Results 1 to 8 of 8
Thread: Several HID problems
  1. Junior Member iguano's Avatar
    Dec 18th, 2007
    San Diego, CA
    BMP 20th AE GTI, '08 A4 2.0T Quattro S-Line
    05-27-2012 11:53 AM #1
    Vortex, Please help! This has been boggling my mind like crazy.
    I just installed my HIDs and I've encountered a few problems. The first issue is that my drivers side bulb is pinkish, which after doing some research I have learned that the bulb is going out.
    The second issue is my passenger side HID sometimes does not come on at all and it requires me turning my lights off and back on several times before it comes on.
    I'm looking for the easiest/best way to get this fixed this weekend without having to order anything, so any help is greatly appreciated. Thank you!
    May 8th, 2012
    New York City
    Passat 08 jetta 01 jetta 98 240sx
    05-28-2012 09:39 PM #2
    Most likely the balast is not working.. And going death
    Is this a new set? Or it has been working for a while now?
    Sent from my DROID2 using Tapatalk
    DO YOU SPEAK DAS AUTO?
  3. Member xJOKERx's Avatar
    Apr 8th, 2009
    Dallas, TX
    05-29-2012 12:32 AM #3
    Usually the pink color to the bulb means that the salts in the bulb are burned up so the bulb is done. I would try picking up another set of bulbs and trying, or weigh and compare kit vs bulbs and go the kit route and replace.
  4. Junior Member iguano's Avatar
    Dec 18th, 2007
    San Diego, CA
    05-29-2012 12:44 PM #4
    Everything is brand new. I just received them from TMTuning. The driver's side ballast (The side w/ the pink bulb) works fine because I hooked up another bulb to it so I've diagnosed the issue as the bulb for that light. However, sometimes when I turn my lights on the HIDs don't come on at all, or just one of them will. I have no idea what would cause this.
  5. Member xJOKERx's Avatar
    Apr 8th, 2009
    Dallas, TX
    05-29-2012 02:13 PM #5
    What car are you putting these into?
  6. Member
    May 8th, 2012
    New York City
    05-29-2012 04:02 PM #6
    Quote Originally Posted by iguano View Post
    you may need to add an anti flicker unit to the ballast and replace both bulbs so you can verify they are not the problem
  7. Junior Member iguano's Avatar
    Dec 18th, 2007
    San Diego, CA
    05-29-2012 06:34 PM #7
    They're going into a MKIV GTI. The headlights that they're in are Daywalkers from TM Tuning.
    I already have anti-flicker decoders installed with them.
  8. Member gough14's Avatar
    Mar 12th, 2012
    Everett, WA
    1995 Jetta GL
    06-16-2012 01:05 AM #8
    The ballest sent getting enough power from the car that's why it won't turn on. Or it could be a bad ballest. Contact tmtuning and ask for a new one.
    Sent from my iPad using Tapatalk
    Volkswagen für das Leben.
    Will nichts kaufen, aber deutsche Autos
    VW Jetta MK3 2.slow, 2.5in Exhuast
