with the junk yard etiquette....I: take what I need and leave the rest reassembled within reason; never wipe my greasy paws on interior stuff; never break things as a shortcut to get what I need; never leave trunks and doors and windows and tops that can be closed open; almost always leave a damn wrench or screwdriver or pliers in a car and have to drive ALL THE WAY BACK to get it.
