VWVortex.com - Gonna need some help
    Results 1 to 13 of 13
    Thread: Gonna need some help
      Mar 4th, 2004
      Lacey, Washington
      2003 silverstone GTI VR6 24v
      05-27-2012 03:23 AM #1
      Well,
      I"m going to need the transmission pulled so I can get the "flange" where the the Drive ale connects machined.
      I had a broken bolt in one of the six holes and when it got extracted and retreaded the retread is not straight. I can not get a proper seal on the inner cv joint due to this.
      Any suggestions on where I can go OR who could help me?
      John
      Mar 4th, 2004
      Lacey, Washington
      05-29-2012 12:54 AM #2
      bump
      anyone.
      suggestions?
    3. Member MEDEL514's Avatar
      Jan 12th, 2002
      Ramstein, Germany
      86 Rocco 8v, 90 Geo Tracker 1.6L 8v, G60 Corrado, 01 Audi A3 1.8tQ, 05 Yamaha R1, 06 Nissan Frontier
      05-30-2012 09:37 AM #3
      You'll probably have to put a helicoil in that hole. I don't know of a shop that will do it, but worse case, just run the 5 good bolts and try to forget about it
      Go €uro, or go home!
      Hyperlink to MY CARS
      Straightaways are for fast cars, Corners are for fast drivers.
    4. Member
      Mar 4th, 2004
      Lacey, Washington
      05-30-2012 11:36 AM #4
      Quote Originally Posted by MEDEL514 View Post
      You'll probably have to put a helicoil in that hole. I don't know of a shop that will do it, but worse case, just run the 5 good bolts and try to forget about it :laugh:
      kind of what I've been doing, but I need that "proper"seal.. cv joint's are not exactly cheap..
    5. Member 88Jetta350's Avatar
      May 4th, 2007
      Kaiserslautern, Germany
      1986 Golf Syncro, 1996 Passat VR6, 2012 Up!
      06-07-2012 10:32 AM #5
      If you stripped out the flange, just get yourself a puller, and replace the flange.. It's alot easier than dropping the tranny.
      Sent from my LT18i using Tapatalk 2
      [88Jetta350]
      '86 Golf Syncro -'96 Passat VR6 - '12 Up!
      ***VWSyncro.co.uk - The #1 resource for VW Syncro cars & vans***
    6. Member
      Mar 4th, 2004
      Lacey, Washington
      06-10-2012 04:23 AM #6
      I hope I painted the correct picture of what my issue is..
      where the inner CV Joint mounts to the transmisison on the drivers side. the "flange" (circle with 6 threaed holes).. One of the holes was rethreaded and is"crooked" the bolt does not tighten flush with the "flange"..
      I was told that the "flange" is pressure mounted to the transmission and can not just be removed.. said pressure could "kill me" if it was not taken off properly...
      Mar 4th, 2004
      Lacey, Washington
      06-11-2012 06:07 AM #7
      is my problem area
      the small circle: was retrhreaded, but crooked, so now the bolt won't tighten down flusch for a tight seal.
      Big circle: can this whole piece be replaced? and if so how?
    8. Member MEDEL514's Avatar
      Jan 12th, 2002
      Ramstein, Germany
      06-11-2012 07:28 AM #8
      Why not put a washer(s) under the head of the bolt to shorten the grip length a bit so that was you can tighten the CV joint down more?
      Mar 4th, 2004
      Lacey, Washington
      06-11-2012 07:45 AM #9
      hmm, you relly think that would work?
      might work, but at this point it sounding like the whole drive axle is loose now..
    10. Member Notabora2's Avatar
      Dec 24th, 2002
      Darmstadt, Germany
      Jetta MK4 VR6 Audi A4 B8 2.0 BMW 128
      06-11-2012 08:00 AM #10
      Bro, a VR drive shaft is expensive. I know a company that can replace the ends on a drive shaft if you need this. I replaced both of mine last year. I first go the aftermarket ones from ECS and they broke a few weeks later, then I bought the OEM ones and so far, working great. but if you need this piece, I can send you the number to my friend. His company makes these and I am sure its cheaper than a VR shaft.
      P.s. I also see you leaving Sembach and that your ride sounds so nice!
    11. Member
      Mar 4th, 2004
      Lacey, Washington
      06-11-2012 01:32 PM #11
      stopped by a dealership today
      part numbers:
      02M409355A x1
      02M301189B x1
      N90587602 x1
      N90991002 x6
      said those 4 are what I need
      dealer cost with out tax is 83euro
      dealer to do everything 235euro
      hmm
      Mar 4th, 2004
      Lacey, Washington
      06-11-2012 01:43 PM #12
      looking on line, not seeing a better price..
      I have few other things I think I will have them do for me as well...
      can't wait to get this all put behind me..
    13. Member
      Mar 4th, 2004
      Lacey, Washington
      07-11-2012 08:07 AM #13
      got it squared away..
      now it's onto intalling new suspension and installing R32 brakes on all 4 corners(still in the mail).. got the autotec ssl brakelines too..
