So i recently replaced the front main seal on my car and when i put the motor back together i put the timing belt on advanced one tooth (i didn't find this out until now). i ran a few days and didn't realize it until it detonated and blew up two spark plugs (cylinders 1 and 4) running ~27psi.
had the car down at southern worthersee and just threw a new set of plugs in to get me through the weekend.
once i got the car home i did a compression test (motor was cold) and the #4 cylinder had the lowest, which the worse plug was in..
#1 - 125psi
#2 - 134psi
#3 - 108psi
#4 - 60psi
pulled the head off today and found the head gasket blown between cyl 3 and 4.. the pistons and cylinders look ok and have no marks or scratches. the valves look okay also, none look bent but i want to get the head checked out to make sure the valves seal and aren't nicked or anything. i also saw oil seeping down the valves so i'm guessing i would need new valve seals?
bottom end:
head gasket:
head:
is there anything i overlooked that can be damaged?
bottom end has ~17k
2.1L stroker
tdi crank
IE Rods
JE 9.5:1 stroker pistons
coated bearings
gates timing belt
IE manual tensioner
Fluiddampr
ac delete
arp hardware
head is completely stock with ~136k
pte5857dbb turbo
IE tubular mani
tial mvs wastegate (dumped)
id1000's
IE fuel rail
bosch 044 fuel pump and an lines
mafless
TT intake mani and stock tb
running eurodyne maestro vvt software
pic of my engine bay
so what would you guys recommend to get the most out of my setup in my head? i was looking into getting integrated's IECVA1's and revving out to 8500. should i look into an AEB head? not looking to really spend a ton.. what do i need to replace in the head while i have it apart?
thanks!![]()
