Results 1 to 5 of 5
Thread: bayliner 185
  1. Member O2VW1.8T's Avatar
    Jul 9th, 2003
    2013 335I, 2012 Tundra 4x4
    05-27-2012 11:02 AM #1
    So I really would like a wake boarding boat but they are 50k used. My parents have a bayliner 185 2007 I believe with the 4.3 engine. Is it possible to turn it into a somewhat wake boarding boat?
    02 GTi 1.8T haldex'd w/35r-SOLD 7.3@102mph 27psi on 93 octane--04 A4 1.8T converted to AWD also- SOLD--'11 JSW Tdi 6speed Manual- Gone--
    13' BMW 335i M-sport EBII
  2. Junior Member P0G0's Avatar
    Mar 22nd, 2011
    Sandy Eggo
    2010 Tdi Jetta, 2010 Wrangler, 2003 Ford Brodozer
    05-28-2012 01:12 PM #2
    You can wake board behind anything. A normal runnabout wont have the shaped wake of a dedicated wakeboard boat, but depending on your skill level, its more than enough to get you up and having fun. You can get a universal tower from anywhere between $1000 to $3000 plus accessories. If you want a bigger wake down the line and your motor can handle it think about adding a fat sack ballast.
    Check out http://diywake.com theyre a good place to start for what you need. I added a tower to my monterey recently. I went local for the tower but I got the racks and a mirror from here. And a friend of mine bought 4 of the tower speakers. Everything is extremely nice and high quality.
  3. Member case sensitive's Avatar
    Oct 8th, 2001
    03 a4 1.8t avant
    05-28-2012 07:41 PM #3
    what ^ said. I've wakeboarded behind everything from a 9.9hp row boat to a 32' long pontoon boat to a 80k pro model wakeboard boat. Your bayliner should be fine. If you can get a tower on your bayliner, that'll help you get higher out of the water.
  4. Member
    May 17th, 2010
    Elgin, IL
    2013 VW Golf R
    05-28-2012 10:38 PM #4
    The 18 foot Bayliner has been around in various forms for years, and for 5 wonderful years I owned a 2000 1850 Capri with the 4.3 - the exact same boat you are talking about.
    You are getting good advice here. In so far as a wakeboard boat, it won't give you the wake of an inboard V Drive Boat, but it will give you plenty of wake to have fun with. You can get a tower on them or have a universal one put on.
    But the bigger point is if this is your first boat, they don't get much easier, more reliable, or good performing. Baylner is known for having good performing hulls, and keeping it covered and cared for means it will outlast you. The 4.3 should push that thing over 55 mph with a SS prop, and you can cruise all weekend on a tank of gas. We even have a really solid owners group willing to help you with anything from advice to scheduled service:
    www.baylinerownersclub.com
    The Bayliner 185 is a very versitile boat. You can fish out of it, ski behind it, tube behind it, cruise with it and use it as an adventure machine, and the best part is they are affordable enough that any normal person can afford to buy and run one - which is important if the gas spikes again.
    In short, 2 thumbs up. THe compromise you make in wake shape is MORE than made up by all the other good points a 185 brings to the table.
    Just make sure you maintain it, keep it clean and covered when you aren't using it (don't leave the interior open to the elements - that's how these boats die an early death).
    Any questions, just ask. Like I said, I ran one for 5 years and pretty much only had to put gas and oil changes into it.
    2013 VW Golf .:R 6-Speed (Rising Blue/Titan Black)
    2012 Toyota Prius 3 (Blizzard White/Dark Gray)
  5. Junior Member P0G0's Avatar
    Mar 22nd, 2011
    Sandy Eggo
    05-29-2012 12:26 AM #5
    This was my fil's boat behind my truck. Its a bayliner with the tower and was a blast. My wife learned to board off that boat and i learned to drive. All around fun boat.
