Results 1 to 2 of 2
Thread: Jolting and intermittent cruise control after clutch master/slave cylinder replace
  1. Semi-n00b
    May 19th, 2010
    Los Gatos, California
    2001 S4, 2006 C320 Sport
    05-26-2012 10:48 PM #1
    Recently replaced my clutch master and slave cylinder and now when i let off the gas the car jolts. best way i know how to describe it is when you try to go full boost on a car with bad EGTs and let off the gas, kind of falls on its face.
    Also, cruise control works intermittently. When it does engage it only stays on for about 3-5 seconds. If I take my foot and put it under the clutch pedal, even thought it is at the end of its swing, and engage CC it works indefinitely.
    I did not replace the clutch flywheel or pressure plate while doing this. They are only about a year and a half old.
    TIA
  2. Member mkdueskey91's Avatar
    Mar 30th, 2011
    phoenix arizona
    1992 VW GTI 8v 2001 audi s4 2.7tt 6sp
    05-30-2012 01:12 PM #2
    Misadjusted linkage
