Results 1 to 9 of 9
Thread: broke some stuff.. need advice on head work. 2.1L 5857 content
  1. Member dubbin_boho's Avatar
    Dec 3rd, 2007
    NJ
    imola 20th
    05-27-2012 02:12 AM #1
    So i recently replaced the front main seal on my car and when i put the motor back together i put the timing belt on advanced one tooth (i didn't find this out until now ). i ran a few days and didn't realize it until it detonated and blew up two spark plugs (cylinders 1 and 4) running ~27psi.
    had the car down at southern worthersee and just threw a new set of plugs in to get me through the weekend.
    once i got the car home i did a compression test (motor was cold) and the #4 cylinder had the lowest, which the worse plug was in..
    #1 - 125psi
    #2 - 134psi
    #3 - 108psi
    #4 - 60psi
    pulled the head off today and found the head gasket blown between cyl 3 and 4.. the pistons and cylinders look ok and have no marks or scratches. the valves look okay also, none look bent but i want to get the head checked out to make sure the valves seal and aren't nicked or anything. i also saw oil seeping down the valves so i'm guessing i would need new valve seals?
    bottom end:
    head gasket:
    head:
    is there anything i overlooked that can be damaged?
    bottom end has ~17k
    2.1L stroker
    tdi crank
    IE Rods
    JE 9.5:1 stroker pistons
    coated bearings
    gates timing belt
    IE manual tensioner
    Fluiddampr
    ac delete
    arp hardware
    head is completely stock with ~136k
    pte5857dbb turbo
    IE tubular mani
    tial mvs wastegate (dumped)
    id1000's
    IE fuel rail
    bosch 044 fuel pump and an lines
    mafless
    TT intake mani and stock tb
    running eurodyne maestro vvt software
    pic of my engine bay
    so what would you guys recommend to get the most out of my setup in my head? i was looking into getting integrated's IECVA1's and revving out to 8500. should i look into an AEB head? not looking to really spend a ton.. what do i need to replace in the head while i have it apart?
    thanks!
    maestro tuned 2.1L 5857
    May 16th, 2006
    Regina/Calgary
    '02 TTQ (RIP); '06 3.2Q A3
    05-27-2012 03:12 AM #2
    Your build is too nice to be running a stock head; here is the order in which I would choose upgrades:
    - AEB head
    - Large-port manifold (IE just announced their new one!)
    - +1 Inconel valves
    - Porting/polishing
    - Springs
    - Cams
    Depending on how much cash you can drop on it, I would choose that order since the springs and cams can be done - rather easily - at later date. +1 valves and porting can be skipped, but I regret not doing it, and I'd like to see more people pushing our scene forward. Not many guys are doing +1 valves and heavy porting now, but it wasn't so long ago that 400wHP was a heavy hitter in the 1.8T scene...now it's peanuts. There's a reason why we're behind the Honda/Evo/Subaru guys
    Jeremy Brehm: Regina Wedding Photographer
    '02 Audi TT 225 Build Thread - 2.0L - PTE6262 Daily @ 30PSI - 10.0:1CR - AEB @ 9000RPM - Maestro - RIP
    '06 3.2Q A3 - Stay tuned!
    May 16th, 2006
    Regina/Calgary
    05-27-2012 03:16 AM #3
    Quote Originally Posted by dubbin_boho View Post
    Missed that one
    I would find a blown AEB head for cheap, put in all new valves (inconel exhaust), and upgraded springs now. Cams will be a pretty easy swap in for when you're ready to drop the cash and/or need another 50HP Of course, do cams now if you can swing it.
    You can run your small-port manifold with a transition spacer to defer that cost as well.
  4. Banner Advertiser pete@integrated's Avatar
    Jan 1st, 2009
    Salt Lake City, UT
    '92 Gti 20v, '96 M3, '10 Shop Van :)
    05-27-2012 04:41 AM #4
    AEB head, proper valve job & check & replace the guides if neccessary- most of the time they are shot. Everything else you can do later as it the head won't need to come off.
    I wouldn't recommend taking a zillion year old, unknown AEB head and lapping in some valves, unless you are just a sucker for punishment. If the guides are shot, the valve job won't last at all- if there is even much of one left after who knows how many miles and getting smacked with bent valves... Hot tank the hell out of it too- the oil galleys are usually sludged up even on the "clean" looking ones.
    Been buying a lot of those heads lately and at least 1/2 of them are useless for some reason or other I would say, so it's worth it to go through the basics carefully before you marry it by bolting it on.
    Do check the installed height as well- many heads have been rebuild a lot of times now and some have sunk valve jobs. At best you won't get the spring pressure you should, at worst the hydraulic bucket won't be able to soak it up and you'll have valve(s) stuck open slightly.
    .:IntEngineering.com:. .:Facebook:.
    Check out some cutting edge R&D Work on our blog! IE Behind the scenes Blog!
  5. Member Vegeta Gti's Avatar
    Feb 12th, 2003
    konoha village
    1984 GLi 20v, '06 M3, '10 Ninja, '10 690 Duke
    05-27-2012 05:04 AM #5
    stainless valves over inconel.no need for inconel if it is a street car.bending is better than breaking valves, stainless can take the abuse.
    Sent from my SPH-D710 using Tapatalk 2
    Quote Originally Posted by frechem View Post
    I like my women how I like my whiskey; aged 18 years and mixed up with coke.
  6. 05-27-2012 05:32 AM #6
    AEB, CLEAN THE **** OUT OF IT. I literally hot tanked my head ~10 times and still was cleaning **** off it by hand... lucky I had free run of a hot tank at that time. Check the valve guides and installed height, get shims from IE if needed.
  7. Member dubbin_boho's Avatar
    Dec 3rd, 2007
    NJ
    imola 20th
    05-29-2012 11:19 PM #7
    Quote Originally Posted by pete@integrated View Post
    thanks for the tips
    i'm going to look for an AEB head.. looking at going with supertech valves and IE springs and retainers.. eventually gonna get the IECVA1's when they're back in stock and the new IE intake manifold
  8. 05-30-2012 01:53 AM #8
    You can check the valves integrtity with gasoline, or alcohol, pour it on there, and see if it leaks past the seat. If it leaks then you have a seat problem. But you would see if the valves touched the pistons, i can see on my pistons where the valves kissed the pistons a bit. If ur gonna do cva1 cams. Get a big port head. Small port heads just just flow enough. And those cva1 cams, when you get going, ur powerband doesnt end until you bounce off limiter. Theyre beast! I recommend them, matched with single keeper groove valves and keepers, and i.e. high rev spring and ull be on ur way! Sorry to see this. What head bolts were you isig when this hapenned? Go with arp. But **** looks good man. Keep it up! And get her going again!
    Unitronic830cc/Racetronix 846cc flowmatched injectors/HP6262SP-b/ TurboSmart Race Port/PrecisionPW39/TurboSmart MBC/Snow W/M Injection/IE Rods/AEB pistons/ARP Main cap studs/ARP headstuds/3" turboback/ FMIC/Custom fuel surge tank/ Wally 255/AEB head/supertech single keeper valves/ IECVA1 cams/IE valve springs and retainers/034 motor mounts. SPEC Stg 4 6 puck clutch, Vr6 lightweight flywheel. KRM intake manifold/80mm tb
  9. Senior Member 87vr6's Avatar
    Jan 17th, 2002
    Okinawa, Japan
    IY 20th in America, Evolution IV in 沖縄, 日本
    05-30-2012 03:24 AM #9
    If you plan on revving out to 8500+ you need to build the head. Plain and simple. A stock head will not get you there. Also, highly recommended since you are 2.1L is to have the rotating assembly balanced very well....
    "not looking to spend a ton"
    Good luck for your goals then... Reliable costs money.
